Waking up Arduino with reed switch
Hi
So I have got a huge problem. I have setup my Arduino to wake up on alarm from RTC and incoming Bluetooth connection but I have extra one which I would like to implement - wake Arduino up with reed switch. Here is the imgur link to switch I am using. Here is hardware debounce circuit for this switch:
Or here is more clear image of said circuit: link
While Arduino is awake, I can easily count every interrupt but to my surprise if I want to use this signal as a wake up interrupt signal for Arduino - nothing happens.
What am I doing wrong?
Hi whoru
Please post your program. Use code tags (the </> button on the toolbar above the reply window).
Regards
Ray
Posting only relevant part. Obviously I am using Arduino Mega.
#include <Wire.h>
#include <SoftwareSerial.h>
#include <SPI.h>
#include <DS3232RTC.h>
#include <Time.h>
#include "LowPower.h"
#define WSPEED 0
#define RLEVEL 1
#define RTCINT 4
#define BTINT 5
SoftwareSerial bt(10,11); // RX, TX
const byte wPin = 2;
const byte rPin = 3;
const byte btPin = 18; //interrupt from bluetooth
const byte rtcPin = 19; //interrupt from RTC
tmElements_t tm; //time from RTC
int BluetoothData; //bluetooth data
void pin19Interrupt(void) {
void pin18Interrupt(void) {
  ADCSRA = 0; // disable ADC (analog to digital conversion)
  pinMode(rPin, INPUT);
  pinMode(wPin, INPUT);
  pinMode(btPin, INPUT);
  pinMode(rtcPin, INPUT);
  bt.begin(38400);
  Serial.println(String("__DATE__ = ") + __DATE__);
  Serial.println(String("__TIME__ = ") + __TIME__);
  setTime(cvt_date(__DATE__, __TIME__));
  RTC.set(now());
  RTC.squareWave(SQWAVE_NONE);
  RTC.setAlarm(ALM2_EVERY_MINUTE,0,0,0);
  //RTC.setAlarm(ALM1_MATCH_HOURS,0,0,0);
  RTC.setAlarm(ALM1_EVERY_SECOND,0,0,0);
  RTC.alarmInterrupt(ALARM_2, true);
  Serial.println(String("System date = ") + day() + "/" + month() + "/" + year() + " " + hour() + ":" + minute() + ":" + second() + "\n");
  if(RTC.alarm(ALARM_1)) {
    Serial.println("ALARM 1");
  if (RTC.alarm(ALARM_2)) {
    Serial.println("ALARM 2");
  if (bt.available()) {
     BluetoothData = bt.read();
     if(BluetoothData == '!') {
  Serial.println("Entering sleep mode");
  delay(999);
  attachInterrupt(WSPEED, pin19Interrupt, FALLING);
  attachInterrupt(RLEVEL, pin18Interrupt, FALLING);
  attachInterrupt(BTINT, pin18Interrupt, FALLING); //bt
  attachInterrupt(RTCINT, pin19Interrupt, FALLING); //rtc
  LowPower.powerDown(SLEEP_FOREVER, ADC_OFF, BOD_OFF);
  detachInterrupt(0);
  delay(1);
//CONVERT __DATE__ and __TIME__ to time_t
time_t cvt_date(char const *date, char const *time) {
  char s_month[5];
  int year;
  tmElements_t t;
  static const char month_names[] = "JanFebMarAprMayJunJulAugSepOctNovDec";
  sscanf(date, "%s %hhd %d", s_month, &t.Day, &year);
  sscanf(time, "%2hhd %*c %2hhd %*c %2hhd", &t.Hour, &t.Minute, &t.Second);
  t.Month = (strstr(month_names, s_month) - month_names) / 3 + 1;
  t.Year = year - 1970;
  return makeTime(t);
EDIT: Interestingly, if I switch jumper from pin 3(int.1) to pin 18(int.5) I can easily wake Arduino up using reed switch with this very code. What is going on? How the heck int.1 is any different from int.5?
What happens if you create a separate ISR function for interrupt 1, rather than using the same function as for interrupt 5?
