i am trying to make automatic hand sanitizer for my class room.. i am using arduino uno... now what is my aim?... my aim is to develop a program in which ir sensor module take digital / analog input from hand movements and turn ON 5v dc water pump only for 3 seconds after 3 seconds it will automatically turn off the pump even if hand is there. when the next person again put hand in front of sensor it will agin start for 3 seconds and turns off.... components used arduino uno, ir sensor module, 5v dc relay, 5v dc water pump.... someone plz provide code... i am not belong to electronics so i don't have enough knowledge about it.. can some pz provide me ready-made code plzz plzz plzz... goal of this project is to use only limited quantity of sanitizer because some naughty students from my class are purposely put hand infront of sensor more than 10 minutes to empty the sanitizer bottle so i want a program evenif hand is present for long time in front of sensor it operates only for 3 seconds... it again turn ON only when 1st person hand was removed and the next person hand is come in front of sensor... plz give me code plz help me to solve this plz
We can help you with your project(s) when you show us what you have currently done.
This should be easily accomplished using the Arduino platform.
How do you propose to power this ?
Always start with a good schematic.
Show us a good schematic of your circuit.
Show us a good image of your ‘actual’ wiring.
Give links to components.
Posting images:
https://forum.arduino.cc/index.php?topic=519037.0
Use CTRL T to format your code.
Attach your ‘complete’ sketch between code tags, use the </> icon in the posting menu.
[code]Paste your sketch here[/code]
If you need someone to do all the work, there is a ‘Gigs and Collaborations’ forum on this web site where you can ask for assistance.
#define sensor 2 //The input of IR sensor connected to pin 2
#define motor 8 //The output of Motor connected to pin 8
int count=0;
pinMode(sensor,INPUT); // configuring pin A0 as Input
pinMode(motor, OUTPUT); // configuring pin 8 as Output
// initialize serial communication at 9600 bits per second:
int readPin = 0;
// the loop routine runs over and over again forever:
// read the input pin 2:
readPin = digitalRead(sensor);
if (readPin == 0)
count ++;
if(count < 10)
digitalWrite(motor,HIGH); // Send 1KHz motor signal...
// print out the value you read:
Serial.println("DC Pump is ON Now!!");
delay(100);
digitalWrite(motor,LOW);
else if (readPin == 1)
digitalWrite(motor,LOW); // Send 1KHz motor signal...
count =0;
Serial.println("DC Pump is OFF Now!!");
in the code bellow motor start for 3 seconds then stop and again start i can't find any solution please help me out please
int count=0;
int readPin = 0;
if (readPin == 0)
count ++;
if(count < 10)
delay(100);
count =0;
Take a look at the blink without delay example and the state change example in the IDE.
Please remember to use code tags when posting code
Thank you for the information.
Looks like you are a budding expert
Are you able to measure the resistance of the motor ?
If so, what is it ?
Will this be plugged into AC or is it battery powered ?
Do you have a web link to the sensor, if so, please supply.
How are you powering the pump ?
Please draw a ‘power’ wiring schematic showing: Arduino, relay card, sensor and pump connections.
// constants won't change. Used here to set a pin number:
const int ledPin = LED_BUILTIN;// the number of the LED pin
// Variables will change:
int ledState = LOW; // ledState used to set the LED
// Generally, you should use "unsigned long" for variables that hold time
// The value will quickly become too large for an int to store
unsigned long previousMillis = 0; // will store last time LED was updated
// constants won't change:
const long interval = 1000; // interval at which to blink (milliseconds)
// set the digital pin as output:
pinMode(ledPin, OUTPUT);
// here is where you'd put code that needs to be running all the time.
// check to see if it's time to blink the LED; that is, if the difference
// between the current time and last time you blinked the LED is bigger than
// the interval at which you want to blink the LED.
if (currentMillis - previousMillis >= interval) {
// save the last time you blinked the LED
// if the LED is off turn it on and vice-versa:
if (ledState == LOW) {
ledState = HIGH;
ledState = LOW;
// set the LED with the ledState of the variable:
digitalWrite(ledPin, ledState);
i found this code but as i already told my educational background is pharmacy i can't understand these codes plz help me to solve my issue
i leaned this from youtube video they prove code i run this code it will work perfectly but my aim is not satisfied so i tried to modify the code and i lost....still i can't find any solution so please help me out... i am powering my motor with usb cable it is 5v dc. i don't have any device to measure register of motor thank you
We can help, but please supply the information asked for in post #5.
If you continue to run the pump from the USB, you will damage something.
Do any friends have a DVM you can borrow ?
Are you able to measure the resistance of the motor ? NO...
If so, what is it ? NO...
Will this be plugged into AC or is it battery powered ? DC 5V
How are you powering the pump ? USING USB 5V CABLE
Please draw a 'power' wiring schematic showing: Arduino, relay card, sensor and pump connections.
PLEASE FIND ATTACHMENT BELLOW
what is DVM i don't know the long form
DVM digital volt meter.
Is your USB cable plugged into a computer or is it plugged into a Cell Phone 5 volt charger ?
This is how things should be wired:
Do you have a 5v Cell phone type charger ?
Change as needed:
Pin 2 is sensor input.
Pin 8 is relay control output.
// YY/MM/DD
// Version 1.00 20/06/10 Running code
#define motorON LOW //change as needed, most relay cards need a LOW to pick the relay
#define motorOFF !motorON
#define handDectected LOW //sensor gives a LOW when an object is detected, change as needed
const byte sensorPin = 2; //IR sensor connected to pin 2
const byte motorPin = 8; //motor relay connected to pin 8
const byte heartbeatLED = 13; //toggles every 500ms, acts as a heartbeat indication
byte lastReadSensor; //the state the sensor was last in
bool pumpFlag = false; //true means the pump is on
bool waitFlag = false; //false means we 'can' check the hand sensor
//timing stuff
unsigned long currentMillis;
unsigned long heartbeatMillis;
unsigned long checkSensorMillis;
unsigned long pumpMillis;
const unsigned long pumpOnInterval = 3 * 1000ul; //the pump is on for 3 seconds
unsigned long waitingMillis;
const unsigned long waitInterval = 2 * 1000ul; //wait 2 seconds before we allow more dispensing
pinMode(sensorPin, INPUT_PULLUP);
pinMode(motorPin, OUTPUT);
pinMode(heartbeatLED, OUTPUT);
} //END of setup()
//save current time
//to help show if there is any blocking code, this LED toggles every 500ms
if (currentMillis - heartbeatMillis >= 500)
//start this TIMER
heartbeatMillis = currentMillis;
digitalWrite(heartbeatLED, !digitalRead(heartbeatLED));
checkSensor();
//pump ON TIMER
if (pumpFlag == true && currentMillis - pumpMillis > pumpOnInterval)
//disable this TIMER
pumpFlag = false;
digitalWrite(motorPin, motorOFF);
Serial.println("");
//enter the waiting phase
//start the TIMER
waitingMillis = currentMillis;
//enable the wait TIMER
waitFlag = true;
//waiting phase TIMER
if (waitFlag == true && currentMillis - waitingMillis > waitInterval)
//allow sensor checking
//disabel this TIMER
waitFlag = false;
//other non blocking code
} //END of loop()
void checkSensor()
byte readStatus = 0;
//can we check the sensor yet ?
if (currentMillis - checkSensorMillis < 50)
//no, it is not time to read the sensor
return;
//restart the TIMER
checkSensorMillis = currentMillis;
//read the sensor
readStatus = digitalRead(sensorPin);
//has the sensor state changed ?
if (lastReadSensor == readStatus)
//no change
return;
//save the new state
lastReadSensor = readStatus;
//if we are allowed, has the hand been detected ?
if (waitFlag == false && pumpFlag == false && readStatus == handDectected)
//start the TIMER
pumpMillis = currentMillis;
//enable the pump TIMER
pumpFlag = true;
digitalWrite(motorPin, motorON);
//other sensors or switches
} //END of checkSensor()
thank you so much sir.. i'll check and post reply message .... again thank you so much
i am very happy thank you so much the code is working properly again and again thank you so much for help me to develop my home based machine..... i am so happy now .... again thank you
What do you teach ?
What is the student ages ?
chemistry, pharmaceutical chemistry, pharmacy of 5th to 12th standard students and some pharma students
age of students 11 year to 18 years
Teachers are great !
you are great sir ... thanks again for providing this valuable information ...
