hi ,
This is a code for measuring a constant voltage(DC VOLTMETER) using a voltage divider
After dividing the voltage, the two ends were connected to ground and the second to analog A0
The code displays the voltage on the serial monitor
I want to add a code to control the movement of the servo motor if the voltage(DC) is less than 20 volts and the return of the motor to its original position if the voltage is more than 20 volts.
Can you help me add the correct code for the servo motor? I tried but failed؟
And this is the code
const float arduinoVCC = 5.01;//Your Arduino voltage
unsigned long ValueR1 = 5070;
unsigned long ValueR2 = 7500;
double Voltage_Source = 12;
const int alanogPin = A0;//the pin connecting the voltage.
const int inputResolution =1023;//works with most Arduino boards
const float average_of = 500;//Average of 500 readings
float voltage;
Serial.println("hi: Reading Any voltage with Arduino");
//islamway.com ARDVC-01 Measure any voltage with Arduino
readVoltage();
Serial.print("Vin: ");
//Serial.print(voltage);
//Serial.print("V Avg: ");
Serial.print(getVoltageAverage());
Serial.println("V");
//delay(100);
}//loop end
* @brief calculates the input voltage and updates the variable "voltage"
* @param none
* @return does not return anything
* www.islamway.com code cairo, egypt
void readVoltage(){
//islamway.com http://islamway.com/L/?id=62
int A0Value = analogRead(alanogPin);
float voltage_sensed = A0Value * (arduinoVCC / (float)inputResolution);
// Serial.print("voltage_sensed:");
// Serial.print(voltage_sensed);
voltage = voltage_sensed * ( 1 + ( (float) ValueR2 / (float) ValueR1) );
}//readVoltage()
* @brief calculates the average of input voltage and updates the variable "voltage"
* @param none
* @return retuns average of "average_of" iteration of voltage
float getVoltageAverage(){
//This code is explained at my at http://islamway.com/L/?id=62
float voltage_temp_average=0;
for(int i=0; i < average_of; i++)
readVoltage();
voltage_temp_average +=voltage;
return voltage_temp_average / average_of;
//islamway ARDVC-01 Measure any voltage with Arduino
}//getVoltageAverage
I want to add a code so that the command is given to the servo motor to move 180 degrees if the voltage reading is less than 20 volts, and I want the servo to return to its original position if the voltage reading is more than 20 volts
This is the latest modification and it didn't work unfortunately
unsigned long ValueR2 = 94300;
#include "Servo.h" // include the servo library
Servo servo1; // creates an instance of the servo object to control a servo
int posServo1 = 0;
int servoPin = 9; // Control pin for servo motor
float voltage;
Serial.println("ISLAMWAY: Reading Any voltage with Arduino");
servo1.attach(servoPin); // attaches the servo on pin 4 to the servo object
servo1.write(45);
delay(2000);
//ISLAMWAY.com ARDVC-01 Measure any voltage with Arduino
readVoltage();
Serial.print("VOLT");
//delay(100);
analogValue = getVoltageAverage; // read the analog input (value between 0 and 1023)
Serial.println(analogValue);
if(analogValue==0)
posServo1=0;
else if(analogValue>=511)
posServo1+=1;
posServo1-=1;
posServo1=constrain(posServo1,0,180);
servo1.write(posServo1); // write the new mapped analog value to set the position of the servo
delay(50); // waits for the servo to get there
}//loop end
* @param none
void readVoltage(){
}//readVoltage()
* @param none
readVoltage();
What does "doesn't work" mean? As an example of "it doesn't work" is a meaningless description to describing a problem. I want help with getting the PRU_1 to work with PyPin on a BeagleBoneBlack, it doesn't work. Now does "it doesn't work" explain the issue?
I will connect the external voltage source to power the Arduino and I will be grateful if you write me the complete final code so that I don't get confused
All i need code to measure input dc voltage about 30 volt ..and if the input volt less than 20 volt then the servo move 180 degree ...and if the input voltage more than 20volt then servo return to 0 degree
In need the code and i will wireing all connection
The forum is not a place where a somebody writing code on demand.
We can help you, but you have to write code yourself.
Or you can hire a programmer in Paid consultancy section of the forum.
int posServo1 = 0;
float voltage;
servo1.write(45);
delay(2000);
readVoltage();
//delay(100);
if(analogValue==0)
posServo1=0;
posServo1+=1;
posServo1-=1;
}//loop end
* @param none
void readVoltage(){
}//readVoltage()
* @param none
readVoltage();
