Want to build an air pollution monitor
Hi. I'm interested in building a device that will monitor 1) the particulate level in the air, like PM2.5, and 2) the volatile chemicals in the air, like engine exhaust or formaldehyde. I understand the two will probably require separate sensors.
I hope someone well versed in those sensors can give me a simple breakdown of different technologies used, cost, and effectiveness in monitoring different things. For instance, I need the particulate sensor to be effective at reading particles that are 0.3micron or less.
Once I have the sensors selected, I think it should be easy to get it working with an Arduino and a display, no?
I'm also considering buying off the shelf monitors. But I'm not sure which route I should go. Please advise.
Thanks
A Google search for "PM2.5 sensor Arduino" turned up at least one reasonably-priced ($40-ish) sensor and some tutorials. Adafruit has one:
A Google search for "VOC sensor Arduino" turned up a combined CO, Alcohol, VOC sensor for $15:
Nice cheap intro is the IKEA VINDRIKTNING, which is easily hacked.
You can easily fit an 8266 inside the case.
I have a couple with BME280 and external 18Ds20
Both of these require a fan to bring the air to the sensor.
The Adafruit PM2.5 sensor includes a fan.
I have not looked, does it also include a calibration scenario based on the air volume being moved by the fan? Same must be done for VOC sensor.
Thanks. Do particulate monitor usually specify the size of the particles it can monitor? For instance, if I'm only interested in particles 0.3 microns or below, how do I make sure the monitor is not giving me readings of particles 1 microns and above?
Thanks
You filter then out BEFORE the sensor!
