I wanna learn to use interrupts, so I read some tutorials, watched some youtube-videos and finally tried some stuff in the IDE for myself.
Everything fine so far, all stuff worked as expected.
BUT: now I want to do some advanced blinky-stuff. Just like the well known BIOS-beep-codes, I want to flash the LED two or more short times every x seconds.
My very short test script looks like this:
#include "TimerOne.h"
const int ledPin = 13;
int every_x_seconds = 5;
void blinken() {
int i = 1;
do { // set the LED with the ledState of the variable:
digitalWrite(ledPin, digitalRead(ledPin) ^ 1);
delay(200);
delay(200);
i++;
} while (i <= 3);
pinMode(ledPin, OUTPUT);
Timer1.initialize(every_x_seconds * 1000000);
Timer1.attachInterrupt(blinken);
void loop(){
But now it just blinks one short moment "every_x_seconds", not 3 times as expected. Why?
PS: I know that I have to keep the interrupt-code short and the "delay()" is only used for me figuring out, how to do... Speaking about this: Whats the way to do this?
Thanks for reading my post and I appreciate every help
Heh I've got no idea how that works. Personally I'd specify a pin to either be an input, and read from it, or specify an output and write to it. I wouldn't mix on the same pin on the same line.
More rationally, don't delay more than a few 100us in an ISR. For instance I've
used delayMicroseconds (10) in an ISR to generate stepper motor control pulses,
this is perfectly valid.
Somethings don't / can't work in an ISR and busy-waiting is one of them - Serial calls
and delay() busy-wait, so they can jam the entire system if called in an ISR and they
sit there waiting for something to change.
By default interrupts are disabled throughout the ISR. You can re-enable interrupts
explicitly before returning, and thereafter delay() and Serial (for instance) will
work, but you had better understand what re-entrant code is before you do this,
since the ISR is then potentially re-entrant.
Yes, you can re-enable interrupts inside your ISR so that delayMicroseconds() and the communication functions work. A classic case is reading a sensor such as an SPI accelerometer inside an interrupt so that you get a precise timing on the readings.
If you forget to enable interrupts and call one of the delay functions then it will lock up at a random time, when the timer underneath the delay overflows and tries to call its own interupt.
is a very common way of inverting the value of a pin
Pins that are set as OUTPUT can always be read - though much of the time it is rather pointless.
...R
Yes that's ignorance on my part. Despite never reading it anywhere I must of decided that pins set as OUTPUT can only be written to and not read. Definitely good to know though.
