I want to read pulse from this water meter. It has 3 PINs-blue is Normally Open and Black is normally close).
I can use only normally open pin and use Debounce to count the pulse but it's not accurate when the flow is low because it'll keep connected for a long time which make it difficult to configure the debouncing period.
Is there anyway to use all the 3 wire and signal each other to count the pulse correctly?
Hello
Did you read the product specification of the supplier?
It's a reed switch. It's like a relay(NO,NC). But problem for me is to read its digital pulse
Hello,
you can do this job either by using an interrupt service routine or to dedect a state change methode within the LOOP().
Sounds like you are not handling state change detection and debounce correctly. Show your code and we can correct the problem. Or follow this example:
const byte ButtonPin = 2;
const unsigned long DebounceTime = 10;
boolean ButtonWasPressed = false;
unsigned long ButtonStateChangeTime = 0; // Debounce timer
void checkButton()
unsigned long currentTime = millis();
boolean buttonIsPressed = digitalRead(ButtonPin) == LOW; // Active LOW
// Check for button state change and do debounce
if (buttonIsPressed != ButtonWasPressed &&
currentTime - ButtonStateChangeTime > DebounceTime)
// Button state has changed
ButtonWasPressed = buttonIsPressed;
ButtonStateChangeTime = currentTime;
if (ButtonWasPressed)
// Button was just pressed
// Button was just released
dlloyd
August 11, 2021, 2:50am
7
No debouncing required if you use all 3 wires (Form-C type: NO, NC and COM). Just connect the NO and NC to separate inputs with 10K pullup resistors and connect COM to GND.
Here's example code that detects 5 unique conditions, bounce free.
Hello,
here comes my proposal for water meter counter. I´ve made an object for the water meter. I love objects and structs.
//BLOCK COMMENT
// https://forum.arduino.cc/t/water-meter-with-3-wire-reed-switch/894121
#define ProjectName "Water meter with 3 wire reed switch"
// LIBARIES INCLUSION
// CONSTANT DEFINITION
// you may need to change these constants to your hardware
const byte Input_[] {A0};
enum {One};
// VARIABLE DECLARATION
struct WATERMETER {
byte pin;
bool state;
float m3counter; // cubic meter counter
float m3pulse; // cubic meter per pulse
} watermeter {Input_[One], 1, 0.0, 0.01};
// FUNCTIONS
Serial.println(F("."));
Serial.print(F("File : ")), Serial.println(__FILE__);
Serial.print(F("Date : ")), Serial.println(__DATE__);
Serial.print(F("Project: ")), Serial.println(ProjectName);
pinMode (LED_BUILTIN, OUTPUT);
for (auto Input : Input_) pinMode(Input, INPUT_PULLUP);
void loop () {
digitalWrite(LED_BUILTIN, (currentTime / 500) % 2);
static unsigned long scanMillis;
const unsigned long scanDuration{20};
if (currentTime - scanMillis >= scanDuration) {
scanMillis=currentTime;
bool stateNew = digitalRead(watermeter.pin);
if (watermeter.state != stateNew) {
watermeter.state = stateNew;
if (!stateNew) {
watermeter.m3counter += watermeter.m3pulse;
Serial.print("Watermeter "), Serial.print(watermeter.m3counter), Serial.println(" m³");
Enjoy the day and enjoy coding.
Thanks for all the suggestions. I use Tasmota and set a pin as Counter pin and it works like a charm. I don't set debouncetime. Anyhow, i have to check if it counts correctly if the pressure of water flow change
I think your solution work because it uses all the 3 PIN which will switch the state correctly no matter how fast or slow the water flow.
But I tried Tasmota and it looks like it works correctly based on my initial observation. But this one use only NO and COM
system
Closed
December 17, 2021, 10:49am
11
