Hello,
I am searching for a water pressure sensor, with a 0~2 bar rating. easy to interface with arduino.. any ideas ?
Thank you for help
Hello,
Thank you for help
I don't know if this one
works with the arduino. It looks like it should. This one is 0-60psig (or 4bar). There are versions rated to 30psig/2bar.
Perhaps we can get confirmation from someone that has used one connected to an arduino.
adwsystems:
I don't know if this oneworks with the arduino. It looks like it should. This one is 0-60psig (or 4bar). There are versions rated to 30psig/2bar.
I agree that it should do the job: Output: 0.5-4.5V linear voltage output. 0 psi outputs 0.5V, 30 psi outputs 2.5V, 60 psi outputs 4.5V. With 5 volt supply. Three wires.
The op will need to find a 1/8 inch pipe tap to mount it.
Paul
Thanks for the confirmation before I wasted my $$$.
As for the tap, if in the USA, 1/8" NPT taps are a dime a dozen at the local BORG hardware store. 1/4" NPT is too difficult to find. Larger than that gets 'tricky' and expensive. Personal experience.
If outside the USA, the OP could always try Alibaba or Amazon. ![]()
