Water pump issues with code for self watering plant- Resolved
Hi, I am attempting to create a self watering plantpot which monitors soil moisture content, light and temperature, however when trying to add the waterpump to the rest of the circuit I am having issues as it will no longer run. With just the code below and without the relay and pump connected the circuit does the desired tasks. How do I add the waterpump and relay (which I can get to work on its own) to the rest of the circuitry, I have also used a secondary ps for the pump using 9v battery.
I think it may be a current issue as both circuits work when they are separate. Please see below code, and circuit schematic.
Here is the schematic for the relay and pump.
#define BLYNK_TEMPLATE_ID "TMPL5fmzE-Hpj"
#define BLYNK_TEMPLATE_NAME "Quickstart Template"
#define BLYNK_AUTH_TOKEN "xn54Yt1kZ8AX_7sozzQBeUZoEmolmOKR"
#define BLYNK_PRINT SerialUSB
#include <SPI.h>
#include <WiFiNINA.h>
#include <BlynkSimpleWiFiNINA.h>
#include <LiquidCrystal.h>
char ssid[] = "iPhone";
char pass[] = "password";
BlynkTimer timer;
BLYNK_WRITE(V0){
  digitalWrite(7, param.asInt());
LiquidCrystal LCD(0,1,2,3,4,5);
#define analogPin A2
#define beta 3950
#define resistance 10
int lightRead = 0;
int lightLevel;
int button=6;
int moistureSensor;
int moisturePercentage;
#define moisture A4
//const int buttonPin = 6;// Pushbutton pin;
const int redPin = 8;    // Red LED pin
const int greenPin = 10; // Green LED pin
const int bluePin = 9;   // Blue LED pin
int motorState = LOW;      // Motor state (OFF for default)
int lastButtonState = LOW; // Last state of the button
int currentButtonState;    // Current state of the button
const int pump_pin = 11;
/*unsigned long startTimeMotor = 0;
const unsigned long MotorRunTime = 5000;  // 5 seconds
unsigned long previousMillisMotor = 0;
unsigned long startTimeMotor;
const unsigned long motorDuration = 5000;
//Arrays needed for trhe unhappy face on LCD screen
byte a[8] = {B00001,B00011,B00111,B01110,B11110,B11111,B11111,B11111};
byte b[8] = {B11111,B11111,B11111,B01110,B01110,B11111,B11111,B11111};
byte c[8] = {B10000,B11000,B11100,B01110,B01111,B11111,B11111,B11111};
byte d[8] = {B11011,B11000,B11100,B11110,B01111,B00111,B00011,B00001};
byte e[8] = {B11111,B00000,B00000,B00000,B00000,B11111,B11111,B11111};
byte f[8] = {B11011,B00011,B00111,B01111,B11110,B11100,B11000,B10000};
//Arrays needed for trhe happy face on LCD screen
byte g[8] = {B00001,B00011,B00111,B01110,B11100,B11111,B11111,B11111};
byte h[8] = {B11111,B11111,B11111,B01110,B00100,B11111,B11111,B11111};
byte i[8] = {B10000,B11000,B11100,B01110,B00111,B11111,B11111,B11111};
byte j[8] = {B11111,B11111,B11110,B11100,B01101,B00111,B00011,B00001};
byte k[8] = {B11111,B00000,B00000,B11111,B11111,B11111,B11111,B11111};
byte l[8] = {B11111,B11111,B01111,B00111,B10110,B11100,B11000,B10000};
//Array for small waterdrop
byte m[8] = {B00000,B00001,B00011,B00111,B01111,B11111,B11111,B01110};
  LCD.begin(16,2);
  SerialUSB.begin(115200);
  Blynk.begin(BLYNK_AUTH_TOKEN, ssid, pass);
  LCD.print("  Initializing  ");
  for(int b = 5; b <= 10; b++){
    LCD.setCursor(b, 1);
    LCD.print(".");
  pinMode(redPin, OUTPUT);
  pinMode(greenPin, OUTPUT);
  pinMode(bluePin, OUTPUT);
  pinMode(pump_pin, OUTPUT); //Motor  pinMode(1, INPUT); //on/off switch
  pinMode(button, INPUT);
  pinMode(A2, INPUT); //Temp
  pinMode(A3, INPUT); //light
  pinMode(A4, INPUT); //moisture
  pinMode(7, OUTPUT);
  //startTimeMotor = millis();  // Record the starting time
  //code for lcd smileyface
  LCD.createChar(0, a);
  LCD.createChar(1, b);
  LCD.createChar(2, c);
  LCD.createChar(3, d);
  LCD.createChar(4, e);
  LCD.createChar(5, f);
  //code for lcd unhappyface
  LCD.createChar(6, g);
  LCD.createChar(7, h);
  LCD.createChar(8, i);
  LCD.createChar(9, j);
  LCD.createChar(10,k);
  LCD.createChar(11,l);
  //code for lcd raindrop
  LCD.createChar(12, m);
  Blynk.run();
  //tempDegrees = (((tempRead-20) * 0.488)-40);//calculates degrees
  //tempDegrees = ((tempRead*5.0/1024.0)-0.5)*100.00;
  //read thermistor value
  long a = analogRead(analogPin);
  float tempC = beta / (log((1025.0 * 10 / a - 10) / 10) + beta / 298.0) - 300; //conversion for degrees in celsius
  Blynk.virtualWrite(V3, tempC);
  //LCD.setCursor(0, 0); // set the cursor to column 0, line 0
 // LCD.print("Temp: ");// Print a message of "Temp: "to the LCD.
  // Print a centigrade temperature to the LCD.
  //LCD.print(tempC);
  // Print the unit of the centigrade temperature to the LCD.
  //LCD.print(char(223));//print the unit" ℃ "
 // LCD.print("C");
  // (note: line 1 is the second row, since counting begins with 0):
  //delay(200); //wait for 100 milliseconds
  int moistureSensor = analogRead(moisture);
  moisturePercentage = map(moistureSensor,0,1023,100,0);
  Blynk.virtualWrite(V2, moisturePercentage);
  int lightRead = analogRead(A3);
  lightLevel = map(lightRead,1023,0,100,0);
 // lightLevel = (lightLevel - 100) * -1;
  Blynk.virtualWrite(V1, lightLevel);
  Serial.println("M =");
  Serial.println(moisturePercentage);
  Serial.println("L =");
  Serial.println(lightLevel);
  Serial.println("T =");
  Serial.println(tempC);
  currentButtonState = digitalRead(button);
 if (currentButtonState == HIGH && lastButtonState == LOW)
    //runMotor();
    Watering();
    digitalWrite(redPin, LOW);
    digitalWrite(greenPin, LOW);
    digitalWrite(bluePin, HIGH);
    //motorState = !motorState;  // Toggle the motor state on button press
  //controlMotor();  // Call the function to control the motor
  lastButtonState = currentButtonState;
//=======This initial push button if statement^^^^ is breaking the millis and loop below!====
 if (digitalRead(button) == HIGH)
    runMotor();
    Watering();
  unsigned long currentMillisLCD = millis();
 //if both moisture and light are low (out of water)
  if (moisturePercentage >=0 && lightLevel <=45){
    lightandmoisturebad();
    showvaluesbad();
    //runMotor();
    Watering();
//if just light is low
else if(lightLevel <=45){
    lightbad();
    showvaluesbad();
//if just moisture is too high (in water)
  else if(moisturePercentage <=80){
   digitalWrite(pump_pin, LOW);
   moisturebad();
   showvaluesbad();
   digitalWrite(redPin, HIGH);
   digitalWrite(bluePin, LOW);
  else if(moisturePercentage >=0){ //when moisture too low
    showvaluesbad();
    //runMotor();
    Watering();
    LCD.setCursor(0,0);
    LCD.clear();
    LCD.print("Warning,Moisture");
    LCD.setCursor(0,1);
    LCD.print("Level Too LOW");
  else if(moisturePercentage >=0 && lightLevel >=45){
    showvaluesgood();
    lightandmoisturegood();
void lightandmoisturebad()
  LCD.setCursor(0,0);
  LCD.clear();
  LCD.print("Warning, light &");
  LCD.setCursor(0,1);
  LCD.print("soil bad!");
void lightandmoisturegood()
  LCD.setCursor(0,0);
  LCD.clear();
  LCD.print("light &");
  LCD.setCursor(0,1);
  LCD.print("soil good!");
  digitalWrite(8, LOW);
  digitalWrite(9, LOW);
  digitalWrite(10, HIGH);//Green RGB on
  LCD.clear();
void lightbad()
  LCD.setCursor(0,0);
  LCD.clear();
  LCD.print("Warning, light");
  LCD.setCursor(0,1);
  LCD.print("level bad ");
  digitalWrite(8, HIGH); //Red RGB on
  digitalWrite(10, LOW);
void moisturebad()
  LCD.setCursor(0,0);
  LCD.clear();
  LCD.print("Warning, soil");
  LCD.setCursor(0,1);
  LCD.print("moisture bad ");
void showvaluesgood()
  LCD.setCursor(0,0);
  LCD.clear();
  LCD.print("M=");
  LCD.print(moisturePercentage);
  LCD.setCursor(7,0);
  LCD.print("L=");
  LCD.print(lightLevel);
  LCD.setCursor(0,1);
  LCD.print("T=");
  LCD.print(tempC);
  LCD.print("C");
  //lcd smiley face for good values
  LCD.setCursor(13, 0);
  LCD.write(byte(0));
  LCD.setCursor(14, 0);
  LCD.write(byte(1));
  LCD.setCursor(15, 0);
  LCD.write(byte(2));
  LCD.setCursor(13, 1);
  LCD.write(byte(3));
  LCD.setCursor(14, 1);
  LCD.write(byte(4));
  LCD.setCursor(15, 1);
  LCD.write(byte(5));
  LCD.clear();
void showvaluesbad()
  LCD.setCursor(0,0);
  LCD.clear();
  LCD.print("M=");
  LCD.setCursor(7,0);
  LCD.print("L=");
  LCD.setCursor(0,1);
  LCD.print("T=");
  LCD.print(tempC);
  LCD.print("C");
  //lcd unhappy face for badvalue/s
  LCD.write(byte(6));
  LCD.write(byte(7));
  LCD.write(byte(8));
  LCD.write(byte(9));
  LCD.write(byte(10));
  LCD.write(byte(11));
  delay(1500);
  //LCD.clear();
void Watering()
  LCD.setCursor(0,0);
  LCD.clear();
  LCD.print("Watering: ");
  digitalWrite(pump_pin, HIGH);
  LCD.setCursor(11, 0);
  LCD.write(byte(12));
  LCD.setCursor(10, 1);
  LCD.setCursor(12, 1);
  digitalWrite(9, HIGH);
  delay(5000);
void runMotor() {
  unsigned long currentTimeMotor = millis();
  unsigned long elapsedTimeMotor = currentTimeMotor - startTimeMotor;
  // Check if 5 seconds have passed
  if (elapsedTimeMotor < motorDuration) {
    // Turn the motor on
    // Turn the motor off after 5 seconds
    // Reset the start time for the next cycle
void controlMotor(){
  if (motorState == HIGH) {
    // Motor control code for when the button is pressed (Start)
    LCD.setCursor(0,0);
    LCD.print("Watering");
    for (int a = 8; a <= 12; a++) //LCD Cursor 8-12
    LCD.setCursor(0,0);
    LCD.setCursor(a, 0);
    LCD.print(".");
  LCD.clear();
    // Motor control code for when the button is not pressed (stop)
You cannot power a motor from an Arduino pin !
Post a link to the pump data sheet or product page, and forum members can advise on how to safely power and control it.
Don’t use pins 0 or 1, these are for communications.
I am using the arduino pin (pump_pin) to power the relay for the pump to work, sorry if the tinkerCAD sketch is confusing. The LCD seems to work correctly along with the rest of the circuit until the relay and pump are added(which also work together using their own code).
Hi sorry but I have been unable to find the data sheet for the pump, below is the link to the pump.
https://www.amazon.co.uk/RUNCCI-YUN-Submersible-Brushless-Flexible-Fountain/dp/B082PM8L6X/ref=asc_df_B082PM8L6X/?tag=&linkCode=df0&hvadid=394354543395&hvpos=&hvnetw=g&hvrand=5276697030108340206&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9045202&hvtargid=pla-858762822213&mcid=079bc4aea21c3408879b3ed256e3df47&ref=&adgrpid=82243840952&th=1
Please see the link below for the relay I am currently using.
Hailege 2pcs 5V One Channel Relay Module Relay Switch With OPTO Isolation High Low Level Trigger : Amazon.co.uk: Business, Industry & Science
More confusion.
Are you using an UNO or a WiFi 1010?
Sorry I am using a WIFI 1010
Powering the Arduino and a motor from a 9V block battery is not going to work well, either. When the pump is powered up the voltage of the battery may drop so low the Arduino stops working.
What would you recommend I use instead of the 9v battery?
The pump is designed to run on 3-4.5V, not 9V.
Since you have a relay to control the pump, use a 2x or 3xAA battery pack to power it. The pump draws up to 200 mA, so AA batteries will last about 10 hours of continuous operation.
For long term operation, use a 3-4.5V "wall wart" power supply.
Yes, perfect I have done this but did not resolve the issue with the LCD displaying random characters once the pump is turned off.
To rectify this I added a capacitor across the positive and negative of the pump, I think the pump was generating noise, picked up on the comm lines to the LCD.
