WAV-Player with RF remote
I try to build a WAV-Player with Arduino UNO R4 Minima that takes the files from a micro-SD-card module and which is controlled by a 433 MHz remote. Does the wiring look reasonable, especially the voltage divider before the RCA jacks?
What part of this creates the audio from the stored data?
The Arduino itself via port A0.
If I understand your drawing correctly you are using
  • a 10µF capacitor to block DC and
  • a 4.7 kOhm and a 1 kOhm resistor as a voltage divider
  • A0 of a UNO R4 Minima as DAC output
  • two audio jacks connected in parallel to the 1 kOhm resistor
Blocking the DC should be fine.
The voltage divider (1k/(1k+4,7k) = 0.1754 ) will reduce the voltage at the jacks to about 18%.
To be more flexible you could use a potentiometer (e.g. 10 kOhm) instead of the fixed resistors. That would allow to adjust the voltage depending on the input resistance/impedance of the amplifier you use.
If you want to dive into it you may find this helpful (or not ;-) )
https://www.electronics-tutorials.ws/amplifier/input-impedance-of-an-amplifier.html#:~:text=What%20is%20the%20Input%20Impedance,Impedance%20Based%20on%20Amplifier%20Configuration
The idea is to reduce the 5V from the Arduino to the typical 0.9V (1V ?) for the audio system and to protect the A0 Port from overvoltage. If this is necessary at all.
In order to block DC and pass AC, you need to use a NON-POLARIZED capacitor! Otherwise you will get really distorted wave forms.
Not necessarily. Electrolytic (polarized) capacitors are widely used in audio applications.
It is important to connect the capacitor the right way (plus to the DAC pin and minus to the jack). The capacitor in combination with the amplifier input resistance/ impedance will create a filter. For Audio applications and a 10 uF capacitor an input resistance of 10 kOhm up to 100 kOhm should be fine.
See here
https://passive-components.eu/capacitor-selection-for-coupling-and-decoupling-applications/
and also here
https://audioxpress.com/article/selecting-electrolytic-capacitors-for-lowest-distortion#:~:text=The%20results%20all%20have%20the,rule%20out%20any%20rectification%20process.
Yes, that is very interesting.
I am reminded of a customer my company had for years. He was an audio engineer. He sold silver speaker wires and said he and others could tell the difference. With my poor hearing, I had to accept that!
He also designed and built and sold preamps for CD music systems. We built the boards less any active components like op-amps, etc. These, the engineer picked by hand to give the lowest noise/best sound. Again, I have to take his word for it. He sold lots of them around the world. Mostly to people that could afford the best.
I agree with you that using other than electrolytic capacitors has certain advantages. They have the advantage to provide higher capacity at reasonable dimensions.
The main disadvantage is that they tend to "blow up" after a certain time of usage (average 10 to 15 years, or sooner if not correctly biased). A common problem of older radios and amplifiers.
The silver speaker wires are nice... I know some people are mad about gold-plated connectors. They swear they can hear the difference... But there are also people who swear that audio CDs would sound better when they are stored in the fridge.
Your resistor choice is quite ok. If you want to be more flexible you could use a trimmer potentiometer e.g. like this
https://us.rs-online.com/product/bourns/3296w-1-103lf/70153918/
or yu could optimize the voltage divider by using DAC -- 10µF -- 4 k -- 1 k -- GND where the 4k are build by 2 x 2k Ohm (E24 series).
But there's nothing better than creating a setup for testing!
"In theory, theory and practice are the same. In practice, they are not."
