wave shield
untill now i have been into very basic arduino. such as start/ stop different machines.. and it has worked very well to just copy paste code and edit it a bit..
i am not skilled in programming and since i got the wave shild i have been in problems because the code examples are so complicated to understand.
does someone have a very besic code that could play a soundfile from the wave shield and start a motor in the same time( the motor i control from a relayboard )
would be wonderful :slight_smile:
(deleted)
Thanks.
i have this waveshield
i found a library called WaveHC and put it in the libraries folder and still the computer says
ave_test.ino:1:20: fatal error: WaveHC_h: No such file or directory
compilation terminated.
when i try your code
in my library manager it says waveHC version unknows installed... see attachment.???? where can i find one that works?
after trying again it doesn´t complain for the library.. i changed it to #include <WaveHC.h>
now it complains this
wave_test.ino: In function 'void setup()':
wave_test:5: error: 'waveshield' was not declared in this scope
wave_test.ino: In function 'void loop()':
wave_test:10: error: 'waveshield' was not declared in this scope
Well, we are going to complain that you didn't post your code!
