Has anyone used the waveshare sx1262 hf lora module with the arduino uno.
I could not get it to work ...i dont know where to start
Most LoRa modules are 3.3V logic and cannot be directly connected to 5V logic Arduinos such as the UNO.
Maybe provide some useful information such as the code you are using, the schematic\connections and links to the modules your are using.
Hi, @lamshuwa
Welcome to the forum.
Can you please post your codes?
Thanks.. Tom...
Micro Controller: Arduino Uno
Lora Module: Waveshare sx1262 HF
Antenna Used: 698 – 960 MHz & 1710 – 2690 MHz 6/7 dBi Gain Magnetic Mount Antenna (0.5m)
Pin Configuration:
|SX1261 Pin|Arduino Pin|Description|
|MOSI |11 |Master Out Slave In (Data)|
|MISO |12 |Master In Slave Out (Data)|
|CLK |13 |Serial Clock|
|CS |10 |Chip Select|
|RESET | 9 |Reset Pin|
|DIO1 | 2 |Interrupt Pin|
|GND |GND |Ground|
|VCC |3.3V |Power Supply|
Transmitter Code:
#include <SPI.h>
#include <LoRa.h>
#define CS_PIN 10 // Chip Select pin
#define RESET_PIN 9 // Reset pin
#define DIO0_PIN 2 // DIO0 pin for interrupt
while (!Serial); // Wait for serial port to open
Serial.println("LoRa Transmitter Setup");
pinMode(RESET_PIN, OUTPUT);
digitalWrite(RESET_PIN, HIGH);
delay(10);
digitalWrite(RESET_PIN, LOW);
delay(50); // Reset delay
delay(100); // Delay for module to stabilize
Serial.print("Initializing LoRa... ");
if (!LoRa.begin(868E6)) { // Set frequency to 868 MHz
Serial.println("LoRa init failed!");
while (1); // Stop further execution
Serial.println("LoRa init successful!");
LoRa.setTxPower(13); // Set transmission power
const char *msg = "Hello LoRa!";
Serial.print("Sending: ");
Serial.println(msg);
LoRa.beginPacket();
LoRa.print(msg);
LoRa.endPacket();
Serial.println("Packet sent!");
delay(2000); // Wait 2 seconds before sending again
Receiver Code:
#include <SPI.h>
#include <LoRa.h>
Serial.println("LoRa Receiver Setup");
delay(10);
int packetSize = LoRa.parsePacket();
if (packetSize) {
String receivedMessage = "";
while (LoRa.available()) {
receivedMessage += (char)LoRa.read();
Serial.print("Received: ");
Serial.println(receivedMessage);
Serial.println("No packet received.");
delay(1000); // Delay between checks
You need bidirectional logic level shifters to connect that 3.3V module to a 5V Uno.
If you have connected the two without using the level shifters, one or both may already be damaged. It is best to use a 3.3V Arduino with that radio.
arduino uno board have the 3.3v pin
The Arduino UNO will put out 5V logic level signals. These signals do not convert the UNO 5V logic\GPIO signals to 3.3V levels just because you connect the LoRa module to the UNOs 3.3V power supply pin.
On some UNOs, the 3.3V pin cannot provide enough current for someting like a LoRa transmitter.
Using 3.3V logic Arduinos or Micros for 3.3V logic modules (such as LoRa) is heaps easier.
I did what you guys suggested using the logic level cobverter ....but it fail to initialize
Some logic level converters are not so good.
Much easier when using 3.3V modules to use 3.3V Microcontrollers\ Arduinos.
Hi, @lamshuwa
Can you post some images of your project?
So we can see your component layout.
Thanks.. Tom...
That LoRa library does not support SX1262 LoRa devices.
So i have been doing so far:
Firstly i use only the sx1262 module and arduino uno...Initialization was success and also i can send and receive although the rssi is terrible and the data received is gibberish
Then i learn that we need a logic level converter, and a voltage regulator, but when i connected all those it always fail to initialize even when checking the wiring and configuration many times...
Then i tried again like how i did the first time ...initialization success but this time i cannot receive data sending by the Transmitter
Library Used: RadioLib by jgromes
Example code from his github Sx126x_PingPong
Wire Configuration :
CS-10
CLK-13
MOSI-11
MISO-12
RESET-3
BUZY-9
DIO1-2
I am unable to enter AT Command mode in SX1262-HF-DTU-LoRa module of Waveshare. Have connected the LoRa - serial Port DB9 to Laptop - using SSCOM software or Tera Terminal. Please help. Using these LoRa devices (8nos) in a wireless mesh network on a rooftop for operating pumps ON/OFF operation through a PLC. Have updated Firmware through RS485 port in all the devices.
Forum members will have seen your other thread about the module you are using;
Entering AT Command Mode SX1262-LoRa-DTU - #9 by rooftopurja](Entering AT Command Mode SX1262-LoRa-DTU - #9 by rooftopurja)
I had this issue too and I fixed it!
first of all before any command do it :
set NRESET_LORA to Low
wait for about 200 milli seconds
set NRESET_LORA to High
wait for about 500 milli seconds
then send this command
// SetDIO3asTCXOCtrl SPI Transaction
cmnd[0] = 0x97; // 0x97 is SetDIO3asTCXOCtrl
cmnd[1] = 0x00; // DIO3 outputs 1.6 V to supply the TCXO
cmnd[2] = 0x00;
cmnd[3] = 0x00;
let me know if you fix it ![]()
(base on my repository you can see more setting : LORA1262/LORA1262/Libs/Src/SX1262.c at main · Saba-abiri/LORA1262 · GitHub)
