Way to hack the digital pins on Nano?
I want to try to make the built in LED on my Nano fade using code. Is that possible even though it isn't on a PWM pin?
or read up on software pwm.
It’s not too hard, once you understand what PWM is.
I’ve run 72 channels with no problems.
(24x RGB LEDs)
You can use a technique called "bit angle modulation" and here are two demonstrations, one doing it all in a loop and another using a timer interrupt. The version using the timer makes the brightness fading a little smoother to my eye. If you go on Youtube and search for "Arduino bit angle modulation", you can watch a video I made about the technique.
Version one, not using a timer interrupt:
#define PIN_LED 13
byte _bamCount;
uint8_t _ledBrightness = 0;
uint8_t _fadeUp = 1;
uint32_t _currentMillis, _lastUpdateMillis;
  pinMode(PIN_LED, OUTPUT);
  _currentMillis = millis();
  // Once every 50 milliseconds, change the led brightness.
  // It cannot go over 15 so when it gets that bright, change it back to 0.
  if (_currentMillis - _lastUpdateMillis > 49)
    _lastUpdateMillis = _currentMillis;
    if (_fadeUp)
      _ledBrightness++;
      if (_ledBrightness == 15) _fadeUp = 0;
      _ledBrightness--;
      if (_ledBrightness == 0) _fadeUp = 1;
  bitAngleModulationHandler();
void bitAngleModulationHandler()
  _bamCount++;
  if (_bamCount > B1111) _bamCount = B0001; // Ensure counter goes from 1 to 15
                                                  // if led brightness is 10 (binary B1010)
  if      (_bamCount == B0001) { updateLeds(0); } // cycle  1 led off
  else if (_bamCount == B0010) { updateLeds(1); } // cycle  2 led on
                     // B0011                        cycle  3 led still on
  else if (_bamCount == B0100) { updateLeds(2); } // cycle  4 led off
                     // B0101                        cycle  5 led still off
                     // B0110                        cycle  6 led still off
                     // B0111                        cycle  7 led still off
  else if (_bamCount == B1000) { updateLeds(3); } // cycle  8 led on
                     // B1001                        cycle  9 led still on
                     // B1010                        cycle 10 led still on
                     // B1011                        cycle 11 led still on
                     // B1100                        cycle 12 led still on
                     // B1101                        cycle 13 led still on
                     // B1110                        cycle 14 led still on
                     // B1111                        cycle 15 led still on
                     // So out of the available 15 cycles, a brightness of 10 sets the
                     // led to be on for 10 of them.
void updateLeds(byte bitPosition) {
  // if brightness is 10 (binary B1010) and bit position is 0
  // bitRead(B1010, 0) = 0 = false
  bool isEnabled = bitRead(_ledBrightness, bitPosition);
  digitalWrite(PIN_LED, isEnabled);
Version 2 using a timer:
#define PIN_LED 13
volatile byte _bamCount;
volatile uint8_t _ledBrightness;
volatile uint8_t _increaseBrightness;
  // Setup timer2 to cause an interrupt every 640 microseconds.  1024 prescaler / 16000000 clock frequency Hz * 10 counts
  TCCR2A = _BV(WGM21);  // CTC
  TCCR2B = _BV(CS22) | _BV(CS21) | _BV(CS20); // 1024 prescaler
  OCR2A = 10;           // Output Compare Register A
  TIMSK2 = _BV(OCIE2A); // Output Compare Interrupt Enable Match A
  // It starts at 0 and goes up to 15, then back down to 0, and repeats.
  if (_currentMillis - _lastUpdateMillis > 49) {
    if      (_ledBrightness == 0)  _increaseBrightness = true;
    else if (_ledBrightness == 15) _increaseBrightness = false;
    if (_increaseBrightness)
      _ledBrightness++;
      _ledBrightness--;
ISR(TIMER2_COMPA_vect) // timer interrupt service routine
  _bamCount++;
  if (_bamCount > 15) _bamCount = 1; // Ensure counter goes from 1-15.
  digitalWrite(PIN_LED, bitRead(_ledBrightness, bitPosition));
