Ways to Crash ESP32/FreeRTOS
A guide for newbies what should be avoided in writing code for the ESP32.
First example: do nothing is harmful!
A delay() had to be inserted to prevent too fast error logging. Remove it and it will only crash faster.
[code]
void Crash1(void* pv) {
  delay(10000); //time between continued crashes
} //do nothing, return
  xTaskCreate(Crash1, "Creash1", 10000,NULL,1,NULL);
[/code]
Lesson learned:
A task NEVER should return.
Error log using Core Debug Level "Error":
Guru Meditation Error: Core 0 panic'ed (IllegalInstruction). Exception was unhandled.
Memory dump at 0x400d10b8: 04e5fbda 00f01d00 81006136
Core 0 register dump:
PC : 0x400d10bd PS : 0x00060a30 A0 : 0x00000000 A1 : 0x3ffc77c0
A2 : 0x00000000 A3 : 0x00000000 A4 : 0x00000000 A5 : 0x00000000
A6 : 0x00000000 A7 : 0x00000000 A8 : 0x800d10bd A9 : 0x3ffc77a0
A10 : 0x00002710 A11 : 0x00000000 A12 : 0x00000000 A13 : 0x00000000
A14 : 0x3ffbd2e8 A15 : 0x80000001 SAR : 0x00000000 EXCCAUSE: 0x00000000
EXCVADDR: 0x00000000 LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000
Backtrace: 0x400d10ba:0x3ffc77c0
ELF file SHA256: fcf1f381f570a6fb
Rebooting...
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1344
load:0x40078000,len:13964
load:0x40080400,len:3600
entry 0x400805f0
this is documented here
A task should have the following structure:
    void vATaskFunction( void *pvParameters )
        for( ;; )
            -- Task application code here. --
        /* Tasks must not attempt to return from their implementing
        function or otherwise exit.  In newer FreeRTOS port
        attempting to do so will result in an configASSERT() being
        called if it is defined.  If it is necessary for a task to
        exit then have the task call vTaskDelete( NULL ) to ensure
        its exit is clean. */
        vTaskDelete( NULL );
I know that many ways are documented. Here I want to create a summary of what to avoid.
OK - may be there is value in adding a link to the dos on top of the don'ts? happy to remove my post if that's not useful
Here comes #2, a task that does nothing on Core 0.
TaskHandle_t Task2; //->Crash2
void Crash2(void* pv) {
  while(true)
} //do nothing, don't return
  xTaskCreatePinnedToCore(
    Crash2,   // Task function.
    "Crash2", // name of task.
    10000,    // Stack size of task
    NULL,     // parameter of the task
    1,        // priority of the task
    &Task2,   // Task handle to keep track of created task
    0);       // pin task to core 0 <=======================
Lesson learned:
Never pin a long running task to core 0.
Core 0 does essential housekeeping and event handling. Blocking these tasks will make the watchdog bark and the system reboot.
Solutions:
  • dont pin a task, in detail not to core 0
  • don't assign "Arduino runs on Core: 0"
  • insert yield() or delay() in order to force a task switch
  • have more tasks at same or higher priority
Error log (truncated):
E (30094) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:
E (30094) task_wdt: - IDLE (CPU 0)
E (30094) task_wdt: Tasks currently running:
E (30094) task_wdt: CPU 0: Crash2
E (30094) task_wdt: CPU 1: loopTask
E (30094) task_wdt: Aborting.
abort() was called at PC 0x400d4455 on core 0
Next one is a bit tricky. It's about using the handle of a deleted task. The task handle can(!) become invalid after the task is deleted, but not always.
If a task terminates itself the handle seems to remain valid, with a task state of eDeleted and using the handle does no harm. Perhaps no cleanup of the task memory will be performed?
If a task is deleted from outside then its handle can become invalid. Not always, but at least in this special case:
TaskHandle_t Task3; //->Crash3
void Crash3(void* pv) {
L:
  for (int i=10; i>0; i--) {
    Serial.println(i);
    //vTaskSuspend(NULL); // wait for resume
    delay(200);
//all done
  goto L; //try again
  xTaskCreate(
    Crash3,   // Task function.
    "Crash3", // name of task.
    &Task3);  // Task handle to keep track of created task
eTaskState ts3 = eTaskGetState(Task3);
  Serial.print("loop "); Serial.println(ts3);
//kill task 3
  delay(3000);
  Serial.println("deleting...");
  vTaskDelete(Task3); //crash here on second occurence!
  Serial.println("deleted!");
Lesson learned:
Don't use the handle of a deleted task.
Dont delete a deleted task once more.
Comments on variations of the code are welcome :slight_smile:
Serial Monitor:
10
9
8
7
6
5
4
3
2
1
10
9
8
7
6
5
deleting...
deleted!
loop 4
deleting...
Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
This is not a crash but a bug :frowning:
Add
int T1;
to a program and help me interpreting the error message.
This name (and T2, T3...) seems to be in use for something else, but what?
pins short names for internal touch sensors pins (The ESP32 has 10 internal capacitive touch sensors. These can sense variations in anything that holds an electrical charge, like the human skin)
You are such a precious source of knowledge! :kiss:
Thanks for reading even this topic :slight_smile:
The first part of that statement does not follow from the example, and is generally bad advise. Your example code does not crash if the task is pinned to Core 1. However, if the task is created with no core affinity, then it's quite possible that the task will eventually run on Core 0 and crash. You can never tell when this will happen because, aside from trivial code like yours, the dynamics of context switching are far too complex to predict.
I'd go so far as to say that until you become significantly more skilled in working in this programming paradigm, you should always pin tasks you create to Core 1.
Additionally, the "Don't Pin" advise makes no sense when working with ESP32 variants that have a single core.
Finally, with the tight loop while that you've written for testing:
  while(true)
there's a chance that it will be completely optimized away as the compiler can see it has no observable effects. This depends on the exact structure of the code and is again too complex for analysis. So, you should replace it with something like this:
  volatile uint8_t x = 0;
  while(true) {
    x++;
I disagree - the observable effect is that you never reach the end of the function. It's not equivalent of not having it there in the first place, so no, it won't be optimized away.
Ahhhh .... sounds plausible, thanks.
to be fair, I think it still could because I think the implementation may assume that any thread will eventually terminate, make a call to a library I/O function, access or modify a volatile object, or perform a synchronization operation or an atomic operation. which we don't do there...
I think that I've explained that already.
Is the affinity subject to "Arduino runs on..."? Did not test that yet.
Just then it makes sense. Who says that the function for pinned tasks is available at all on single core machines?
[/quote]
First of all the optimizing compiler will find a variable that is not further used and will eliminate such "dead" code.
I came across such tricks in a workstation presentation, where a loop took 8 seconds on the fastest machine, 8 minutes on the next machine, and on the last machine I aborted the program after an hour. All timing only depending on the compiler settings.
In my example the task will crash the system anyway. Either it alarms the watchdog or it crashes on return. In addition a task with an empty loop will consume runtime and block other tasks. That's what I want to point out, several reasons for not writing tasks according to that pattern.
When "loopTask" is created for you in the background, it is pinned to the Core specified in "Arduino runs on...".
That depends on the task's priority.
Nope. Perhaps you don't know what "volatile" does?
@J-M-L and I decided to split the difference on this one and say it's difficult to predict the compiler's action and resultant code behavior.
Hmmm. As is, the compiler cannot distinguish tasks from ordinary functions and consequently can not hinder a task from returning. Else the compiler could insert a (hidden) vTaskDelete(NULL); at the end of the function, or the system could silently dump a returning task.
probably more to that with -O3
in the specific case where x is a local variable within a function and not used elsewhere in that function, the volatile keyword alone might not be sufficient to prevent the compiler from optimizing away the variable and so
  while(true) {
    x++;
is equivalent to
  while(true) {}
with GCC you could hack maybe something like this
  while (true) {
    x++;
    __asm__ __volatile__("" : : "r"(&x) : "memory");
I'll disagree on that one. The compiler has no way of knowing that the volatile variable isn't a memory-mapped I/O (for example). Reviewing the Herb Sutter video now (very end of Part 2). Seems Volatile variable accesses are "unoptimizable" ... although perhaps ordinary loads could be moved around them.
I think that I should have made clearer that I want to demonstrate what not to do, not a discussion on how to do bad things in a different way.
