These are the functions and pin-definitions of the Renesas HAL. If you want to use the 'standard' Arduino calls you probably need to create your own 'variant' of the R4 boards and add it to the boards.txt ( there are two already: MINIMA and UNOWIFIR4 ).
(...\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.0.5)
E.g. the mapping of Renesas-Pins to Arduino pins for the R4 Minima is done in ...\1.0.5\variants\MINIMA\variant.cpp::
extern "C" const PinMuxCfg_t g_pin_cfg[] = {
{ BSP_IO_PORT_03_PIN_01, P301 }, /* (0) D0 ------------------------- DIGITAL */
{ BSP_IO_PORT_03_PIN_02, P302 }, /* (1) D1 */
{ BSP_IO_PORT_01_PIN_05, P105 }, /* (2) D2 */
{ BSP_IO_PORT_01_PIN_04, P104 }, /* (3) D3~ */
{ BSP_IO_PORT_01_PIN_03, P103 }, /* (4) D4 */
{ BSP_IO_PORT_01_PIN_02, P102 }, /* (5) D5~ */
{ BSP_IO_PORT_01_PIN_06, P106 }, /* (6) D6~ */
{ BSP_IO_PORT_01_PIN_07, P107 }, /* (7) D7 */
{ BSP_IO_PORT_03_PIN_04, P304 }, /* (8) D8 */
{ BSP_IO_PORT_03_PIN_03, P303 }, /* (9) D9~ */
{ BSP_IO_PORT_01_PIN_12, P112 }, /* (10) D10~ */
{ BSP_IO_PORT_01_PIN_09, P109 }, /* (11) D11~ */
{ BSP_IO_PORT_01_PIN_10, P110 }, /* (12) D12 */
{ BSP_IO_PORT_01_PIN_11, P111 }, /* (13) D13 */
{ BSP_IO_PORT_00_PIN_14, P014 }, /* (14) A0 -------------------------- ANALOG */
{ BSP_IO_PORT_00_PIN_00, P000 }, /* (15) A1 */
{ BSP_IO_PORT_00_PIN_01, P001 }, /* (16) A2 */
{ BSP_IO_PORT_00_PIN_02, P002 }, /* (17) A3 */
{ BSP_IO_PORT_01_PIN_01, P101 }, /* (18) A4/SDA */
{ BSP_IO_PORT_01_PIN_00, P100 }, /* (19) A5/SCL */
{ BSP_IO_PORT_05_PIN_00, P500 }, /* (20) Analog voltage measure pin */
{ BSP_IO_PORT_00_PIN_12, P012 }, /* (21) TX LED */
{ BSP_IO_PORT_00_PIN_13, P013 }, /* (22) RX LED */
{ BSP_IO_PORT_05_PIN_01, P501 }, /* (23) TX on SWD connector */
{ BSP_IO_PORT_05_PIN_02, P502 }, /* (24) RX on SWD connector */
{ BSP_IO_PORT_01_PIN_08, P108 }, /* (25) SWDIO */
{ BSP_IO_PORT_03_PIN_00, P300 }, /* (26) SWCLK */
But there maybe more to do ...
[EDIT] The board you bought isn't a "clone", but a completely different board, only with the same processor. So it's a 'variant'
