I'm planning for the actual thing so the the ultrasonic sensor and the load cell to be far from the arduino nano at about 1 meter for the load cell amplifier and 2,5 meters for the ultrasonic sensors
the question what the effect of the distance on the strength of the signal , would it make it weaker so the readings from the sensor would be faulty, and in such case what the is the solution?
The actual distance is irrelevant. What is important is how long are the connecting wires and how are the routed, what other electrical devices are they near, and are the signal wires twisted with a ground wire.
@Paul_KD7HB
the wires are for both sensors are connected to the ground pin of the Arduino but not twisted with a dedicated ground wire. the proposed length for the 4 wires of the ultrasonic sensor about 2 .5 meters and for the load cell amplifier 4 about 4 meters,
and regarding environment it's full of all sorts of electronic and electrical devices .
