Here is the codes. I just changed LCD and DHT library.
Original transmitter codes;
#include "DHT.h"
#include <SPI.h>
#include "RF24.h"
#define DHTPIN 4
#define DHTTYPE DHT22
RF24 myRadio (7, 8);
byte addresses[][6] = {"0"};
const int led_pin = 13;
struct package
float temperature ;
float humidity ;
typedef struct package Package;
Package data;
DHT dht(DHTPIN, DHTTYPE);
pinMode(led_pin, OUTPUT);
dht.begin();
myRadio.begin();
myRadio.setChannel(115);
myRadio.setPALevel(RF24_PA_MAX);
myRadio.setDataRate( RF24_250KBPS ) ;
myRadio.openWritingPipe( addresses[0]);
digitalWrite(led_pin, HIGH); // Flash a light to show transmitting
readSensor();
Serial.println(data.humidity);
Serial.println(data.temperature);
myRadio.write(&data, sizeof(data));
digitalWrite(led_pin, LOW);
void readSensor()
data.humidity = dht.readHumidity();
data.temperature = dht.readTemperature();
Original Receiver codes;
//If your display does not work correctly, check the User_Setup.h file that comes with the display library
//Try to use HX8357B driver to see if that works
#include <TFT_HX8357_Due.h> // https://github.com/Bodmer/TFT_HX8357_Due
#include <Sodaq_DS3231.h> //RTC Library https://github.com/SodaqMoja/Sodaq_DS3231
#include "DHT.h" //https://github.com/adafruit/DHT-sensor-library
#include "RF24.h" //https://github.com/TMRh20/RF24
#define DHTPIN 8
RF24 myRadio (6, 7);
TFT_HX8357_Due tft = TFT_HX8357_Due(); // Invoke custom library
float remoteHumidity = 0.0;
float remoteTemperature = 0.0;
String dateString;
String hours;
int minuteNow=0;
int minutePrevious=0;
struct package
float temperature ;
float humidity ;
float previousIndoorHumidity = 0;
float previousIndoorTemperature = 10;
float previousRemoteHumidity = 0.1;
float previousRemoteTemperature = 0.1;
float indoorHumidity = 0;
float indoorTemperature = 0;
Package data;
tft.init();
tft.setRotation(1);
tft.fillScreen(TFT_BLACK);
delay(100);
rtc.begin();
dht.begin();
delay(2000);
//setRTCTime();
startWirelessCommunication();
printUI();
checkForWirelessData();
getAndPrintTime();
printIndoorTemperature();
printIndoorHumidity();
printRemoteTemperature();
printRemoteHumidity();
void setRTCTime()
DateTime dt(2016, 6, 7, 13, 40, 30, 2); // Year, Month, Day, Hour, Minutes, Seconds, Day of Week
rtc.setDateTime(dt); //Adjust date-time as defined 'dt' above
void startWirelessCommunication()
myRadio.begin();
myRadio.openReadingPipe(1, addresses[0]);
myRadio.startListening();
delay(100);
void checkForWirelessData()
if ( myRadio.available())
while (myRadio.available())
myRadio.read( &data, sizeof(data) );
previousRemoteTemperature = remoteTemperature;
previousRemoteHumidity = remoteHumidity;
remoteTemperature = data.temperature;
remoteHumidity = data.humidity;
Serial.print("\nPackage:");
Serial.print("\n");
void printUI()
tft.drawRoundRect(5,5,470,71,5,TFT_WHITE);
tft.drawRoundRect(6,6,470,71,5,TFT_WHITE);
tft.drawRoundRect(5,90,220,225,5,TFT_WHITE);
tft.drawRoundRect(6,91,220,225,5,TFT_WHITE);
tft.drawRoundRect(250,90,220,225,5,TFT_WHITE);
tft.drawRoundRect(251,91,220,225,5,TFT_WHITE);
tft.fillRect(26,90,180,40,TFT_GREEN);
tft.fillRect(270,90,180,40,TFT_CYAN);
tft.setCursor(62,100);
tft.setTextColor(TFT_BLACK);
tft.setTextSize(3);
tft.print("REMOTE");
tft.setCursor(312,100);
tft.setTextSize(3);
tft.print("INDOOR");
tft.setCursor(162,165);
tft.setTextColor(TFT_GREEN);
tft.setTextSize(6);
tft.print("%");
tft.setCursor(412,165);
tft.setTextColor(TFT_CYAN);
tft.setTextSize(6);
tft.print("%");
tft.setCursor(162,230);
tft.setTextSize(6);
tft.print("C");
tft.setCursor(145,230);
tft.setTextSize(2);
tft.print("o");
tft.setCursor(412,230);
tft.setTextSize(6);
tft.print("C");
tft.setCursor(395,230);
tft.setTextSize(2);
tft.print("o");
void getAndPrintTime()
delay(100);
DateTime now = rtc.now(); //get the current date-time
minuteNow = now.minute();
if(minuteNow!=minutePrevious)
readSensor();
dateString = getDayOfWeek(now.dayOfWeek())+" ";
dateString = dateString+String(now.date())+"/"+String(now.month());
dateString= dateString+"/"+ String(now.year());
minutePrevious = minuteNow;
hours = String(now.hour());
if(now.minute()<10)
hours = hours+":0"+String(now.minute());
}else
hours = hours+":"+String(now.minute());
printTime();
void printTime()
String dateAndTime = dateString+" "+hours;
tft.setTextSize(2);
char charBuf[25];
dateAndTime.toCharArray(charBuf, 25);
tft.setTextColor(TFT_WHITE, TFT_BLACK);
tft.drawCentreString(charBuf,240,25,2);
String getDayOfWeek(int i)
switch(i)
case 1: return "Monday";break;
case 2: return "Tuesday";break;
case 3: return "Wednesday";break;
case 4: return "Thursday";break;
case 5: return "Friday";break;
case 6: return "Saturday";break;
case 7: return "Sunday";break;
default: return "Monday";break;
void readSensor()
previousIndoorTemperature = indoorTemperature;
previousIndoorHumidity = indoorHumidity;
indoorHumidity = dht.readHumidity();
indoorTemperature = dht.readTemperature();
Serial.println(indoorTemperature);
Serial.println(indoorHumidity);
void printIndoorTemperature()
if(indoorTemperature != previousIndoorTemperature)
String temperature = String(indoorTemperature,1);
tft.fillRect(270,232,120,40,TFT_BLACK);
tft.setCursor(270,234);
tft.setTextSize(5);
tft.print(temperature);
void printRemoteHumidity()
String humidity;
if(remoteHumidity != previousRemoteHumidity)
if(remoteHumidity == 0.0 && remoteTemperature == 0.0) //We just booted up
humidity = "---";
}else
humidity = String(remoteHumidity,1);
tft.fillRect(20,167,120,40,TFT_BLACK);
tft.setCursor(20,167);
tft.setTextSize(5);
tft.print(humidity);
void printRemoteTemperature()
String temperature;
if(remoteTemperature != previousRemoteTemperature)
temperature = "---";
}else
temperature = String(remoteTemperature,1);
tft.fillRect(20,232,120,40,TFT_BLACK);
tft.setCursor(20,234);
tft.setTextSize(5);
void printIndoorHumidity()
if(indoorHumidity != previousIndoorHumidity)
String humidity = String(indoorHumidity,1);
tft.fillRect(270,167,120,40,TFT_BLACK);
tft.setCursor(270,167);
tft.setTextSize(5);
