WEB radio on ESP32-S3-WROOM-1 no sound or just a buzzer
I’m trying to build a web radio basic schematic, from internet.
ESP32-S3 board and MAX98357.
I see the board connected to Internet on my firewall.
The URL connected to works perfect on my computer.
I tried different GPIO settings. Either I have sound like a buzzer or silence.
Serial monitor shows:
10.200.200.4
Total PSRAM: 8388608
Here is the sketch:
```cpp
#include <Arduino.h>
#include <WiFi.h>
#include <Audio.h>
#define I2S_DOUT     4
#define I2S_BCLK      5
#define I2S_LRC        14
Audio audio;
String ssid =    "P";
String password = "s";
  WiFi.disconnect();
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid.c_str(), password.c_str());
  while (WiFi.status() != WL_CONNECTED)
  delay(1500);
  Serial.printf("Total PSRAM: %d\n", ESP.getPsramSize());
  audio.setPinout(I2S_BCLK, I2S_LRC, I2S_DOUT);
  audio.setVolume(100);
  //audio.connecttohost("https://playerservices.streamtheworld.com/api/livestream-redirect/CJFMFM.mp3");
  audio.connecttohost("http://vis.media-ice.musicradio.com/CapitalMP3");
  Serial.println("Music now");
  audio.loop();
Please post mandatory schematics for a project like this. Know that we know only what You show us.
@Railroader Above is the basic diagram
Thanks. Looks rather okey.
From where does “5 volt” come?
@Railroader
Playing with the different GPIO settings I got working. I also added Internet connection OnDemand, based on Tzapu library. Next step to add a rotary switch to change the sations.
Help will always be appreciated.
Here is the current working sketch:
```cpp
//#include <WiFi.h>
#include <WiFiManager.h> // https://github.com/tzapu/WiFiManager
#include <Audio.h>
#define I2S_DOUT     12
#define I2S_BCLK      13
#define I2S_LRC        14
// select which pin will trigger the configuration portal when set to LOW
#define TRIGGER_PIN 46
int timeout = 120; // seconds to run for
Audio audio;
//String ssid =    "P";
//String password = "s";
  //WiFi.disconnect();
  //WiFi.mode(WIFI_STA);
  //WiFi.begin(ssid.c_str(), password.c_str());
  //while (WiFi.status() != WL_CONNECTED)
  pinMode(TRIGGER_PIN, INPUT_PULLUP);
while (digitalRead(TRIGGER_PIN) == HIGH) {
  Serial.println("\n Waiting for button");
  delay(1500);
   WiFiManager wm;
    //reset settings - for testing
    wm.resetSettings();
    // set configportal timeout
    wm.setConfigPortalTimeout(timeout);
    if (!wm.startConfigPortal("OnDemandAP")) {
      Serial.println("failed to connect and hit timeout");
      //delay(3000);
      //reset and try again, or maybe put it to deep sleep
      ESP.restart();
      //delay(5000);
  delay(1500);
  //audio.connecttohost("http://vis.media-ice.musicradio.com/CapitalMP3");
  audio.loop();
No. It comes from out ouf the sky.
So no remaining question, no more help needed?
Anyone can help implementing KY-040 360 Degrees Rotary Encoder, please?
@Railroader
I asked for more help, nobody answered.
Please post a link to the datasheet of the exact decider You've got.
@Railroader
Can you, please, elaborate?
Sorry. The bastard AI changed the message.
Please post a link to the datasheet of the exact encoder You've got.
@Railroader
Datasheet please.
@Railroader
Make a test code for the encoder and make it work. Start by using the example in the datasheet.
Then is the question how You want the encoder to affect the build.
@Railroader
Thanks, I will work on it, and I will let you know.
Please do. Know that there will be a need for a sum up for both code and wiring to give a clear overview.
@Railroader
I’ll do my best.
I’m trying to built a web radio. My first radio that I built, was a Galena!!! Now you know my age.
