I am using code from a post (Home Automation) as modified by "briankTHISISIT" that works as it is suppose to unless I change the 'Serial.println("Activate Button");' to anything else in the double quotes. This makes no sense to me as it is just a print to the serial port ans I can't see how it would make the code drop through the code and not execute properly. The code seems to run but not properly after any change to the print "text".
Any thoughts?
If I blank the print statements out as shown in the code it works and also if I put the code back exactly with the same "text' [Serial.println("Activate Button");] it work too.
I am new with Arduino and the Ethernet Shield but this seems very odd to me.
THX Russell
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0x12, 0x15, 0x57, 0xFF, 0xAA, 0x07 };
IPAddress ip(169,254,86,101);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
String readString = String(100); //string for fetching data from address
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
// start the Ethernet connection and the server:
Serial.println("Initiaizing ethernet...");
// this uses a fixed address
Ethernet.begin(mac, ip);
// get an address with DHCP
//if (Ethernet.begin(mac) == 0)
// Serial.println("Failed to configure Ethernet using DHCP");
// give the card a second to initialize
server.begin();
Serial.print("Garage Door Opener Control Ready at IP address ");
Serial.println(Ethernet.localIP());
// command received (one character) '1' - activate garage door button
char cmd = 0; // 1 - pulse button
boolean done = false; // set to indicate that response is complete
// listen for incoming clients
if (client) {
Serial.println("new client");
readString = "";
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
//int i = c;
//Serial.print("(");
//Serial.print(i);
//Serial.print(")");
// store character received in receive string
if (readString.length() < 100) {
readString += (c);
// check for end of line
if (c == '\n') {
//Serial.print("Receved line: ");
//Serial.print(readString);
// process line if its the "GET" request
// a request looks like "GET /?1" or "GET /?2"
if (readString.indexOf("GET") != -1) {
if (readString.indexOf("?1") != -1)
cmd = '1';
// check for other commands here. ie turn on light, etc.
if (readString.indexOf("?2") != -1)
cmd = '2';
if (readString.indexOf("?3") != -1)
cmd = '3';
if (readString.indexOf("?4") != -1)
cmd = '4';
if (readString.indexOf("?5") != -1)
cmd = '5';
if (readString.indexOf("?6") != -1)
cmd = '6';
if (readString.indexOf("?7") != -1)
cmd = '7';
if (readString.indexOf("?8") != -1)
cmd = '8';
// if a blank line was received (just cr lf, length of 2), then its the end of the request
if (readString.length() == 2) {
if (cmd == '1'){
//Serial.println("1 On");
digitalWrite(5, HIGH);
if (cmd == '2'){
//Serial.println("1 Off");
digitalWrite(5, LOW);
if (cmd == '3'){
// Serial.println("2 On");
digitalWrite(6, HIGH);
if (cmd == '4'){
// Serial.println("Activate Button");
digitalWrite(6, LOW);
if (cmd == '5'){
digitalWrite(7, HIGH);
if (cmd == '6'){
digitalWrite(7, LOW);
if (cmd == '7'){
// Serial.println("4 On");
digitalWrite(8, HIGH);
if (cmd == '8'){
Serial.println("4 Off");
digitalWrite(8, LOW);
// add other commands here
// send web page back to client
Serial.println("sending web page");
SendWebPage(client);
Serial.println("web page sent");
cmd = 0;
// break out and disconnect. This will tell the browser the request is complete without having to specify content-length
} // end of request reached
// start line over
readString = "";
} // end of line reached
} // end data is available from client
} // end cient is connected
// give the web browser time to receive the data
Serial.println("delay before disconnect");
delay(100);
// close the connection:
client.stop();
Serial.println("client disonnected");
} // end client has been created
// send web page
void SendWebPage(EthernetClient client)
client.println("Content-Type: text/html");
// to specify the length, wooul have to construct the entire string and then get its length
//client.println("Content-Length: 1234");
client.println("Connnection: close");
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html>");
client.println("<head>");
client.println("<title>Home Automation Control</title>");
client.println("<style type='text/css'>");
client.println(".label {font-size: 30px; text-align:center;}");
client.println("button {width: 160px; height: 70px; font-size: 30px; -webkit-appearance: none; background-color:#1fe3ee; }");
client.println("</style>");
client.println("<script type='text/javascript'>");
client.println("function OnButtonClicked(parm) { window.location.href=\"X?\" + parm; }");
client.println("</script>");
client.println("</head>");
client.println("<body style=\"background-color:#3b5998\">");
client.println("<div class=\"label\">");
client.println("Home Garage Control
// future idea: could read a limit switch on the garage door here and tell the user if the door is currently open or closed
if (digitalRead(DOOR_OPEN_INPUT) == HIGH)
client.println("Door is Open");
client.println("Door is Closed");
client.println("
// door open / close button
if (digitalRead(5)==LOW){
client.println("<button onclick=\"OnButtonClicked('1');\">1 ON</button>
if (digitalRead(5)==HIGH){
client.println("<button onclick=\"OnButtonClicked('2');\">1 Off</button>
if (digitalRead(6)==LOW){
client.println("<button onclick=\"OnButtonClicked('3');\">2 ON</button>
if (digitalRead(6)==HIGH){
client.println("<button onclick=\"OnButtonClicked('4');\">2 Off</button>
if (digitalRead(7)==LOW){
client.println("<button onclick=\"OnButtonClicked('5');\">3 ON</button>
if (digitalRead(7)==HIGH){
client.println("<button onclick=\"OnButtonClicked('6');\">3 Off</button>
if (digitalRead(8)==LOW)
client.println("<button onclick=\"OnButtonClicked('7');\">4 ON</button>
if (digitalRead(8)==HIGH){
client.println("<button onclick=\"OnButtonClicked('8');\">4 Off</button>
// add more buttons here
// button separator
client.println("</div>");
client.println("</body>");
client.println("</html>");
client.println("");
