Web Server Error?
So this is the code that I started with (it was working):
#include <ESP8266WiFi.h>
const char* ssid = "my ssid here";
const char* password = "my pass here";
int ledPin = 13; // GPIO13
WiFiServer server(80);
  delay(10);
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, LOW);
  // Connect to WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  // Start the server
  server.begin();
  Serial.println("Server started");
  // Print the IP address
  Serial.print("Use this URL to connect: ");
  Serial.print("http://");
  Serial.print(WiFi.localIP());
  Serial.println("/");
  // Check if a client has connected
  WiFiClient client = server.available();
  if (!client) {
    return;
  // Wait until the client sends some data
  Serial.println("new client");
  while(!client.available()){
    delay(1);
  // Read the first line of the request
  String request = client.readStringUntil('\r');
  Serial.println(request);
  client.flush();
  // Match the request
  int value = LOW;
  if (request.indexOf("/LED=ON") != -1)  {
    digitalWrite(ledPin, HIGH);
    value = HIGH;
  if (request.indexOf("/LED=OFF") != -1)  {
    value = LOW;
// Set ledPin according to the request
//digitalWrite(ledPin, value);
  // Return the response
  client.println("Content-Type: text/html");
  client.println(""); //  do not forget this one
  client.println("<!DOCTYPE HTML>");
  client.println("<html>");
  client.print("Led pin is now: ");
  if(value == HIGH) {
    client.print("On");
    client.print("Off");
  client.println("
  client.println("<a href=\"/LED=ON\"\"><button>Turn On </button></a>");
  client.println("<a href=\"/LED=OFF\"\"><button>Turn Off </button></a>
  client.println("</html>");
  delay(1);
  Serial.println("Client disonnected");
  Serial.println("");
And now, with this code I get these errors:
const char* ssid = "Edimax35";
const char* password = "davidnet2003";
int ledVerde = 13; // GPIO13
int ledRosu = 12; //GPIO12
int ledAlbastru = 14; //GPIO14
  delay(10);
  pinMode(ledVerde, OUTPUT);
  digitalWrite(ledVerde, LOW);
  pinMode(ledRosu, OUTPUT);
  digitalWrite(ledRosu, LOW);
  pinMode(ledAlbastru, OUTPUT);
  digitalWrite(ledAlbastru, LOW);
    Serial.print(".");
  Serial.println("");
  // Start the server
  server.begin();
  if (!client) {
    return;
    delay(1);
  client.flush();
  int value = LOW;
    digitalWrite(ledVerde, HIGH);
    value = HIGH;
    value = LOW;
 int value2 = LOW;
  if (request.indexOf("/LED2=ON") != -1)  {
    digitalWrite(ledRosu, HIGH);
    value2 = HIGH;
  if (request.indexOf("/LED2=OFF") != -1)  {
    value2 = LOW;
 int value3 = LOW;
  if (request.indexOf("/LED3=ON") != -1)  {
    digitalWrite(ledAlbastru, HIGH);
    value3 = HIGH;
  if (request.indexOf("/LED3=OFF") != -1)  {
    value3 = LOW;
//ledVerde
  client.print("ledVerde is now: ");
  if(value == HIGH) {
    client.print("On");
  client.println("
  client.println("<a href=\"/LED=ON\"\"><button>Turn On ledVerde</button></a>");
  client.println("<a href=\"/LED=OFF\"\"><button>Turn Off ledVerde</button></a>
  client.print("ledRosu is now: ");
//ledRosu
  if(value2 == HIGH) {
    client.print("On");
  client.println("
  client.println("<a href=\"/LED2=ON\"\"><button>Turn On ledRosu</button></a>");
  client.println("<a href=\"/LED2=OFF\"\"><button>Turn Off ledRosu</button></a>
  delay(1);
  Serial.println("");
//ledAlbastru
client.print("ledAlbastru is now: ");
  if(value3 == HIGH) {
    client.print("On");
  client.println("
  client.println("<a href=\"/LED3=ON\"\"><button>Turn On ledAlbastruu</button></a>");
  client.println("<a href=\"/LED3=OFF\"\"><button>Turn Off ledAlbastru</button></a>
  delay(1);
  Serial.println("");
Web_Server_Led2:143: error: 'client' does not name a type
Web_Server_Led2:145: error: expected unqualified-id before 'if'
Web_Server_Led2:147: error: expected unqualified-id before 'else'
Web_Server_Led2:150: error: 'client' does not name a type
client.println("
Web_Server_Led2:151: error: 'client' does not name a type
client.println("<a href="/LED3=ON"">Turn On ledAlbastruu");
Web_Server_Led2:152: error: 'client' does not name a type
client.println("<a href="/LED3=OFF"">Turn Off ledAlbastru
Web_Server_Led2:153: error: 'client' does not name a type
client.println("");
Web_Server_Led2:155: error: expected constructor, destructor, or type conversion before '(' token
delay(1);
Web_Server_Led2:156: error: 'Serial' does not name a type
Web_Server_Led2:157: error: 'Serial' does not name a type
Serial.println("");
Thanks for your attention and have a nice day!
Just above where the first error there is a closing brace which ends the loop function. All subsequent issues are caused by that.
