This is early work so it is not really usable, but it may help show the idea. To be extra clear I have not used WSGI so this is new to me.
The Python code old code see GitHub
#!/usr/bin/env python3
# Web Server Gateway Interface (WSGI) daemon
# use to serve request on a TCP/IP PORT for serial devices that use simple commands
# at CLI run with
# python3 WSGIdaemon.py
# killing it is a PITA, I just close the terminal, yep that needs some work.
# to try it open a brower with url: http://localhost:8000/?addr=0&cmd=id&q=true
# For info on WSGI see https://docs.python.org/3.7/library/wsgiref.html
# For info on CGI see https://docs.python.org/3.7/library/cgi.html
# The goal is to hold a seril link open while a web server runs pages, e.g. use the WSGI daemon to access the serial link.
# it takes commands from the CGI query string and turns them into the format I am using e.g. "/0/id?" or "/0/adc 3,4,5"
# I am using python3 so make sure the serial package is installed.
# sudo apt-get install python3-serial
import json
import serial
from time import sleep
from wsgiref.simple_server import make_server
from cgi import parse_qs, escape
# claim the serial link (e.g. it is a resourse that I will provide use of)
# hardwar serial on R-Pi is/dev/ttyAMA0
# FTDI and some other usb serial is /dev/ttyUSB0
# Arduino's ATmega16u2 is a modem... what? /dev/ttyACM0
device = "/dev/ttyUSB0"
sio = serial.Serial(device,38400, timeout=3)
print("claim serial link " + device + "\n")
# TBD only run one WSGI server with one thread
# A relatively simple WSGI application.
def simple_app(environ, start_response):
# Returns a dictionary from CGI in which the values are lists, it is the easy way
query_string = parse_qs(environ['QUERY_STRING'])
#given URL: http://localhost:8000/?addr=0&cmd=id&q=true
#the QUERY_STRING is: addr=0&cmd=id&q=true
addr = query_string.get('addr', [''])[0] # Returns the first addr value
cmd_base = query_string.get('cmd', [''])[0] # Returns the first cmd value
q = query_string.get('q', [''])[0] # Returns the first q value
# TBD thre are arguments to add, but this is a start
status = '200 OK'
headers = [('Content-type', 'text/plain; charset=utf-8')]
start_response(status, headers)
#check for correctness of command
if (addr == ''):
addr = '0' # for default of /0/id?
if ( (addr < '0') or (addr > '9') ):
ret = [ ("ERR: addr must be in the range 0..9\n").encode('utf-8') +
(b"ERR: bad query_string \"addr=" + addr.encode('utf-8') + b"\"\n").decode().encode('utf-8') ]
return ret
if (cmd_base == ''):
cmd_base = "id" # default
if ( not (cmd_base.isalpha()) ):
ret = [ ("ERR: cmd must be a string that isalpha\n").encode('utf-8') +
(b"ERR: bad query_string \"cmd=" + cmd_base.encode('utf-8') + b"\"\n").decode().encode('utf-8') ]
return ret
if (q == ''):
q = 'true' # default needs a ? after the cmd_base
if ( not ( (q == 'true') or (q == 'false')) ):
ret = [ ("ERR: q must be true or false\n").encode('utf-8') +
(b"ERR: bad query_string \"q=" + q.encode('utf-8') + b"\"\n").decode().encode('utf-8') ]
return ret
# note: if the command will not encode with ascii then use bytes e.g.
# command = b"/"+bytes([192])+b"/id?"
if (q == "true"):
command = "/"+addr+"/"+cmd_base+"?\n"
else:
command = "/"+addr+"/"+cmd_base+"\n"
sio.write(command.encode('utf-8')) # "/0/id?" is like the command I want to send on the serial link
sio_echo_cmd = sio.readline().strip() # my serial device echo's the command
sio_echo = sio.readline().strip() # and then outpus the JSON
# format as bytestring suitable for transmission as HTTP response headers
ret = [ (sio_echo_cmd + b"\n").decode().encode('utf-8') +
(sio_echo + b"\n").decode().encode('utf-8') ]
return ret
with make_server('', 8000, simple_app) as httpd:
print("Serving on port 8000...")
httpd.serve_forever()
The idea is to have the daemon make a command for the serial link, the commands I use resemble "/0/id?". The second character is an address on the serial bus (it is a multi-drop), the command is "id", and the "?" means it is a query (but everything has an echo and returns JSON so it's just adding overhead)
If I do end up using this I will likely keep the updates at
