web server 'hangs' when page size increases.
Hi all
I see a strange behavior when i use the arduino as a webserver.
I have code that generates a form with some option bullets and a submit button.
While the page loads with two bullets, it will not load with four bullets.
I m using a module with the enc28j60 ethernet controller ant the UIP lib for it.
I m not that expierienced in coding and I m out of clue's.
See below the code:
#include <WString.h>
#include <UIPEthernet.h>
#include <avr/wdt.h>
#define MaxHeaderLength 32    //maximum length of http header required
int     gr        = 17;
int     rd        = 16;
int     dummy_inA = 18;
int     dummy_inB = 19;
int     ping      = 2;
int     CharPos[] = {0,0,0,0};
int     Relais[]  = {0,0,0,0};
String           HttpHeader = String(MaxHeaderLength);
EthernetServer   server     = EthernetServer(1000);
void setup(){
  wdt_disable();
  wdt_enable(WDTO_1S);
  pinMode(dummy_inA, INPUT);
  pinMode(dummy_inB, INPUT);
  pinMode(gr, OUTPUT);
  pinMode(rd, OUTPUT);
  digitalWrite(gr, HIGH);
  digitalWrite(rd, LOW);
  uint8_t mac[6] = {0x00,0x01,0x02,0x03,0x04,0x05};
  IPAddress myIP(192,168,1,15);
  Ethernet.begin(mac,myIP);
  server.begin();
void loop(){
   // Create a client connection
   if (client) {
     while (client.connected()) {
       if (client.available()) {
         char c = client.read();
          //store characters to string
          HttpHeader = HttpHeader + c;
          //if HTTP request has ended
          if (c == '\n') {
            // start of web page
            delay(ping); client.println("<!DOCTYPE html>");
            delay(ping); client.println("<html>");
            delay(ping); client.println("<body>");
            delay(ping); client.println("Light control system
            delay(ping); client.println("<form method='get'>");
            delay(ping); client.println("1 : ");
            delay(ping); client.println("<input type='radio' name=v value='1'> AAN");
            delay(ping); client.println("<input type='radio' name=v value='0'> UIT
            delay(ping); client.println("2 : ");
            delay(ping); client.println("<input type='radio' name=w value='1'> AAN");
            delay(ping); client.println("<input type='radio' name=w value='0'> UIT
            //delay(ping); client.println("3 : ");
            //delay(ping); client.println("<input type='radio' name=x value='1'> AAN");
            //delay(ping); client.println("<input type='radio' name=x value='0'> UIT
            //delay(ping); client.println("4 : ");
            //delay(ping); client.println("<input type='radio' name=y value='1'> AAN");
            //delay(ping); client.println("<input type='radio' name=y value='0'> UIT
            delay(ping); client.println("<input type='submit' value='submit'></form>");
            delay(ping); client.println("</body>");
            delay(ping); client.println("</html>");
            //stopping client
            delay(4);
            client.stop();
            delay(4);
     CharPos[0] = HttpHeader.indexOf('v');
     CharPos[1] = HttpHeader.indexOf('w');
     CharPos[2] = HttpHeader.indexOf('x');
     CharPos[3] = HttpHeader.indexOf('y');
      //clearing string for next read
      HttpHeader="";
      // reset the watchdog
      wdt_reset();
You may be short of RAM. Try using the F macro on your web page strings to leave them in progmem, like this:
client.println(F("<!DOCTYPE html>"));
Thank you WildBill
I ve tried it and it seems to be OK now.
So I've noticed that the flash footprint of the design got bigger.
Suppose I ran out of flash , can I combine
client.println(F(""));
and
client.println("");
at random in the code,
or is this a bad idea (and why ?)
wildbill:
So I this normal ?
The device file does not inform the compiler about the available memory ?
