WebSite request on esp8266
Hello,
I wanted to make a program that connects on the internet and opens some URLs. Those URLs are connected with webhooks and turns on or off some Sonoffs in my room. The thing is that I tried so many different ways to make it worked but it didn't. I thought that if I use an already made program that connects on a website and takes the webpage HTML source, but the programs I can find, uses this command to connect: "client.connect(host, 80)" and it means that the code connects with a port "80" and it doesn't work.
I want a program to connect on a direct website without the use of any port.
Thanks in advance for any kind of response!!
Is port 80 not the standard HTTP port ?
UKHeliBob:
Sorry, I didn't understand you.
But here is the full codes I tried to use (I removed my link from the code because maybe someone use it and turn my sonoffs on and off anytime he wants and I also removed the wifi password)
#include <ESP8266WiFi.h>
const char* ssid = "wifiname";
const char* password = "wifipass";
const char* host = "google.com";
  Serial.printf("Connecting to %s ", ssid);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
  Serial.println(" connected");
  WiFiClient client;
  Serial.printf("\n[Connecting to %s ... ", host);
  if (client.connect(host, 80))
    Serial.println("connected]");
    Serial.println("[Sending a request]");
    client.print(String("GET /") + " HTTP/1.1\r\n" +
                 "Host: " + host + "\r\n" +
                 "Connection: close\r\n" +
                 "\r\n"
    Serial.println("[Response:]");
    while (client.connected() || client.available())
      if (client.available())
        String line = client.readStringUntil('\n');
        Serial.println(line);
    client.stop();
    Serial.println("\n[Disconnected]");
    Serial.println("connection failed!]");
    client.stop();
  delay(5000);
or this:
    This sketch establishes a TCP connection to a "quote of the day" service.
    It sends a "hello" message, and then prints received data.
#ifndef STASSID
#define STASSID "wifiname"
#define STAPSK  "wifipass"
#endif
const char* ssid     = STASSID;
const char* password = STAPSK;
const uint16_t port = 17;
  // We start by connecting to a WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  /* Explicitly set the ESP8266 to be a WiFi-client, otherwise, it by default,
     would try to act as both a client and an access-point and could cause
     network-issues with your other WiFi-devices on your WiFi-network. */
  WiFi.mode(WIFI_STA);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  Serial.print("connecting to ");
  Serial.print(host);
  Serial.print(':');
  Serial.println(port);
  // Use WiFiClient class to create TCP connections
  WiFiClient client;
  if (!client.connect(host, port)) {
    Serial.println("connection failed");
    delay(5000);
    return;
  // This will send a string to the server
  Serial.println("sending data to server");
  if (client.connected()) {
    client.println("hello from ESP8266");
  // wait for data to be available
  unsigned long timeout = millis();
  while (client.available() == 0) {
    if (millis() - timeout > 5000) {
      Serial.println(">>> Client Timeout !");
      client.stop();
      delay(60000);
      return;
  // Read all the lines of the reply from server and print them to Serial
  Serial.println("receiving from remote server");
  // not testing 'client.connected()' since we do not need to send data here
  while (client.available()) {
    char ch = static_cast<char>(client.read());
    Serial.print(ch);
  // Close the connection
  Serial.println("closing connection");
  client.stop();
  delay(300000); // execute once every 5 minutes, don't flood remote service
a "client" connects to a device (e.g. PC) based on the IP address (or mac) and specifies a port to connect to a specific application on the device. A device can support 10000s of different types of applications
the standard port # for a web server is 80.
Port 80 is the standard one used by HTTP but you would not normally be aware of that
That is not possible
What port do the webhooks use ?
gcjr:
I didn't know that!
Thanks.
So Im not searching for a client example to use!
UKHeliBob:
I don't know but If I don't find any solution, I will make an Arduino Program and I will connect a lamp on my sonoff and make the Arduino try ALL the different ports and with a light sensor check if the lamp is off or not and it will save the port on an sd. So I will let the Arduino working for a night and the next morning probably I will have the webhooks port.
I found the solution:
It works fine, the port was 80 but you must determine correctly the request details
const char* host = "maker.ifttt.com";
    Serial.print(".");
  WiFiClient client;
    client.println("GET /trigger/(appletnamehere)/with/key/(personalkeyhere) HTTP/1.1");
    client.println("Host: maker.ifttt.com");
    client.println("Connection: close");
    client.println();
    client.stop();
    client.stop();
  delay(5000);
