Hii, this is my first Arduino project and I am trying to make an IR remote controlled car.
I have the following problem: the motors run fine when I upload a sketch to turn them on or off directly, but when I upload a sketch with the IR control code only one motor responds.
Trying to determine the cause of this behavior I found the following: In the full code below the motors are controlled directly (both to turn on when the sketch is uploaded) and they work fine. But when I add this line ir_receiver.enableIRIn(); // Start the receiver
Then again only the right motor turns on and the left doesn't respond.
Why is this strange behavior when I add this line of code?? any help is appreciated.
#include <IRremote.h>
const unsigned int IR_RECEIVER_PIN = 2;
IRrecv ir_receiver(IR_RECEIVER_PIN);
decode_results results;
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);//analog control of Motor A
pinMode(3, OUTPUT);//analog control of Motor B
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
void loop(){
digitalWrite(7, HIGH);
digitalWrite(8,LOW);
analogWrite(9,180);
digitalWrite(6, HIGH);
digitalWrite(5,LOW);
analogWrite(3,180);
