I have been trying to get the DS1302 (Data Sheet) to work with the arduino, but I kept getting weird results when getting and setting time with the device. To identify the problem, I wrote up a sketch to write a number to the RTC's RAM, then read that value back. It worked for a few values, then I started to get discrepancies between what I was trying to write and what was being read back. Here's the code, and the Serial print is attached as a csv if you want to view that. Sorry about the crazy comments; it was my way of diagnosing the issue by breaking everything down for myself.
//DEFINE PINS
//IO enable line
#define CE 2
//IO line; both recieve and transmit for data
#define IO 3
//Clock line
#define SCLK 4void setup(){
//setup the pinmodes and serial
pinMode(SCLK, OUTPUT);
pinMode(CE, OUTPUT);//Set the write enable bit to zero (enable)
digitalWrite(CE,HIGH);
out((byte)0x8E);
out((byte)0);
digitalWrite(CE,LOW);
}// A counter value used to test RAM IO
int counter = 0;void loop(){
delay(100);
//Tell Arduino to write the counter value to the first register in RAM
//Enable the IO line
//Tell Arduino which register to write to
out((byte)0xC0);
//Tell Arduino what to write
out((byte)counter);
//Disable the IO line
digitalWrite(CE,LOW);delay(100);
//Tell Arduino to read the value of the first register in RAM
//Tell Arduino which register to read from
out((byte)0xC1);
//Read the RAM output
byte input = in();
//Print out the value recieved from RAM on a new line
Serial.println(input);delay(100);
//Increment the counter
counter++;delay(100);
}//Wtite a byte to the RTC, set CE first
void out(byte data){for(int i=0;i<8;i++){
pinMode(IO,OUTPUT);
//Write the i^th bit of the data byte to the IO line
digitalWrite(IO,bitRead(data,i));
delayMicroseconds(1);
//Pulse the clock
digitalWrite(SCLK, HIGH);
digitalWrite(SCLK, LOW);
}//read the value output by the RTC
byte in(){
//The value to return
int value=0;for(int i=0;i<8;i++){
pinMode(IO,INPUT);
//Store the value obtained by reading the IO line
int temp = (int)digitalRead(IO);
//Pulse the clock
digitalWrite(SCLK,HIGH);
digitalWrite(SCLK,LOW);
//Binary to decimal conversion by multiplying 2^i by the IO value
value += temp*(int)pow(2.0, (float)i);
return (byte)value;
What am I doing wrong? I'm almost certain that it's a code issue because I'm not very familiar with C/C++.
data.txt (4.2 KB)
