Hi, I'm new to Arduino, and I'm programming with a couple of friends the Elegoo car kit v4. Right now I'm trying to understand how to use a websocket server on the ESP32 that comes with the kit, and to do so I'm studying the code that Elegoo gives, but there are tree things I cannot wrap my head around.
The first are heartbeat: what do I need the for and what are they? I tried looking around in the forum and on google but I found nothing.
The second is, what does the data_begin flag does?
The third and last is: what are WA_en and ED_client?
I hope I chose the right category, in case sorry, like I said I'm new, and I tried to choose the category that seemed the best fit for the question.
Here's the code
void SocketServer_Test(void)
static bool ED_client = true;
WiFiClient client = server.available(); //尝试建立客户对象
if (client) //如果当前客户可用
WA_en = true;
ED_client = true;
Serial.println("[Client connected]");
String readBuff;
String sendBuff;
uint8_t Heartbeat_count = 0;
bool Heartbeat_status = false;
bool data_begin = true;
while (client.connected()) //如果客户端处于连接状态
if (client.available()) //如果有可读数据
char c = client.read(); //Read 1 byte
Serial.print(c); //Print it
if (true == data_begin && c == '{') // '{' is the initial char for the message
data_begin = false;
if (false == data_begin && c != ' ') //去掉空格
readBuff += c;
if (false == data_begin && c == '}') // '}' is the final char of the message
data_begin = true;
if (true == readBuff.equals("{Heartbeat}"))
Heartbeat_status = true;
Serial2.print(readBuff);
//Serial2.print(readBuff);
readBuff = "";
// Serial2 seems to be the Arduino on the car: if it's available the data it's sending gets sent to the client (?)
if (Serial2.available())
char c = Serial2.read();
sendBuff += c;
if (c == '}') //接收到结束字符
client.print(sendBuff);
Serial.print(sendBuff); //从串口打印
sendBuff = "";
static unsigned long Heartbeat_time = 0;
if (millis() - Heartbeat_time > 1000) //心跳频率
client.print("{Heartbeat}");
if (true == Heartbeat_status)
else if (false == Heartbeat_status)
Heartbeat_count += 1;
if (Heartbeat_count > 3)
Heartbeat_time = millis();
static unsigned long Test_time = 0;
if (millis() - Test_time > 1000) //定时检测连接设备
Test_time = millis();
//Serial2.println(WiFi.softAPgetStationNum());
if (0 == (WiFi.softAPgetStationNum())) // If there are no clients the car should stop.
Serial2.print("{\"N\":100}");
client.stop(); //结束当前连接:
Serial.println("[Client disconnected]");
if (ED_client == true)
ED_client = false;
