I tried both "esp32 dev module" and "ESP32-WROOM-DA Module" but none of them seem to be working, when I run a test sketch I get this error message, can anyone please help?
[2024-09-14T19:54:46.496Z] SERVER CONSOLE DEBUG: onBackendConnect: gdb-server session connected. You can switch to "DEBUG CONSOLE" to see GDB interactions.
"C:\\Users\\maria\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\openocd-esp32\\v0.12.0-esp32-20240318/bin/openocd" -c "gdb_port 50000" -c "tcl_port 50001" -c "telnet_port 50002" -s "c:\\Users\\maria\\Documents\\Arduino\\esp8266_wifi_tutorial" -f "C:/Users/maria/AppData/Local/Programs/Arduino IDE/resources/app/plugins/cortex-debug/extension/support/openocd-helpers.tcl" -f board/esp32-wrover-kit-3.3v.cfg
Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:26)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
CDRTOSConfigure
Info : auto-selecting first available session transport "jtag". To override use 'transport select <transport>'.
Info : Listening on port 50001 for tcl connections
Info : Listening on port 50002 for telnet connections
Error: unable to open ftdi device with description '*', serial '*' at bus location '*'
C:/Users/maria/AppData/Local/Arduino15/packages/esp32/tools/openocd-esp32/v0.12.0-esp32-20240318/bin/../share/openocd/scripts/target/esp_common.cfg:9: Error:
at file "C:/Users/maria/AppData/Local/Arduino15/packages/esp32/tools/openocd-esp32/v0.12.0-esp32-20240318/bin/../share/openocd/scripts/target/esp_common.cfg", line 9
[2024-09-14T19:54:48.200Z] SERVER CONSOLE DEBUG: onBackendConnect: gdb-server session closed
GDB server session ended. This terminal will be reused, waiting for next session to start...
Hi @syr_maria. What exactly were you attempting to accomplish when you encountered this error message?
I ask because this error message indicates you are clicking the "Start Debugging" button in Arduino IDE, but you don't mention anywhere in your post that you were actually attempting to use the Arduino IDE 2.x integrated sketch debugger.
