What cable do I need?
I need a usb to ttl cable. I need RX, TX, GND and the most important: a pin to control ZERO CROSSING, since my purpose is to
connect a pc through usb to XM10e (ttl-cmos) and so be able to send X10 commands through europe wire system.
Thank you so much for your help, since as you see, I'm bit noob :slight_smile:
What is the Arduino going to be doing?
I used to connect the XM10e to the arduino but now I'd like to connect it directly to the computer.
I know that the question is not directly related to arduino, but if someone could help would be great.
do you think I could use the RTS pin, for Zero crossing?
Cause for example I found this on ebay: []http://www.ebay.com/itm/USB-to-TTL-UART-Adapter-Converter-DragonOSD-with-Cable-and-Driver-Programming-/400282923242?pt=LH_DefaultDomain_2&hash=item5d32b8b0ea#ht_4884wt_932"]](http://www.ebay.com/itm/USB-to-TTL-UART-Adapter-Converter-DragonOSD-with-Cable-and-Driver-Programming-/400282923242?pt=LH_DefaultDomain_2&hash=item5d32b8b0ea#ht_4884wt_932") and it has RTS pin, but I wasnt sure if it is what I need.
Thank you a lot
jjggag:
Thank you a lot
No, that is not a RTS pin, it's a RST pin, which is an input to reset the module which almost no one ever needs or uses.
However there are USB serial converter modules that do have most of the standard serial control signs (but at TTL voltage levels) Note the signal names on the back of the module way down on the listing, those solder pads give access to the signals. http://www.ebay.com/itm/370532286388?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Lefty
