I've been using the code below for the last year or so with no issues, but when my board lost power and I needed to reupload the sketch I got the following message when I tried to compile:
/tmp/300061567/Catomatic_V5/Catomatic_V5.ino:41:1: error: 'RTC_DS1307' does not name a type
RTC_DS1307 RTC; //this defines a variable named RTC of type RTC_DS1307; it's defined in RTClib.h
/tmp/300061567/Catomatic_V5/Catomatic_V5.ino: In function 'time_t syncProvider()':
/tmp/300061567/Catomatic_V5/Catomatic_V5.ino:44:10: error: 'RTC' was not declared in this scope
return RTC.now().unixtime();
/tmp/300061567/Catomatic_V5/Catomatic_V5.ino: In function 'void setup()':
/tmp/300061567/Catomatic_V5/Catomatic_V5.ino:72:5: error: 'RTC' was not declared in this scope
RTC.begin(); //Starts the RTC library
/tmp/300061567/Catomatic_V5/Catomatic_V5.ino: In function 'void loop()':
/tmp/300061567/Catomatic_V5/Catomatic_V5.ino:114:20: error: 'RTC' was not declared in this scope
DateTime now = RTC.now(); //this calls current time and date from RTC
exit status 1
Did something change in the RTClib? This was stable code that lives in the web editor so I can't think of what may have changed.
Ive attached my code below. Any help would be greatly appreciated, the sketch is for my cat feeder and the beast needs to eat!
//Catomatic: An automated cat food and water station
//A hair-brained project by Wayne Gatlin
//last edit 25Jan2018 this version solves the delay block that was making the water dispense too long
Description of the project:
The purpose of this project is to control the timing of two outputs that are used to
dispense food and water to Murf. One output is a low-torque electric motor (12v)
that turns a worm drive to dispense food and the other is a soleniod (12v) that
dispenses water. An Arduino Uno with a RTC controls the timing of food and water cycles.
Each output is activated by a seperate TIP120 transistor that receives a 5v signal from the
Arduino that opens the defined output to the 12v current.
The objective of this code is to:
1. Use the arduino's outputs to send 5v signals to the transistors for the motor and solenoid
so that they turn on at the defined times and are open for the correct amount of time
2. Define a set amount of time that each output is open (longer=more food or water dispensed)
3. Create a timed daily cycle of three food and water events (breakfast, lunch, dinner)
4. Ideally allow the Arduino to "sleep" until it is interruped for the next event
//Step 1: Call libraries
#include <Wire.h> //This library allows the Uno to communicate with I2C / TWI devices. On the Arduino boards with the R3 layout (1.0 pinout), the SDA (data line) and SCL (clock line) are on the pin headers close to the AREF pin.
#include "RTClib.h" //I beleive this library allows the RTC to communicate with the Arduino
#include <TimeLib.h> //This header file contains definitions of functions to get and manipulate date and time information.
#include <TimeAlarms.h> //I believe this libarry allows me to schedule time-based tasks
time_t syncProvider() //this does the same thing as RTC_DS1307::get()
//Step 2: Define the variables
//int is the 'data type' for the variables --int means integer (whole number)
int feedmotor = 3; //The motor for food will be controlled by digial output pin 3
int watersolenoid = 4; //The solenoid for water will be controlled by digial output pin 4
SETUP FUNCTION
// Step 3: Run the setup
//The setup() function is called when a sketch starts. Use it to initialize variables, pin modes, start using libraries, etc.
//The setup function will only run once, after each powerup or reset of the Arduino board.
//establish communication with computer
Serial.begin(9600); //My understanding is that this sets the communiaction rate with the computer(?) and is necessary for all sketches
//Call the libraries that were included in Step 1
Wire.begin(); //Starts the wire library
setSyncProvider(syncProvider); //reference our syncProvider function instead of RTC_DS1307::get()
//Tell the arduino what I've called the outputs
pinMode(feedmotor, OUTPUT); //Defines that the feedmotor (pin 3 from step 2) is an output device
pinMode(watersolenoid, OUTPUT); //Defines that the watersolenoid (pin 4 from step 2) is an output device
pinMode(LED_BUILTIN, OUTPUT); //defines onboard LED
//Test to see if the RTC is NOT running properly
if (! RTC.isrunning())
Serial.println("RTC is NOT running!");
//Test to make sure the RTC is running properly
if (RTC.isrunning())
Serial.println("RTC is workin fine!");
// following line sets the RTC to the date & time this sketch was compiled
RTC.adjust(DateTime(F(__DATE__), F(__TIME__)));
//Define the times that food and water will be delivered
Alarm.alarmRepeat(12,00,00, Breakfast); // An alarm called Breakfast happens at 6:30am every day
Alarm.alarmRepeat(18,30,00, Lunch); // An alarm called Lunch happens at 12:30pm every day
Alarm.alarmRepeat(23,00,00, Dinner); // An alarm called Dinner happens at 6:00pm every day
//for some reason the RTC gets set 5 hours ahead of the current time when the sketch uploads from my macbook
LOOPS
//Step 4: Describe the loop
void loop() { //curly bracket that defines start of the loop
//this sets the RTC clock to current time and date in the serial monitor
//Does this require an LCD? I would like to add one in the future.
Serial.print(now.hour(), DEC); //this set of functions prints the time every second in the serial monitor
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
//this is required, or the alarms won't fire.
Alarm.delay(1000); // wait one second between clock display
//Create a loop that defines a feeding
void FoodWaterON() { // A title for this particular function
digitalWrite(feedmotor, HIGH); //Turns the feedmotor on
Serial.println("Feeding the Beast"); //text on the future LCD
//future project: LED indicator light
//future project: LCD scrolling message
//future project: sound bite to announce feeding
delay(10000); //This is the amount of time the motor will turn dispensing food
Serial.println("Feeding Complete"); //Text on the future LCD
digitalWrite(feedmotor, LOW); //Turns the feedmotor on
delay(12000); //delay between food and water
digitalWrite(watersolenoid, HIGH); //Turns the watersolenoid on
Serial.println("Hydrating"); //text on the future LCD
//future project: sound bite to announce watering
delay(3000); //This is the amount of time the motor will turn dispensing food
Serial.println("Hydration Complete"); //Text on the future LCD
digitalWrite(watersolenoid, LOW); //Turns the watersolenoid on
//Create a loop that defines a watering
/*void WaterON() { //I think this is just a title for this particular function
//Define what will happen at each of the three scheduled meal times
void Breakfast() {
Serial.println("test run");
FoodWaterON();
void Lunch() {
FoodWaterON();
void Dinner() {
FoodWaterON();
