What could be the reasons why a Daikin BRC4M150W air conditioning remote controller is not responding to IR raw code?
What could be the reason for a captured IR raw code for a Daikin air conditioner not working when sent, while IR codes from other AC companies are working? Could there be a specific issue with Daikin's security measures or some other underlying problem?
LIBRARY IRREMOTE ------ 4.1.2
Example we used to capture raw data from example :- IR RECEIVE > RECEIVE DUMP
We are capturing through infrared receiver 138
And Raw data we are getting is :-
on 26
uint16_t rawData[115] = {4930,2220, 280,1870, 280,820, 230,870, 180,870, 230,1920, 230,870, 180,870, 230,870, 180,870, 230,1870, 280,870, 180,1920, 230,1920, 230,870, 180,1920, 230,1920, 230,1920, 230,1920, 230,1920, 230,870, 230,1870, 230,870, 230,870, 180,870, 230,870, 180,870, 230,870, 180,1920, 230,870, 230,870, 180,1920, 230,870, 230,820, 230,870, 180,1920, 230,870, 230,870, 180,870, 230,870, 180,870, 230,870, 180,870, 230,870, 180,870, 230,820, 230,870, 230,820, 230,870, 180,870, 230,1920, 230,1920, 230,1870, 280,870, 180,870, 230,1870, 280,820, 230};  // Protocol=PULSE_DISTANCE Address=0x0 Command=0x0 Raw-Data=0x4E0004 56 bits LSB first
But this is not working we are sending this raw data using IR LED send raw
A few potential issues.
Please describe what you have done and give examples for us to scrutinise.
I have updated the question please check....
I will take a SWAG and say it wants its code modulated, some use 38khz.
Sounds like its all about timing...
#include <IRremote.h>
const int RECV_PIN = 7;
IRrecv irrecv(RECV_PIN);
decode_results results;
void setup(){
  irrecv.enableIRIn();
  irrecv.blink13(true);
void loop(){
  if (irrecv.decode(&results)){
        Serial.println(results.value, HEX);
        switch (results.decode_type){
            case NEC: Serial.println("NEC"); break ;
            case SONY: Serial.println("SONY"); break ;
            case RC5: Serial.println("RC5"); break ;
            case RC6: Serial.println("RC6"); break ;
            case DISH: Serial.println("DISH"); break ;
            case SHARP: Serial.println("SHARP"); break ;
            case JVC: Serial.println("JVC"); break ;
            case SANYO: Serial.println("SANYO"); break ;
            case MITSUBISHI: Serial.println("MITSUBISHI"); break ;
            case SAMSUNG: Serial.println("SAMSUNG"); break ;
            case LG: Serial.println("LG"); break ;
            case WHYNTER: Serial.println("WHYNTER"); break ;
            case AIWA_RC_T501: Serial.println("AIWA_RC_T501"); break ;
            case PANASONIC: Serial.println("PANASONIC"); break ;
            case DENON: Serial.println("DENON"); break ;
          default:
            case UNKNOWN: Serial.println("UNKNOWN"); break ;
        irrecv.resume();
D:\arduino project\SDReadSpeed\SDReadSpeed.ino: In function 'void loop()':
SDReadSpeed:21:18: error: 'DISH' was not declared in this scope
D:\arduino project\SDReadSpeed\SDReadSpeed.ino:21:18: note: suggested alternative: 'MISO'
MISO
SDReadSpeed:24:18: error: 'SANYO' was not declared in this scope
D:\arduino project\SDReadSpeed\SDReadSpeed.ino:24:18: note: suggested alternative: 'SONY'
SONY
SDReadSpeed:25:18: error: 'MITSUBISHI' was not declared in this scope
SDReadSpeed:29:18: error: 'AIWA_RC_T501' was not declared in this scope
exit status 1
Apologies, the original library...
IRRemote library
... has been modified somewhat since I used it in 2017.
Have a look at the example "IRRemoteInfo", which compiles fine for Uno.
Edit: you could uncomment the offending lines in the original sketch to get past the errors.
