i tried looking for how these pin work on LED Dot Matrix Max7219 but i coudln't find any resources for this topic. thank you.
CLK = clock
DIN = Data In (MOSI, from the POV of the host device)
CS = Chip Select
They're all explained in the MAX7219 datasheet.
Hi
SPI Interface
The MAX7219 has a four wire SPI interface - clock, data, chip select and ground - making it very simple to connect to a microcontroller.
- Data - MOSI - Master Output Serial Input. The 7219 is a slave device.
- Chip select - Load (CSn) - active low Chip select.
- Clock - SCK
- Ground.
look if this site help you.
A Google search for "max7219 tutorial arduino" will get a lot of information.
So your 8 by 32 display uses four chained MAX7219.
Precisely what do you propose to use it for? For alphanumeric displays you probably want the "Parola" library in the IDE, which will have some further information.
+1 for Parola. Not just alphanumeric, but custom sprite animations, too. Really fun library once you figure it out.
I mean the function's, what is CLK, CS, DIN really do. like
- CS (Chip Select), this pin choosing the peripheral devices
- CLK (Clock), the clock signal tells the controller inside the led that the logical state on the data line is valid and for use
- DIN (Data In), ????????????
i need knowledge about how these pin's really do
CS is the chip select. It tells the chip whether the incoming data is for that chip or not.
Din is the serial data bits being sent.
CLK is the serial clock that shifts the bits into the shift register.
Google" arduino shift register tutorial" to see how synchronous serial data transfer into a shift register works.
Have you had a look at the datasheet (https://datasheets.maximintegrated.com/en/ds/MAX7219-MAX7221.pdf)?
This is thetiming diagram from the datasheetthat should basically explain how it works
Under detailed description, you can find the explanation.
If you want to truly understand how these pins work, put the led matrix to the side for a while. Get a 74hc595 chip, 8 LEDs and 8 series resistors and learn how to control each led individually. But do not use the SPI library or the shiftOut() function. Use only digitalWrite() and do not copy the code of others, write it yourself. When you are able to control all 8 LEDs individually, you will understand what the pins you asked about do. After that, you can use shiftOut() and SPI library in the future. No-one writes code digitalWrite() to send data to chips like these, except for education and understanding.
This make sense for me, thank you so much
