This is the link to what I purchased and assembeled:
This is the Sketch I obtained from this site (which compiles properly) and that I am using (I know that the pin assignment is not correct):
/* code for max 7219 from maxim,
reduced and optimised for useing more then one 7219 in a row,
Code History:
The orginal code was written for the Wiring board by:
First modification by:
This version is by:
General notes:
-if you are only using one max7219, then use the function maxSingle to control
the little guy ---maxSingle(register (1-8), collum (0-255))
-if you are using more then one max7219, and they all should work the same,
then use the function maxAll ---maxAll(register (1-8), collum (0-255))
-if you are using more than one max7219 and just want to change something
at one little guy, then use the function maxOne
---maxOne(Max you wane controll (1== the first one), register (1-8),
collum (0-255))
/* During initiation, be sure to send every part to every max7219 and then
upload it.
For example, if you have five max7219's, you have to send the scanLimit 5 times
before you load it-- other wise not every max7219 will get the data. the
function maxInUse keeps track of this, just tell it how many max7219 you are
using.
int dataIn = 2;
int load = 3;
int clock = 4;
int maxInUse = 1; //change this variable to set how many MAX7219's you'll use
int e = 0; // just a varialble
// define max7219 registers
byte max7219_reg_noop = 0x00;
byte max7219_reg_digit0 = 0x01;
byte max7219_reg_digit1 = 0x02;
byte max7219_reg_digit2 = 0x03;
byte max7219_reg_digit3 = 0x04;
byte max7219_reg_digit4 = 0x05;
byte max7219_reg_digit5 = 0x06;
byte max7219_reg_digit6 = 0x07;
byte max7219_reg_digit7 = 0x08;
byte max7219_reg_decodeMode = 0x09;
byte max7219_reg_intensity = 0x0a;
byte max7219_reg_scanLimit = 0x0b;
byte max7219_reg_shutdown = 0x0c;
byte max7219_reg_displayTest = 0x0f;
void putByte(byte data) {
byte i = 8;
byte mask;
while(i > 0) {
mask = 0x01 << (i - 1); // get bitmask
digitalWrite( clock, LOW); // tick
if (data & mask){ // choose bit
digitalWrite(dataIn, HIGH);// send 1
}else{
digitalWrite(dataIn, LOW); // send 0
digitalWrite(clock, HIGH); // tock
--i; // move to lesser bit
void maxSingle( byte reg, byte col) {
//maxSingle is the "easy" function to use for a //single max7219
digitalWrite(load, LOW); // begin
putByte(reg); // specify register
putByte(col);//((data & 0x01) * 256) + data >> 1); // put data
// and load da shit
digitalWrite(load,HIGH);
void maxAll (byte reg, byte col) { // initialize all MAX7219's in the system
int c = 0;
for ( c =1; c<= maxInUse; c++) {
void maxOne(byte maxNr, byte reg, byte col) {
//maxOne is for adressing different MAX7219's,
//whilele having a couple of them cascaded
int c = 0;
for ( c = maxInUse; c > maxNr; c--) {
putByte(0); // means no operation
for ( c =maxNr-1; c >= 1; c--) {
// and load da shit
void setup () {
pinMode(dataIn, OUTPUT);
pinMode(clock, OUTPUT);
pinMode(load, OUTPUT);
//initiation of the max 7219
maxAll(max7219_reg_scanLimit, 0x07);
maxAll(max7219_reg_decodeMode, 0x00); // using an led matrix (not digits)
maxAll(max7219_reg_shutdown, 0x01); // not in shutdown mode
maxAll(max7219_reg_displayTest, 0x00); // no display test
for (e=1; e<=8; e++) { // empty registers, turn all LEDs off
maxAll(e,0);
maxAll(max7219_reg_intensity, 0x0f & 0x0f); // the first 0x0f is the value you can set
// range: 0x00 to 0x0f
void loop () {
//if you use just one MAX7219 it should look like this
maxSingle(1,1); // + - - - - - - -
maxSingle(2,2); // - + - - - - - -
maxSingle(3,4); // - - + - - - - -
maxSingle(4,8); // - - - + - - - -
maxSingle(5,16); // - - - - + - - -
maxSingle(6,32); // - - - - - + - -
maxSingle(7,64); // - - - - - - + -
maxSingle(8,128); // - - - - - - - +
//if you use more than one MAX7219, it should look like this
maxAll(1,1); // + - - - - - - -
maxAll(2,3); // + + - - - - - -
maxAll(3,7); // + + + - - - - -
maxAll(4,15); // + + + + - - - -
maxAll(5,31); // + + + + + - - -
maxAll(6,63); // + + + + + + - -
maxAll(7,127); // + + + + + + + -
maxAll(8,255); // + + + + + + + +
//if you use more then one max7219 the second one should look like this
maxOne(2,1,1); // + - - - - - - -
maxOne(2,2,2); // - + - - - - - -
maxOne(2,3,4); // - - + - - - - -
maxOne(2,4,8); // - - - + - - - -
maxOne(2,5,16); // - - - - + - - -
maxOne(2,6,32); // - - - - - + - -
maxOne(2,7,64); // - - - - - - + -
maxOne(2,8,128); // - - - - - - - +
delay(2000);
