I'm using the ESP8266 and ESP32 modules. I desire to both publish and subscribe to MQTT from a single module. I also have a desire to use encrypted communication. I prefer to pub/sub at QOS 0, 1, and 2 if possible.
I originally started with the adafruit library as it was the first hit I came across. I noticed that subs sit in a loop and to publish you have to break out of the loop. The default is 5 seconds which is too low of a resolution to deal with a publish for when a switch is connected. I lowered the timer to .5 seconds but polling that often causes a crash (not sure why yet).
Instead of polling I desire to operate on a callback or interrupt for subscriber messages. What lib. for MQTT do you recommend?
PaulS:
Say what? Request to subscribe to a topic may be queued, but that's generally OK, because you only subscribe once, on startup.
This doesn't make sense. You need to post your code, and a link to the library you are using.
The default what? Ice cream flavor?
You lowered the actual whatever to 5, from the default of 5? Not much of a change, was it?
What, exactly, crashed, when you did that?
It REALLY looks like the problem is your code or your MQTT server, not the library.
I should have replied more clearly. I started with the adafruit MQTT lib as documented here.
Reading a subscription update within the library is not a callback, rather you poll as seen in line 102 here:
I believe I was using that example as well when I modified the polling from 5000 ms to 500ms (5 seconds to 0.5 seconds). This is when the ESP module panic'd. I didn't grab the dump as I didn't want to debug a library that looked unusable for a single client doing both pub and sub. Notice my original post stated this as .5 vs. 0.5. I suppose this isn't a default, it's "user driven" but the example code provided a 5 second window.
I have since moved to a different MQTT library (https://pubsubclient.knolleary.net/) that implements subscription updates as callbacks. I haven't checked over an encrypted connection but this is allowing me to do what I want in the short term. This library does not support QOS 2 unfortunately (but it sounds like a limitation of data persistence within the module).
MQTT isn't a traditional client/server model per say. It's a pub/sub model with clients and a broker (server). In this case I'm using a mosquitto broker which works fine.
Actually, it looked to me like a spot on the laptop screen. Floating point values need to ALWAYS have a digit before the decimal point, even if the digit is 0.
