What is the code to have my sensor measure weight of glass water?
I am using a JOY IT sen-pressure sensor and I am trying to set it up as a weight measurement for a glass of water. Is there a possible code for this?
Post a link.
I'm sure there is. It's the one that you write :slight_smile:
Have you looked at the datasheet of the sensor to find out how it works?
Have you looked for examples that show how to do a reading with that sensor?
Would this be what you have? If not how about a link to what you have including a data sheet? Nobody here, despite some very smart folks, is a mind reader.
Can it be done? Likely but a poor choice for your objective. You would do better with a sensor to measure the weight of the glass like a compression type load cell (a scale). Tare out the weight of the glass which only leaves the water in the glass.
Ron
Yes. But now I ordered a new FSR which square-shaped to see if that work.
The one that I currently have can only measure weight when I press the sensor very hard. It doesn't seem to react to my bottle of water due to how light it is.
I wrote the code from the manual of this sensor. But with this one, it seems to measure weight only when I press it very hard with my thumb. A glass of water doesn't seem to work due to how light it is, even filled fully.
Well, if it measures up to 10 kg and a glass of water weighs 0.2 kg plus the glass, the precision range of the sensor might be way higher than the weigh of the water glass.
That is a force-sensitive resistor. They are not generally useful as a pressure sensor, or to weigh things.
This diagram from the data sheet helps to see why:
Capture
Based on the formula in https://joy-it.net/files/files/Produkte/SEN-Pressure10/SEN-Pressure_Manual_2023-04-04.pdf, the board is nothing more than a voltage divider.
I think you wired it incorrectly; what happens if you swap Vcc and GND around?
I don't have experience with FSRs but I'm not surprised... :frowning:
I'm not sure if a strain gauge will work with light loads either.
I found this about lab balances which can precisely weigh a very-small mass.
I have a postal scale but I don't know how it works. It CAN"T be TOO complicated because it wasn't expensive and you can buy a little pocket scale (like drug dealers might carry) for about $10 USD.
You can also buy a little digital kitchen scale (more like what you want) inexpensively.
OK in the interest of making things simple if I wanted to measure the weight of a glass of water I would use, as I mentioned, a compression type load cell.
Something like this which includes a HX711 amplifier module. I would get the 1 Kg flavor.
Load cells come in a dozen designs so you choose one that fits your design plan.
Above is pictured a load cell similar to what I linked to. The scale platen would sit atop the cell. The platen being your platform.
Ron
