Juraj:
did you try OTA update? AT+CIUPDATE could update the AT firmware (if it doesn't try to update to 1.7 or 2.0)
AT+CIUPDATE is the first thing I tried, before even coming to the forum.. ![]()
It gave an error,
that's what it always does, at least in all the times that I tried, across several different years of trying this command.
My assumption is that Espressif did not want to invest in the needed bandwidth needed for it,
so the command simply tries to communicate with a dead server, and so that's why the error..
(am I correct with this theory? or there are people for whom AT+CIUPDATE actually worked?)
Juraj:
wrong section
see # BOOT MODE section
or "1.2.4. 8 Mbit Flash" in AT reference
I see.
OK for Boot Mode indeed all needed files seem to be present..
From googling: ESP8266 boot vs "no boot", the explanation that I found, is that "no boot" will not support AT+CIUPDATE, and "Boot" will support it.
That's really the only difference?
I wonder why they created different files for that..
It could simply be a small setting in the Flash..
I also wonder why the readme.md file of v1.6.2 shows options for both Boot and No Boot,
yet the No Boot option leads to files that do not exist..
Does it mean they removed the option, and someone forgot to clean the .md file?
