What is this fake board, and how to drive it?
This photo shows two boards. The upper is a real Arduino Uno. When I plug it in the Arduino 2 IDE immediately recognizes it and the LED glows green.
The lower is probably a knockoff, and the IDE does not recognize it. LED glows red and a second LED blinks rapidly red. Does anyone know what this board is and whether there is a driver that works for it? Unfortunately we have several of them.
The lower board is still an Uno but it has a CH340 (I think) so you may need to install drivers for it.
See here >> Using Arduino IDE with unofficial Arduino clones bearing CH340 chip | by Andrey Semenyuk | Dev Genius
For more try a search for "clone uno usb driver".
It is a china clone, I have no problems using them but I use Linux, not windows. No drivers etc to worry about. I do not use IDE 2.x so that may be your problem, not sure.
I use the same boards, Win 11 with no special driver installation, works "out of the box". Only a different USB connector type.
Are you sure you selected the serial port correctly?
Hmmmm.... you are using IDE 2.0 and I am using 1.89 though...
Thanks, groundFungus, that was exactly the link I needed.
If your question has been answered to your satisfaction, please mark the thread as solved so that other members that wish to help will not waste their time opening the thread only to find that you no longer require assistance.
