Hi, I am trying too control 2 servo motors attached to a receiving arduino equipped with HC-12 wireless(which from my understanding is like serial communication), from a sending arduino equipped with 2 potentiometers and an HC-12 wireless module.
Basically, I want to send 2 different variables from the sender arduino to the receiver, and have the receiver set these values into 2 variables. Here is the code for the sender:
#include <SoftwareSerial.h>;
#define RX 0 //Connect to the TX pin of the HC-12
#define TX 1 //Connect to the RX pin of the HC-12
SoftwareSerial MySerial(RX, TX);
int Potentiometer1=0;
int Potentiometer2=0;
int Potentiometer1pin = A1;
int Potentiometer2pin = A2;
MySerial.begin(2400);
pinMode(Potentiometer1pin, INPUT);
pinMode(Potentiometer2pin, INPUT);
void loop() { // run over and over
readPotentiometerValue();
sendValuesMySerial(); //send with start and end markers, each variable separated by a comma
printValuesSerialMonitor();
void readPotentiometerValue(){
Potentiometer1 = analogRead(Potentiometer1pin);
Potentiometer2 = analogRead(Potentiometer2pin);
void sendValuesMySerial(){
MySerial.write("<");
MySerial.write(Potentiometer1);
MySerial.write(",");
MySerial.write(Potentiometer2);
MySerial.write(">");
void printValuesSerialMonitor(){
Serial.print("Potentiometer1 = ");
Serial.println(Potentiometer1);
Serial.print("Potentiometer2 = ");
Serial.println(Potentiometer2);
Here is the receiver code and this is where I am stumped:
#include <Servo.h>;
int Servo1=0;
int Servo2=0;
int Comstate=0;
Servo servo_5;
Servo servo_6;
servo_5.attach(5);
servo_6.attach(6);
if (MySerial.available()) {
receiveWithStartEndMarkers();
printReceivedVariablesSerialMonitor();
adjustServosAccordingly();
Comstate=1;
}else if(Comstate = 1){
servo_5.write(Servo1);
servo_6.write(Servo2);
}else{
servo_5.write(0);
servo_6.write(0);
void receiveWithStartEndMarkers(){
***//What do I put here to receive the values sent from***
*** //the first arduino set Potentiometer1 and Potentiometer2 to these values?***
void printReceivedVariablesSerialMonitor(){
Serial.print("Potentiometer1= ");
Serial.print("Potentiometer2= ");
void adjustServosAccordingly(){
Servo1 = map(Potentiometer1, 0, 1023, 0, 179);
Servo2 = map(Potentiometer2, 0, 1023, 0, 179);
My question is how do I receive the 2 variables sent by the sender, and set the value of variables with the same name to these values on the receiver end?
Any help or suggestions is much appreciated.
This is so that if there is an interruption in the wireless signal, the servo stays in its previous position, unless it has not received the signal at all since powerup.
On the sending side you have two byte integer values for Potentiometer1 and Potentiometer2 but you are only sending one byte with the mySerial.write(PotentiometerN).
After you read the linked tutorial you may decide to send the potentiometer reading as text and convert to integers on the receiving end with atoi.
In that case, your sending function would be better written like this
MySerial.write('<'); //single quote marks to send one chare
MySerial.print(Potentiometer1); //print all characters of the integer
MySerial.write(',');
MySerial.print(Potentiometer2);
MySerial.write('>');
Will it still work when transmitting through HC-12 if I use MySerial.print instead of write?
Also, for receiving the values, how do I write them into variables on the other end, because I did look at the tutorial you recommended, but I don't think that this would do that:
I want to receive the data, which comes as <pot1value, pot2value>, and write those values into variables on the receiver arduino. How do I do that? How does the receiver decode the 2 variables from the angle brackets and the comma?
while (Serial.available() > 0 && newData == false) {
You are reading the data from the HC12 and want to use mySerial instead of Serial in the reading routine.
Read the tutorial more closely, where that is described in some detail.
You also should spend some time learning the difference between = and == and when to use each of them. While your use of if(Comstate = 1){ may do what you intend to default to previously written values, using = with a conditional statement is a bad habit to get into.
I just noticed this in your code. It is not correct to use software serial on the hardware serial pins.
I would recommend that you change the software serial instance to some different pins.
When the program is finished, you may choose to put the HC12's back on the hardware serial pins for the best reliablility, but for now, you will find it easier to develop the program and load code with the HC12s on different pins.
How do I use the serial without softwareserial on pins 0 and 1 for best reliability?
Connect the HC12's to the hardware serial pins. Disconnect the HC12's when you load new code. The serial monitor will be able to echo data sent or received by the HC12's but the Serial monitor can not serve as a source of serial input to the program.
Have you indeed configured the HC12's to run at 2400 baud?
Here's something I ran on my Mega for testing (so using Serial2 to simulate your HC-12). It's certainly not definitive but you can get a feel for what's going on and way(s) to approach things.
Also note that I commented out your RX and TX definitions (hardware Serial0) and instead used pins 10 and 11. If you're using an Uno (or whatever) you'll need to adjust these pins for your HC-12 connections. The pins you had used are not suitable as they're connected to another device.
Notice too in my test message code how I send the integer...
#include <Servo.h>
#define BUFF_SIZE 8
//#define RX 0 //Connect to the TX pin of the HC-12
//#define TX 1 //Connect to the RX pin of the HC-12
#define K_SERVO_TIMEOUT 3000ul //mS 3-seconds message timeout for servo reset
#define TST_MSG_INTERVAL 1500ul //mS 1.5-sec test message interval
const uint8_t pinRX = 10;
const uint8_t pinTX = 11;
const uint8_t pinTestRX = 17;
const uint8_t pinTestTX = 16;
const uint8_t pinServo1 = 5;
const uint8_t pinServo2 = 6;
const int16_t kNumBytesPerInt = sizeof( int );
const int testVal1 = 478;
const int testVal2 = 1018;
SoftwareSerial mySerial(pinRX, pinTX);
int Servo1=0;
int Servo2=0;
int Comstate=0;
uint32_t
tNow,
tTestMessage = 0ul, //times test messages
tServoUpdate = 0ul; //servo message timeout
Servo servo_1;
Servo servo_2;
uint8_t
rxBuffer[BUFF_SIZE];
//test messages; simulates HC-12 transmitter to our softwareserial pins
//for bench testing on a Mega
HardwareSerial
*testSerial = (HardwareSerial *)&Serial2;
pinMode( pinTestTX, OUTPUT );
pinMode( pinTestRX, INPUT );
testSerial->begin(2400);
mySerial.begin(2400);
servo_1.attach( pinServo1 );
servo_2.attach( pinServo2 );
}//setup
tNow = millis();
//if we don't get a serial message within the timeout period, reset
//the servos to '0'
if( (tNow - tServoUpdate) >= K_SERVO_TIMEOUT )
servo_1.write(0);
servo_2.write(0);
}//if
//send a test message (simulates HC-12)
if( (tNow - tTestMessage) >= TST_MSG_INTERVAL )
tTestMessage = tNow;
testSerial->write( '<' );
testSerial->write( testVal1 & 0xff );
testSerial->write( (testVal1 >> 8) & 0xff );
testSerial->write( ',' );
testSerial->write( testVal2 & 0xff );
testSerial->write( (testVal2 >> 8) & 0xff );
testSerial->write( '>' );
}//if
//process any message characters
}//loop
static uint8_t
state = 0,
rxIndex;
//if there is one or more characters waiting
if( mySerial.available() )
//read one
uint8_t ch = mySerial.read();
switch( state )
case 0:
//look for sync/opening character
if( ch == '<' )
//got the sync so reset the index and move
//to state where we receive integer values
rxIndex = 0;
state++;
}//if
case 1:
//receive two 2-byte ints plus a comma
rxBuffer[rxIndex++] = ch;
if( rxIndex == (kNumBytesPerInt * 2) + 1 ) //plus 1 for ',' separator
state++;
case 2:
//next character should be the end-sync character
if( ch == '>' )
//extract the two integers
memcpy( &Potentiometer1, &rxBuffer[0], sizeof( int ) );
memcpy( &Potentiometer2, &rxBuffer[kNumBytesPerInt+1], sizeof( int ) );
//print them
//adjust them and update the servos
//update the message timer
tServoUpdate = millis();
//and go back to state zero ready for the next message
state = 0;
}//if
}//switch
}//if
}//receiveWithStartEndMarkers
}//printReceivedVariablesSerialMonitor
servo_1.write(Servo1);
servo_2.write(Servo2);
}//adjustServosAccordingly
I got it to work with wires in between the arduinos instead of HC12. Here is the sender code:
SoftwareSerial HC12(2,3);
HC12.begin(2400);
sendValuesHC12();
printToMonitor();
delay(10);
void sendValuesHC12(){
HC12.write('<');
HC12.print(Potentiometer1);
HC12.write(',');
HC12.print(Potentiometer2);
HC12.write('>');
void printToMonitor(){
Here is the receiver code:
#include <Servo.h>;
const byte numChars = 32;
char receivedChars[numChars];
char tempChars[numChars]; // temporary array for use when parsing
// variables to hold the parsed data
int Potentiometer1 = 0;
int Potentiometer2 = 0;
int Servo1=0;
int Servo2=0;
Servo servo_5;
Servo servo_6;
boolean newData = false;
HC12.begin(2400);
servo_5.attach(5);
servo_6.attach(6);
recvWithStartEndMarkers();
if (newData == true) {
strcpy(tempChars, receivedChars);
// this temporary copy is necessary to protect the original data
// because strtok() used in parseData() replaces the commas with \0
parseData();
showParsedData();
newData = false;
adjustServos();
void recvWithStartEndMarkers() {
static boolean recvInProgress = false;
static byte ndx = 0;
char startMarker = '<';
char endMarker = '>';
char rc;
while (HC12.available() > 0 && newData == false) {
rc = HC12.read();
if (recvInProgress == true) {
if (rc != endMarker) {
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
else if (rc == startMarker) {
recvInProgress = true;
void parseData() { // split the data into its parts
char * strtokIndx; // this is used by strtok() as an index
strtokIndx = strtok(tempChars,","); // get the first part - the string
Potentiometer1 = atoi(strtokIndx); // copy it to Potentiometer1
strtokIndx = strtok(NULL, ","); // this continues where the previous call left off
Potentiometer2 = atoi(strtokIndx); // Copy second part to Potentiometer2
void showParsedData() {
void adjustServos(){
Servo1=map(Potentiometer1, 0, 1023, 0, 179);
Servo2=map(Potentiometer2, 0, 1023, 0, 179);
However, this is with 2 wires going between the arduinos instead of HC12s.
Would this same code and configuration work if I were to plug pin 2 on each into the tx of HC12 and pin 3 into the RX?
I wish I could try it out but can't because in this process I fried my HC12s
Well done. You have learned one of the key lessons in developing code for Serial based wireless communications in that you can usually develop and test the code independently from the radios.
SoftwareSerial HC12(2,3); //RX,TX
Yes. The Software Serial constructor is from the point of view of the Arduino and the way to connect two devices for communication is RX>TX and TX>RX. That is, they are cross connected.
I'm sorry to hear about the mishap with your units.
What did you do that "fried" them? How do you know they are bad? Were they ever working properly with each other? I know that you have been into the AT command mode because you have set the baud rate to 2400 and perhaps they are not configured correctly.
When I got them yesterday I soldered them and then used a code I found online to set them up. I conversed with both units through the serial monitor of a nano, and the AT commands worked. Now, when I try to use these same AT commands with that code, they don't respond.
Just to clarify, if I were to buy new HC12s and keep the setup I have right now, could I replace the wires connecting RX>TX and TX>RX with an HC12 on each end?
I am just wondering whether I should order new HC12s, or if I should look for another wireless module.
It's not clear to me if the modules are now set to 2400 baud whether that applies to AT mode now or not. Try your AT coms at 2400. If that doesn't work, See this data sheet and read page 7 about how to enter AT mode in a way which should ensure that AT mode is at 9600 baud. I would keep working with the modules before you declare them damaged.
I do not think that the new modules will work at 2400 baud unless you change them from default settings. I think that you could change the code to use Software Serial at 9600 baud and the new modules should work as delivered.
One issue with the HC12 is that there are clone modules which do not work well. It is important to get factory originals sourced from the hc01 factory in China.
I would think that Bluetooth HC05 modules could work for your application but then you will have the issue of configuring one as a master and binding it to the other one. The HC12's have much better range.
There are plenty of other wireless solutions, but most if them will be more complex to use (and will require libraries) than those which use a serial protocol to communicate with the Arduino.
Also, I am unclear on if the HC12 communication requires the library because I have seen it being used in some other hc12 projects I saw online?
What library are you talking about?
You do need to use SoftwareSerial.h is you are using software serial between the module and the Arduino. As discussed earlier, you can use hardware serial between the module and the Arduino and then no libraries are needed to use the HC12.
The wire.h library. Sorry, I had put this in the first time but it was between angle brackets like in code and didn't post to the forum correctly. Also, what does it mean by low level for the set pin of HC12? I have been putting it on the GND, is that right?
