I am using a sample sketch included with the SoftI2CMaster library at GitHub, linked to from the Adafruit site.
Library at:
The sketch includes the line
#include <Arduino.h>
but there is no Arduino.h in the libraries listing on this site nor at Github, and it is not included in the Arduino IDE.
If I try to compile the sketch without Arduino.h it errors out, no surprise.
What's with this Arduino.h?
Thanks, LesB
// reads out the MLX90614 infrared thermometer
#define SDA_PORT PORTD
#define SDA_PIN 3
#define SCL_PORT PORTD
#define SCL_PIN 5
#include <SoftI2CMaster.h>
#define DEVICE (0x5A<<1)
void setup(){
#if (__AVR_ARCH__ == 5) // means ATMEGA
Serial.begin(19200);
Serial.println("Setup...");
#endif
i2c_init();
void loop(){
int dev = 0x5A<<1;
int data_low = 0;
int data_high = 0;
int pec = 0;
i2c_start(dev+I2C_WRITE);
i2c_write(0x07);
// read
i2c_rep_start(dev+I2C_READ);
data_low = i2c_read(false); //Read 1 byte and then send ack
data_high = i2c_read(false); //Read 1 byte and then send ack
pec = i2c_read(true);
i2c_stop();
//This converts high and low bytes together and processes temperature, MSB is a error bit and is ignored for temps
double tempFactor = 0.02; // 0.02 degrees per LSB (measurement resolution of the MLX90614)
double tempData = 0x0000; // zero out the data
int frac; // data past the decimal point
// This masks off the error bit of the high byte, then moves it left 8 bits and adds the low byte.
tempData = (double)(((data_high & 0x007F) << 8) + data_low);
tempData = (tempData * tempFactor)-0.01;
float celcius = tempData - 273.15;
float fahrenheit = (celcius*1.8) + 32;
Serial.print("Celcius: ");
Serial.println(celcius);
Serial.print("Fahrenheit: ");
Serial.println(fahrenheit);
#endif
delay(1000); // wait a second before printing again
