What's this component on the Arduino schematic? It appears in several places. I can see the copper pads for it on the board, but not what the component is or what it's for.
cheers
Paul
cheers
Paul
It is meant to be solder bridge or a cut able trace. I believe the one marked "reset" can be cut to prevent a reset when the DTR line goes low which is normally used by the bootloader. If you cut it you will have to push reset manually when uploading a program, but the board will not reset every time you open the serial monitor.
Great thanks
