What I really want to do is use a Si5351 to replace a crystal in a radio.
This sketch was used by a guy in New Zealand and I added a bit at the front so that I could see the frequency on the LED 20x4 blue LED.
not much luck really.
Your help would be much appreciated as it always seem that there is always a missing "library of some kind"
Please provide a detailed description of what you mean by "still had problems". If you're getting any error messages, then post the full and exact text of the errors.
That is in no way the "full and exact text of the errors" I requested.
Please do this:
When you encounter an error, you'll see a button on the right side of the orange bar "Copy error messages" in the Arduino IDE (or the icon that looks like two pieces of paper at the top right corner of the black console window in the Arduino Web Editor). Click that button..
In a forum reply here, click on the reply field.
Click the </> button on the forum toolbar. This will add the forum's code tags markup to your reply.
Press "Ctrl + V". This will paste the error between the code tags.
Move the cursor outside of the code tags before you add any additional text to your reply.
If the text exceeds the forum's 9000 character limit, save it to a .txt file and post it as an attachment. If you click the "Reply" button here, you will see an "Attachments and other settings" link.
colincolin:
Not sure what further library should be added to correct the error.
The problem isn't a missing library. The problem is that you haven't taken the time to understand the code. Without doing that, you'll only end up with a lot of frustration, confusion, and wasted time.
The error you posted is caused by this:
//Set the lcd address
// set up the LCD's number of columns and rows:
{ lcd.begin(20, 4);
// Print a message to the LCD.
lcd.print("frequency");//YOU CAN CHANGE IT
It looks like a fragment of a function.
But there are other problems. You have two setup functions and two loop functions. That's not allowed. You can't just paste two sketches together.
You are missing a closing brace at the end of the code.
