Where/how can I find compile options for me attiny cores?
I want to program a brand new AT1616. I let JLCPCB assembly a 10x15mm pcb for me.
Currently I can build but the maximum size is 32kb acording to arduino-cli so: Conclusion I must set the cpu: parameter correctly. I completely forgot what to type in CLI to find me the correct syntax and avaiable core options and all.
Ofcourse being a bit crafty, I figured to open up the IDE and put it in verbose mode. So in no time I got me.
megaTinyCore:megaavr:atxy6:chip=1616,
clock=20internal,
bodvoltage=1v8,
bodmode=disabled,
eesave=enable,millis=enabled,
resetpin=UPDI,
startuptime=8,
wiremode=mors,
printf=default,
PWMmux=A_default,
attach=allenabled,
WDTtimeout=disabled,
WDTwindow=disabled
So I compile with these settings and it seem to work.
However I would like to know what to type in CLI to find me these options. So I dont have to use the IDE :see_no_evil:
Secondly: which of these can I leave out? I do want to make use of micros()
Kind regards :coffee:
Bas
Can't you just export the compiled binary in the IDE and then upload it with a separate command outside of the IDE?
e.g. I am using AVRDUDESS for the upload
I do al work in VS Code. This includes compiling and uploading using arduino-CLI. Just one press on F6 :smiley: With atmega's it is really simple because you don't have to set any arguments at al. You just specify that you are using a nano or uno and you're good.
If I start a new project, I always use a python script which assembles a folder for me. This includes certain default files I want to use as well as locally copied libraries I can pick. The script also assembles me build.py and upload.py. But obviously this does not work yet for attinies.
I only use the IDE to reverse engineer me things like attiny build scripits. I also still use the board manager to install cores n all. But I need to start learning me to go full CLI.
Bas
Use the arduino-cli board details command:
$ arduino-cli board details --fqbn megaTinyCore:megaavr:atxy6
Board name:                ATtiny3226/3216/1626/1616/1606/826/816/806/426/416/406
FQBN:                      megaTinyCore:megaavr:atxy6
Board version:             2.6.8
Identification properties: board=atxy6
Package name:              megaTinyCore
Package maintainer:        Spence Konde
Package URL:               http://drazzy.com/package_drazzy.com_index.json
Package website:           https://github.com/SpenceKonde/megaTinyCore
Platform name:             megaTinyCore
Platform category:         Contributed
Platform architecture:     megaavr
Platform URL:              https://SpenceKonde.github.io/megaTinyCore/megaTinyCore-2.6.8.tar.bz2
Platform file name:        megaTinyCore-2.6.8.tar.bz2
Platform size (bytes):     827571
Platform checksum:         SHA-256:33c6c68f5f5dfff1de02113c968ad08dabc2cedddd78b1f9b004d91e0183de9f
Required tool: DxCore:avr-gcc                                                         7.3.0-atmel3.6.1-azduino6
Required tool: DxCore:avrdude                                                         6.3.0-arduino17or18
Required tool: arduino:arduinoOTA                                                     1.3.0
Required tool: megaTinyCore:python3                                                   3.7.2-post1
Option:        Chip        chip
               ATtiny3226                                                             ✔        chip=3226
               ATtiny3216        chip=3216
               ATtiny1626        chip=1626
               ATtiny1616        chip=1616
               ATtiny1606        chip=1606
               ATtiny826        chip=826
               ATtiny816        chip=816
               ATtiny806        chip=806
               ATtiny426        chip=426
               ATtiny416        chip=416
               ATtiny406        chip=406
Option:        Clock        clock
               20 MHz internal                                                        ✔        clock=20internal
               16 MHz internal        clock=16internal
               10 MHz internal        clock=10internal
               8 MHz internal        clock=8internal
               5 MHz internal        clock=5internal
               4 MHz internal        clock=4internal
               2 MHz internal        clock=2internal
               1 MHz internal        clock=1internal
               20 MHz internal - tuned        clock=20internaltuned
               16 MHz internal - tuned        clock=16internaltuned
               12 MHz internal - tuned        clock=12internaltuned
               10 MHz internal - tuned        clock=10internaltuned
               8 MHz internal - tuned        clock=8internaltuned
               6 MHz internal - tuned        clock=6internaltuned
               5 MHz internal - tuned        clock=5internaltuned
               4 MHz internal - tuned        clock=4internaltuned
               1 MHz internal - tuned        clock=1internaltuned
               20 MHz external clock        clock=20extclock
               16 MHz external clock        clock=16extclock
               12 MHz external clock        clock=12extclock
               10 MHz external clock        clock=10extclock
               8 MHz external clock        clock=8extclock
               24 MHz internal - tuned, overclocked        clock=24internaltuned
               25 MHz internal - tuned, overclocked        clock=25internaltuned
               30 MHz internal - tuned, overclocked, may be unstable, req. 20 MHz fuse        clock=30internaltuned
               32 MHz internal - tuned, 2-series, overclocked, may be unstable, req. 20 MHz fuse        clock=32internaltuned
               24 MHz external clock - overclocked        clock=24extclock
               25 MHz external clock - overclocked        clock=25extclock
               30 MHz external clock - overclocked, may be unstable        clock=30extclock
               32 MHz external clock - overclocked, may be unstable        clock=32extclock
Option:        millis()/micros() Timer        millis
               Enabled (default timer)                                                ✔        millis=enabled
               Disabled (saves flash)        millis=disabled
               TCA0 (default on 0-series)        millis=timera
               TCD0 (1-series only, default there)        millis=timerd
               TCB0 (breaks tone() and Servo)        millis=timerb0
               TCB1 (3216, 1616, 2-series only)        millis=timerb1
               RTC (no micros)        millis=rtc
               RTC w/w32.768 kHz ext. crystal (1/2-series only, no micros)        millis=rtcxtal
               RTC w/w32.768 kHz ext. oscillator (1/2-series only, no micros)        millis=rtcxosc
Option:        Startup Time        startuptime
               8ms        ✔        startuptime=8
               0ms        startuptime=0
               1ms        startuptime=1
               2ms        startuptime=2
               4ms        startuptime=4
               16ms        startuptime=16
               32ms        startuptime=32
               64ms        startuptime=64
Option:        BOD Voltage Level (burn bootloader req'd)        bodvoltage
               1.8V (5 MHz or less)                                                   ✔        bodvoltage=1v8
               2.6V (10 MHz or less)        bodvoltage=2v6
               4.2V (20 MHZ or less)        bodvoltage=4v2
               2.1V (Unofficial)        bodvoltage=2v1
               2.9V (Unofficial)        bodvoltage=2v9
               3.3V (Unofficial)        bodvoltage=3v3
               3.7V (Unofficial)        bodvoltage=3v7
               4.0V (Unofficial)        bodvoltage=4v0
Option:        BOD Mode when Active/Sleeping (burn bootloader req'd)        bodmode
               Disabled/Disabled                                                      ✔        bodmode=disabled
               Enabled/Enabled        bodmode=enabled
               Enabled/Sampled (1 kHz)        bodmode=ensampfast
               Enabled/Sampled (125 Hz)        bodmode=ensampslow
               Sampled/Sampled (1 kHz)        bodmode=sampledfast
               Sampled/Sampled (125 Hz)        bodmode=sampledslow
               Sampled/Disabled (1 kHz)        bodmode=sampdisfast
               Sampled/Disabled (125 Hz)        bodmode=sampdisslow
               Enabled hold wakeup/Disabled        bodmode=endisholdwake
Option:        Save EEPROM (burn bootloader req'd)        eesave
               EEPROM retained                                                        ✔        eesave=enable
               EEPROM not retained        eesave=disable
Option:        UPDI/Reset Pin Function (burn bootloader req'd)        resetpin
               UPDI (no reset pin)                                                    ✔        resetpin=UPDI
               UPDI w/reset on PB4 (2-series only)        resetpin=UPDIaltrst
Option:        printf()        printf
               Default (doesn't print floats, 1.4k flash use)                         ✔        printf=default
               Full, 2.6k, prints floats        printf=full
               Minimal, 1.1k flash used        printf=minimal
Option:        Wire (Wire.h/I2C) Library mode        wiremode
               Master or Slave (saves flash and RAM)                                  ✔        wiremode=mors
               Master and Slave        wiremode=mands
Option:        WDT timeout (burn bootloader req'd. Cannot be disabled at runtime if set here)        WDTtimeout
               Disabled (recommended)                                                 ✔        WDTtimeout=disabled
               Window remains open for 8 Seconds        WDTtimeout=8seconds
               Window remains open for 4 Seconds        WDTtimeout=4seconds
               Window remains open for 2 Seconds        WDTtimeout=2seconds
               Window remains open for 1 Second        WDTtimeout=1second
               Window remains open for 500 milliseconds        WDTtimeout=500msec
               Window remains open for 250 milliseconds        WDTtimeout=250msec
               Window remains open for 125 milliseconds        WDTtimeout=125msec
Option:        WDT window (if desired. burn bootloader req'd. Cannot be disabled at runtime if set here)        WDTwindow
               No delay before window "opens"                                         ✔        WDTwindow=disabled
               8 Second before window "opens"        WDTwindow=8seconds
               4 Second before window "opens"        WDTwindow=4seconds
               2 Second before window "opens"        WDTwindow=2seconds
               1 Second before window "opens"        WDTwindow=1second
               500 millisecond before window "opens"        WDTwindow=500msec
               250 millisecond before window "opens"        WDTwindow=250msec
               125 millisecond before window "opens"        WDTwindow=125msec
               62.5 millisecond before window "opens"        WDTwindow=63msec
Option:        PWM pins (advanced, see core documentation)        PWMmux
               PB0-2, PA3-5, 1-series: PC0/1 (default)                                ✔        PWMmux=A_default
               PB0-2, PA3-5. No TCD PWM even on 1-series.        PWMmux=default
               PB0-2 (buffered), 1-series: PC0/1        PWMmux=A_buffered
               PB0-2 (buffered), 1-series: PA4/5        PWMmux=D_buffered
               PB0-2 (buffered). No TCD PWM even on 1-series.        PWMmux=buffered
               PB0,1,5, PA3-5, 1-series: PC0/1        PWMmux=U6_A
               PB0,1,5, PA3-5. No TCD PWM even on 1-series.        PWMmux=U6
               PB0,1,5 (buffered), 1-series: PA4/5        PWMmux=U3_D
               PB0,1,5 (buffered), 1-series: PC0/1        PWMmux=U3_A
               PB0,1,5 (buffered). No TCD PWM even on 1-series.        PWMmux=U3
               PB3-5 PA3-5, 1-series: PC0/1        PWMmux=I6_A
               PB3-5, PA3-5. No TCD PWM even on 1-series.        PWMmux=I6
               PB3-5 (buffered), 1-series: PA4/5        PWMmux=I3_D
               PB3-5 (buffered), 1-series: PC0/1        PWMmux=I3_A
               PB3-5 (buffered). No TCD PWM even on 1-series.        PWMmux=I3
               PB3-5, PC3, PA4/5, 1-series: PC0/1        PWMmux=SC6_A
               PB3-5, PC3, PA4/5. No TCD PWM even on 1-series.        PWMmux=SC6
Option:        attachInterrupt Mode        attach
               On all pins, with new implementation.                                  ✔        attach=allenabled
               Only enabled ports        attach=manual
               Old version, (may fix bugs)        attach=oldversion
Programmers:   ID        Name
               serialupdi                                                             SerialUPDI - 230400 baud
               serialupdi460k                                                         SerialUPDI - FAST: 4.5v+ 460800 baud (CH340 - and maybe some others)
               medbg        Xplained Mini (mEDBG, debug chip: ATmega32u4)
               nedbg        Curiosity Nano (nEDBG, debug chip: ATSAMD21E18)
               edbg        Xplained Pro (EDBG, debug chip: AT32UC3A4256)
               serialupdi57k                                                          SerialUPDI - SLOW: 57600 baud
               serialupdi921k_wd1                                                     SerialUPDI - TURBO: 4.5v+ 921600 baud w/write delay, (adapters that support it and are not CH340, many fall back to 115200)
               jtag2updi                                                              jtag2updi
               snap_updi                                                              MPLAB SNAP (UPDI mode)
               pickit4_updi                                                           PICkit4 (UPDI mode)
               atmelice_updi                                                          Atmel-ICE
               serialupdi921k                                                         SerialUPDI - TURBO: 4.5v+ 921600 baud (CH340 (and maybe some others) only)
               serialupdi230k_wd1                                                     SerialUPDI - 230400 baud w/write delay, 2.7V+ (Linux/MacOS: other adapters, Win: maybe some adapters)
               serialupdi460k_wd1                                                     SerialUPDI - FAST: 4.5v+ 460800 baud w/write delay (other non-CH340 adapters, often slower than 230k, esp. on Windows)
Great, thank you. This is the forgotton line I was looking for.
This :white_check_mark:marks also anwsers my 2nd question, what options must one set. :ok_hand:
Regards, :coffee:
Bas
You are welcome. I'm glad if I was able to be of assistance.
Regards,
Per
