Where is a mistake?
Hello, I am a beginner in Arduino programming and I have an assignment to make a simulation of a vending machine.
Assignment is :
A bottle of soda costs: 2.5 euro.
only combinations of 0.5, 1, 2 euro are allowed (which are buttons)
At rest: red light is on AND green light is off
While waiting for the full amount: red LED flashing AND green is off.
after complete amount entered: green LED is on AND red LED is off.
The problem is that it doesn't work the way I want it to, and leds are lighting up randomly, I am out of ideas anymore.
int Button5 = 2; //button for 50 cents
int Button1 = 3; // button for 1 euro
int Button2 = 4; // button for 2 euros
int RED = 9;
int GREEN = 13;
int buttonState1 = 0;
int lastButtonState1 = 0;
int buttonState2 = 0;
int lastButtonState2 = 0;
int buttonState3 = 0;
int lastButtonState3 = 0;
int result = 0 ;
int oldresult = 0;
unsigned long lastDebounceTime = 0; //last time the pin was toggled, used to keep track of time
unsigned long debounceDelay = 50; //the debounce time which user sets prior to run
Serial.begin (9600);
pinMode(GREEN , OUTPUT);
pinMode(RED , OUTPUT);
pinMode(Button5, INPUT);
pinMode(Button1, INPUT);
pinMode(Button2, INPUT);
buttonState1 = digitalRead(Button5);
// compare the buttonState to its previous state
if (buttonState1 != lastButtonState1) {
if (buttonState1 == HIGH);
result = oldresult + 5;
lastButtonState1 = buttonState1;
oldresult = result;
buttonState2 = digitalRead(Button1);
if (buttonState2 != lastButtonState2) {
// if the state has changed, increment the counter
if (buttonState2 == HIGH)
result = oldresult + 10;
return result;
lastButtonState2 = buttonState2;
oldresult = result;
buttonState3 = digitalRead(Button2);
if (buttonState3 != lastButtonState3)
if (buttonState3 == HIGH)
result = oldresult + 20;
return result;
lastButtonState3 = buttonState3;
oldresult = result;
if ((result > 0) && (result < 25))
digitalWrite(GREEN, LOW);
digitalWrite(RED, HIGH); // turn the LED on (HIGH is the voltage level)
delay(100); // wait for a second
digitalWrite(RED, LOW); // turn the LED off by making the voltage LOW
else if ( result == 0 )
else if ( result >= 25)
digitalWrite(GREEN, HIGH);
How are the inputs wired ?
Have you got pulldown resistors in place to keep them in a known state at all times or are they floating at an uncertain voltage ?
      return result;Where are you returning result to ?
Oops
As pointed out in #1, you have return statements in loop() that sometimes prevent the program from getting to the blink code. Even if it did, though, you would not see a blink because this is wrong:
That code waits for 100 milliseconds, not a second.
int RED = 9;
int GREEN = 13;
int result = 0 ;
int oldresult = 0;
THREE switch pins.
THREE current states.
THREE previous states.
ONE time.
Wrong!
