Where is Adafruit_MAX4466 in Arduino Library manager?
Greetings fellow electrical engineers, it is requested to tell me that where is Adafruit_MAX4466 library in arduino ide, i haven't found it yet. Thanks and regards:
Look i cant find it:
Hi @tengineer. What lead you to believe that such a library exists at all?
If you saw it mentioned somewhere on the Internet, please reply here to provide the link to that page. It would provide the helpers here on the forum with valuable context they can use to better assist you.
Greetings i want to work with a microphone sensor called max4466 sensor. For that I read that I have to install a library called adafruit max4466 library.
Here it's in chatgpt's code:
Oh, well, if ChapGPT says it exists...
Take a look for yourself at Adafruit's Github repositories. Feel free to do a search for yourself and see that there's no such library. There are Eagle schematics and PCB. That's it.
I don’t think you need a library.
Just use it like a digital/analog sensor?
Unfortunately ChatGPT is prone to "hallucinations", where the AI may simply make something up out of thin air if it doesn't know the answer. I think that is the case here.
If you provide a detailed description of what your true goal is, I'm sure the forum helpers will be able to provide assistance.
My goal is to get some audio data(speech) from some audio sensor. I have to send the audio data to a Pc in which the audio would be converted to text. Then sentiment analysis would be performed on it. Kindly help me in this regard
