I'm building some gauges for a cockpit simulator build and I will need to use some stepper motors. I've done some google-ing but literally every tutorial is using a different motor and a different driver so yeah, I'm really confused now. Could someone please point me in the right direction for a cheap stepper motor (doesn't have to be powerful at all) and a driver to control it with?
To give you an advice we need some more details about what you are going to achieve.
So let us know,
how fast the steppers should be (e.g. full turn in .... sec)
is space a factor
what about your power supply
I understand that torque is no issue, but the above listed parameters might matter, besides of those which we hopefully will get to know, when you give us a little more background information.
The motors will be pretty slow, maybe 1 seconds at the fastest for a full turn, keep in mind though not all the gauges actually make a full turn so it's kind of hard to know.
Yes but I imagine the steppers would be relatively small so it shouldn't be a problem. Each gauge is roughly 7cm wide (circle shaped).
Where will the simulator be used?
I suspect, in a kind of laboratory, but not in any vehicle?
So the only space-critical things would be the steppers themselves, as you want to drive the hands of the gauges directly on the axis of the steppers?
If this is true, and you want to mount the steppers directly into a gauge case, the limiting factor is found and your steppers can't exceed 7 cm (diagonal), right?
Another possibility would be to mount them behind a gauge if depth is no issue for the cockpit simulator.
But: As the steppers won't have to carry big loads - in fact it will be like idle load, just moving hands - torque is no issue at all and you could go with pretty small steppers.
As I am in a hurry right now, I will look something up tonight. In the meantime let us know if all my assumptions are correct.
Ok, I searched the sizes for NEMA steppers:
NEMA 11 = 28mm square = 39mm diagonal
NEMA 14 = 35mm square = 49mm diagonal
NEMA 17 = 42mm square = 59mm diagonal
NEMA 23 = 57mm square = 79mm diagonal
Theoretically you could go up to a NEMA 17 sized stepper.
But, if my assumption is correct that you only want to move small hands on the shaft of the motor, you could go with the weakest NEMA 11 stepper - you could even go with something like this:
plus an adequate driver.
To continue you should come back with some confirmations about my assumptions and the knowledge about steppers in general, having studied Robin2's information.
Once we have identified the right stepper motor we can care about the driver boards and the power supply for your project
Wow, never heard of those tiny steppers especially for gauges.
Good information for me for the future as I was looking for very small gauges for a test pad and all the gauges which I could find were way too big and I didn't want to use digital displays for certain reasons.
@rpt007 The simulator is just a fun project, it will probably be in my room, but I don't really know yet. 7cm is just a guess at this stage, I haven't got any dimensions yet but that's my guess. The gauges are circle too, so I think the word you'd be looking for is diameter, not diagonal. Depth isn't an issue no, but I don't want anything ridiculous if you know what I mean.
Some of those Nema motors look pretty good but they're a little bit pricy for just a couple of gauges. However those adafruit ones look pretty nice, very small and cheap. I think I would go with those? What do you think?
@scottyjr Those also look very nice, I've seen them in other videos but again they're just too expensive for a couple of gauges.
@Robin2 Thanks for those links, very useful. Those tiny motors look good but almost too small. Do you think they would actually work? The other one looks good too but the same as most of the others, I feel they are too expensive.
matthewinglis:
Well in that case, I'm tied between those tiny little ones and the 28BYJ 48 motors. Assuming I go for either of those, what drivers would I need?
The 28BYJ is a unipolar motor and is usually controlled with a ULN2003 - I have no experience of the 28BYJ but there are many Forum Threads about them.
If the tiny motors draw about 20mA they could (in theory) be driven directly from the Arduino's I/O pins but I would prefer to but some sort of buffer chip in between to protect the Arduino from voltage spikes.
Oh yeah and I will be needing heaps of them, like at least 30 probably so assuming I will be needing at least 30, what would be the best way to go about powering both of those motors?
And what sort of power supply would I need for the 28BYJ 48 motors?
If I remember the datasheet right, they draw a bit more than the Arduino pins can deliver.
So you will need to use an external power supply for them, check the current value of the motors, multiply the current by the number of motors and you are set.
There are two types of the 28BYJ 48 motors: 5V and 12V.
The higher the voltage the better the control of a motor. But with your given "almost zero" load, I think it wouldn't matter. But: these motors are cheap and pretty noisy.
If you google "28BYJ 48 motor bipolar" you will find instructions how to convert those unipolar steppers to bipolar steppers. This would give you the advantage to drive the stepper with either A4988 or drv8825 drivers, which are much better drivers than the ancient UN2003 drivers.
Maybe my English is a bit misleading but I actually meant a "diagonal" measure:
e.g. NEMA 11 = 28mm square = 39mm diagonal (39mm = 28mm * 1.41) - so it's the diagonal measure which determines the size of the circle to fit in.
30 controlled by one or more Arduinos?
Your Arduino itself will draw something like 30mA, so - if you would, say, need 5 Arduinos, you have to add 5 * 30mA to the 30 * current draw of each motor (assuming that in worst case scenario all motors have to move simultaneously).
