I am making an installation that gets activated via PIR sensor, which starts a 12v DC motor, rotating up for 3 seconds (pulling around 1kg weight), pauses for 5 seconds to make sure no motion is going on, and then reverses for 3 seconds
I have sourced a part of code from the library and tried placing the code for forward motion (upwards), but I am a bit lost as to where the reverse part goes in.
Can anyone help/guide me for this? It any tips, guidance, encouragement is much appreciated.
Thanks in advance.
* Switches a LED according to the state of the sensors output pin.
* Determines the beginning and end of continuous motion sequences.
* @author: Kristian Gohlke / krigoo (_) gmail (_) com / http://krx.at
* @date: 3. September 2006
* kr1 (cleft) 2006
* released under a creative commons "Attribution-NonCommercial-ShareAlike 2.0" license
* http://creativecommons.org/licenses/by-nc-sa/2.0/de/
* The Parallax PIR Sensor is an easy to use digital infrared motion sensor module.
* (http://www.parallax.com/detail.asp?product_id=555-28027)
* The sensor's output pin goes to HIGH if motion is present.
* However, even if motion is present it goes to LOW from time to time,
* which might give the impression no motion is present.
* This program deals with this issue by ignoring LOW-phases shorter than a given time,
* assuming continuous motion is present during these phases.
//VARS
//the time we give the sensor to calibrate (10-60 secs according to the datasheet)
int calibrationTime = 15;
//the time when the sensor outputs a low impulse
long unsigned int lowIn;
//the amount of milliseconds the sensor has to be low
//before we assume all motion has stopped
long unsigned int pause = 5000;
boolean lockLow = true;
boolean takeLowTime;
int pirPin = 3; //the digital pin connected to the PIR sensor's output
int ledPin = 13; // digital pin for LED
int in1Pin = 10; // rotates the motor forward
int in2Pin = 11; // rotates the motor backward
//SETUP
void setup(){
pinMode(pirPin, INPUT); // declare sensor as input
pinMode(ledPin, OUTPUT); // declare LED as output
pinMode (in1Pin, OUTPUT); // declares pin as output
pinMode (in2Pin, OUTPUT); // declares pin as output
digitalWrite(pirPin, LOW);
//give the sensor some time to calibrate
Serial.print("calibrating sensor ");
for(int i = 0; i < calibrationTime; i++){
Serial.print(".");
delay(3000);
Serial.println(" done");
Serial.println("SENSOR ACTIVE");
delay(50);
//LOOP
void loop(){
if(digitalRead(pirPin) == HIGH){
digitalWrite(ledPin, HIGH); //the led visualizes the sensors output pin state
digitalWrite(in1Pin, HIGH); // Motor turns forward
delay(3000); // motor runs for 3 seconds
digitalWrite(in2Pin, LOW);
if(lockLow){
//makes sure we wait for a transition to LOW before any further output is made:
lockLow = false;
Serial.println("---");
Serial.print("motion detected at ");
Serial.print(millis()/1000);
Serial.println(" sec");
delay(50);
takeLowTime = true;
if(digitalRead(pirPin) == LOW){
digitalWrite(ledPin, LOW); //the led visualizes the sensors output pin state
// digitalWrite
if(takeLowTime){
lowIn = millis(); //save the time of the transition from high to LOW
takeLowTime = false; //make sure this is only done at the start of a LOW phase
//if the sensor is low for more than the given pause,
//we assume that no more motion is going to happen
if(!lockLow && millis() - lowIn > pause){
//makes sure this block of code is only executed again after
//a new motion sequence has been detected
lockLow = true;
Serial.print("motion ended at "); //output
Serial.print((millis() - pause)/1000);
delay(50);
