Which Interrupt pins can I use
Hello I am trying to use the interrupt pins to use with buttons on a project I am working on. I am using the Arduino mega 2560 rev 3. I have read through the Arduino docs and it it says for the Arduino that for that board pins 2, 3, 18, 19, 20, and 21. I am curious if anyone knows if I can assign digitalPinToInterrupt() function to other pins for this board.
No. You cannot decide that an arbitrary pin is associated with a hardware interrupt
However, you may want to investigate pin change interrupts
Are you sure that you need to use interrupts of any type ?
Usually there is no need for an interrupt for a button.
Use one of the available libraries. For example "OneButton".
Is there some reason you don't believe the official documentation?
Correction they are limit switches and I would like is the limit switch gets pressed I want my code to stop what it is doing.
So, once in the ISR, how will you accomplish that?
for(;;); :rofl:
Still no need for an interrupt.
Check the state of your limit switches with digitalRead,
and continue your task when the criterion is not fullfilled.
  for (int ii = 0; ii < 54 ; ++ii) {
    int intNum = digitalPinToInterrupt(ii);
    if (intNum >= 0 ) {
      Serial.print(ii);
      Serial.print(":");
      Serial.println(intNum);
3:1
18:5
19:4
20:3
21:2
Nope. That looks like it.
thank you
As UKHeliBob stated, you have to use the predefined Pins as specified in the doc. The digitalPinToInterrupt() function is there to make your code a little more readable (if you prefer) as you use the interrupt Pin # (as defined in the doc), rather than use the built in Interrupt Vector definition.
