I believe I have the one USB cable that goes from the MEGA's Square connector to the PC just a regular USB cable correct?
What about the Female USB connector on the MEGA ADK? MOst Androids have the Micro A to Normal Male USB but how does one connect a Standard MALE to MALE?
My Tablet is a WM8560 and has a Dongle which connects to the port at the bottom of the Tablet and provides FEMALE USB connectors and Ethernet.
I need a Male to Male correct and not ACTIVE?
I can't find one in any stores nearby. I wonder if I can get a Micro Male to standard Male adapter then I am set!!
Can I ask this please. They sell a USB A Male to USB a Male non active would that work? I am referring to the ADK MEga. One of those USB ports make the ADK except external USB devices such as the Android. But if My Android does not have a Micro A or Micro B but just a USB A then I would need a USB A Male to USB A Male correct? The MEGA ADK has a USB female end to except these devices right? The other connector is for the Mega ADK to PC a standard USB cable.
I don't think your answer was helpful at all. Is there a Document on this to show me the different USB cable configurations? I am guessing that the only other possible one I would need which I have is a USB A Male to USB Micro A or B male for Android devices that have the female Micro connection.
Mine is a tablet with a port that takes a Dongle that has 2 USB Female connectors and 1 Ethernet. No Micro on it!!
Which version of Android are you using on that tablet. A quick google shows it running 2.2. The Open Accessory Protocol originally required Android 3.1, and was back-ported to 2.3.4, but isn't supported on 2.2.
Are you aware of the difference between a USB host and a USB device ? You connect a host to a device, the arduino is a device so it needs connecting to a host, I have an android phone with a micro USB connector, it is also a device and is intended to be connected to a host (eg a PC). It cannot be connected to another USB device such as an Arduino. Some tablets can be used as USB hosts (and many cannot) , but they usually have either the familiar rectangular socket as used on PCs or a proprietry connector intended to be used with their cable.
