Why 'Char' Value is equal to 48 'int' Value?
I was tinkering with my Arduino Board and I found Something Strange
I uploaded this code
int v;
char t = '2';
v=t;
Serial.print(t);
Serial.print(" ");
Serial.println(v);
And the Result were Strange the Char Value was '2' but the Integer Value was '50'
Please explain me anyone why this happened??
Serial print sends the ASCII character codes. The ASCII characer code for '2' is 5010 (0x32 hex). If you want to send the byte 2 use Serial.write(). That sends the binary number (0x02). If you want a number (2) displayed when received from a print (50 dec), subtract '0' (0x30 or 40 dec) from the received character.
val = receivedChar - '0';
areeburrub:
I was thinking that I should point out that subtracting '0' only works with single characters, '0' to '9'. So a better example is:
char receivedChar = '7';  // try this with a non numeric character, say 'e'
   // check to maake sure that the receivedChar
   // is a valid number 0 to 9.
   if(receivedChar >= '0' && receivedChar <= '9')
      int val = receivedChar - '0';
      Serial.print("  val = ");
      Serial.println(val);
    Serial.println("invalid input");
areeburrub:
the American Standards Association defined it in 1963 in the American Standard Code for Information Interchange (ASCII)
areeburrub:
No, the integer value was 50.
