I recently bought a 2.8" tft screen spi for a project i am working on with arduino.
But i just can't get anything working on the screen
Screen i bought:
The seller of the product sended me his code, i plugged my tft screen on the uno like he did and still i don't get anything on the screen...
Attached is the code he sended me.
All i get is a black screen and nothing shows up on the tft screen.
Anyone got any suggestion cause i am getting realy pissed off because of this...
From the photo of the pcb, I concluded that it was an experimental "device" that probably did not work at all.
What country do you live in?
I can look at the attached sketch later this evening. And compare it to the photo of the pcb.
Please can you compare the item in your hand with the AliExpress photo.
Report back if it is a 100% exact match. If it is different, it is not worth our time trying to see what is happening.
Thank you, as far as i can see it is a 100% exact match.
I only just dont understand how it "works" on his photo, and while i attach it to the same arduino as he has mine doesnt do anything
If this won't work, do you got any other suggestion for a better screen?
I need one that leaves at least analog pin 4 & 5 free (for i2c) because i need to interact with other arduino's for my project. But all of the bigger screens or same size i see all are using all of the available analog pins
According to one of the "feedback" comments, you need Adafruit_ILI9340.h library and not the Adafruit_ILI9341 library.
What is the part number of the SOIC chip?
Are the SMD resistors really 0R ?
Regarding I2C. Most of the current 2.4" MCUFRIEND Shields are using an ILI9341. This means that you do not need the RESET pin. (You can use a Software Reset command with the ILI9341)
So you can simply snip the LCD_RESET male header pin. Now you have A4, A5 freely available for I2C: SDA, SCL. And you still have the Touch Screen and microSD. And those 2.4" Red Shields are CHEAP, reliable and have proper level translation.
it says 0 on those small chips.
i managed to get back light or how u call it.
not by plugging it into the arduino but by using jumper wires connected to the tft and then to the arduino.
only now i just need to figure out how to display something on it (code that would work)
Does this display need 5v-to-3.3v level shifters on the SPI lines? I've bought two small SPI LCD's on eBay and they both required level shifters to work. I used CD4050 chips with both of my LCD's to get them working.
