Why does SPI.begin mess upo the code
I have to write character on an LCD display.
My connection is such that I have to use SPI to turn on LEDs.
I have the following code working fine until I add SPI.begin(); in the set up. My code is no longer working properly and I am getting wrong characters on the display.
Using Teensy 2++ and LCD graphic display 2x16 char.
Wroking code:
#include<SoftwareSerial.h>
#include <SPI.h>
#define txPin 45
#define LED_POW 44
#define MeterMode 38
#define MeterBlank 19
#define TLC_Latch 20
#define SPICLOCK 21
#define SDOUT 22
#define LCD_DB7 23
#define LCD_DB6 24
#define LCD_DB5 25
#define LCD_DB4 26
#define LCD_E 1
#define LCD_RW 0
#define LCD_RS 27
#define SW_408 41
#define SW_816 42
#define LCD_CONTRAST_0 17
#define LCD_CONTRAST_1 16
#define LCD_CONTRAST_2 15
#define LCD_CONTRAST_3 14
const int pinLedRed = 39;
const int pinLedGreen = 40;
int ROWpins[] = {
4, 5, 6, 7};
const int pinSW_COL_1 = 8;
const int pinSW_COL_2 = 9;
const int pinSW_COL_3 = 10;
const int pinSW_COL_4 = 11;
const int pinSW_COL_5 = 12;
const int pinSW_COL_6 = 13;
int LCD_CONTRAST[] = {
17, 16, 15, 14};
const int UserSW = 43; // Push switch to start testing
int SW = 0; // Switch selected on the DUT board
int test=0;
int SelectSW = 0; //select unit 408 or 816
SoftwareSerial LCD = SoftwareSerial(0, txPin);
// since the LCD does not send data back to the Arduino, we should only define the txPin
const int LCDdelay=10; // conservative, 2 actually works
long interval = 5000;
long currentMillis = 0;
long previousMillis = 0;
//SPISettings settingsA(125000, MSBFIRST, SPI_MODE1); //(gives 8 microsecond period clock pulses)
uint8_t i=0;
pinMode(txPin, OUTPUT);
pinMode(TLC_Latch, OUTPUT);
pinMode(MeterMode, OUTPUT);
pinMode(LED_POW, OUTPUT);
pinMode(LCD_RW, OUTPUT);
pinMode(LCD_RS, OUTPUT);
pinMode(LCD_E, OUTPUT);
pinMode(pinLedRed, OUTPUT);
pinMode(pinLedGreen, OUTPUT);
for (int p=0; p<4; p++)
pinMode(ROWpins[p], OUTPUT);
pinMode(LCD_DB4, OUTPUT);
pinMode(LCD_DB5, OUTPUT);
pinMode(LCD_DB6, OUTPUT);
pinMode(LCD_DB7, OUTPUT);
digitalWrite(LCD_RW, HIGH);
// digitalWrite(MeterBlank, LOW); // ON/OFF of OUTx outputs are controlled by input data
// digitalWrite(MeterMode, LOW);
// digitalWrite(TLC_Latch, LOW);
// SPI.begin();
// delay(10);
// Serial.begin(9600);
//Serial1.begin(9600);
// LCD.begin(9600);Why does
// clearLCD();
// LCD.print("G2 Fixture");
// delay(1000);
// digitalWrite(LCD_RW, HIGH);
void lcd_command(uint8_t i) {
digitalWrite(LCD_RS, LOW);//1=data, 0=command
digitalWrite(LCD_RW, LOW);//1=read,0=write
digitalWrite(LCD_DB4, i&(1<<4));
digitalWrite(LCD_DB5, i&(1<<5));
digitalWrite(LCD_DB6, i&(1<<6));
digitalWrite(LCD_DB7, i&(1<<7));
Nibble();
digitalWrite(LCD_DB4, i&(1<<0));
digitalWrite(LCD_DB5, i&(1<<1));
digitalWrite(LCD_DB6, i&(1<<2));
digitalWrite(LCD_DB7, i&(1<<3));
Nibble();
void Nibble(){
digitalWrite(LCD_E, HIGH);//D1
delay(1);
digitalWrite (LCD_E, LOW);
delay(1);
void lcd_data (uint8_t i){
digitalWrite(LCD_RS, HIGH);//B6
digitalWrite(LCD_RW, LOW);//B5
Nibble();
Nibble();
void loop(){
//init
//this is a command so clear these
digitalWrite(LCD_RS, LOW);//B6
i=0x30;//wake up
digitalWrite(LCD_DB4, i&(1<<4));//B6
digitalWrite(LCD_DB5, i&(1<<5));//B5
digitalWrite(LCD_DB6, i&(1<<6));//B4
digitalWrite(LCD_DB7, i&(1<<7)); //B3
Nibble();
delay(160);
Nibble();
delay(160);
Nibble();
delay(160);
i=0x20;//4-bit interface
Nibble();
delay(100);
lcd_command(0x28);//4-bit two line
lcd_command(0x10);//set cursor
lcd_command(0x0F);//Display On, Cursor blink
lcd_command(0x06);//Entry Mode set
lcd_command(0x01);//Clear
uint8_t pos_counter=0;
i=0b01000001;//startt off with an A
while(1){ //Happy Display Routine
lcd_data (i);
delay(100);
i++;
//Make the display pretty
pos_counter++;
if (pos_counter==16)lcd_command(0xC0);//Line 2
//Avoid weird chars
if (i==0b01011011)i=0b00110001;//after Z send 1
if (pos_counter==32){//At the end of line 2, start over at A
pos_counter=0;
lcd_command(0x80);//Line 1
i=0b01000001;//A
}//end of loop
I need to add SPI.begin(); to use my SPI.transfer functions.
Does anybody know how to fix this?
To post:
  1. Use CTRL-T in the Arduino IDE to autoformat your code.
  2. Paste the autoformatted code between code tags (the </> button)
    so that we can easily see and deal with your code.
LCDs are often connected to SPI lines. You either need to get your LCD off the SPI bus, or find a way to get them to play nicely together. This often involves properly using the enable lines, but I suspect that you don't understand how this works.
Before posting again, you should read the three locked topics at the top of the Programming Questions forum, and any links to which these posts point.
Good Luck!
Sorry for not putting the code properly
#include <SPI.h>
#define txPin 45
#define LED_POW 44
#define SPICLOCK  21
#define SDOUT 22
#define LCD_DB7 23
#define LCD_DB6 24
#define LCD_DB5 25
#define LCD_DB4 26
#define LCD_E 1
#define LCD_RW 0
#define LCD_RS 27
#define SW_408 41
#define SW_816 42
int ROWpins[] = {
  4, 5, 6, 7};
  17, 16, 15, 14};
int test=0;
uint8_t i=0;
  //  SPI.begin();
  //  delay(10);
  // clearLCD();
  // delay(1000);
  Nibble();
  Nibble();
void Nibble(){
  delay(1);
  delay(1);
  Nibble();
  Nibble();
void loop(){
  //init
  i=0x30;//wake up
  Nibble();
  delay(160);
  Nibble();
  delay(160);
  Nibble();
  delay(160);
  Nibble();
  delay(100);
    lcd_data (i);
    delay(100);
    i++;
    pos_counter++;
    //Avoid weird chars
      pos_counter=0;
      i=0b01000001;//A
}//end of loop
What do these do?
Is there anything connected to PB0-PB3?
