Why does the arm servo moveee?
  #include <Arduino.h>
  #include <ESP32Servo.h>
  Servo front;  // pin 47
  Servo rear;   // pin 21
  Servo arm;    // pin 16
      front.attach(47);
      rear.attach(21);
      arm.attach(3);
      // position 1
      front.write(90);
      rear.write(90);
      arm.write(45);
      delay(2000);
      // position 2
      front.write(180);
      rear.write(0);
      arm.write(45);
      delay(2000);
      // position 3
      front.write(0);
      rear.write(180);
      arm.write(45);
      delay(2000);
  void loop() {}
This is the code that the arm servo moves to the front servo position. I'm using an ESP32-S3, and I tried changing the pins as well as the arm servo. I tried (16, 3, 48), but it still moves only to the front servo position.
The usual way to develop programs is one step at a time, but you have all combined at once. Make a copy of this program, but remove all but one servo and test with just the one servo. Does it work? Now do the same for another servo and test if it works.
Now, what is different about the single servo code and the one you have shown here? If nothing, then you have wiring problems that should have been shown to you in the single servo tests.
I moved your topic to a more appropriate forum category @diheindl.
The Nano Family > Nano ESP32 category you chose is only used for discussions directly related to the Arduino Nano ESP32 board.
In the future, when creating a topic please take the time to pick the forum category that best suits the subject of your question. There is an "About the _____ category" topic at the top of each category that explains its purpose.
Thanks in advance for your cooperation.
I found a trail ESP32-S3 Not Working With 2+ Servos - #14 by onlykelvin
(post deleted by author)
the thing is all the libs are now outdated
What does that have to do with your problem? All software quickly becomes either out of date or irrelevant. My previous software company had new releases every 6 months and did not support older version more that a few weeks.
It is possible ESP32 most recent core has broken your sketch. Try reverting back to 2.x.
It seems "working" simulations on Wokwi are also not working...
You can't power three servos from the 5V output of a processor. Simple as that.
With each servo having a stall current of about 2 Amps, which it draws every time a servo is asked to move, you have to supply an external power supply for this. The control can still come from the processor but not the power.
Make sure that the ground from the external supply is connected to the ground of the processor.
Also the code looks wrong.
Hi, @diheindl
Welcome to the forum.
What are you using for a power supply for the servos?
Can you post some images of your project?
So we can see your component layout.
Thanks... Tom.... :smiley: :+1: :coffee: :australia:
It does
   front.write(90); front.write(180); front.write(0);
   rear.write(90);  rear.write(0);    rear.write(180);
   arm.write(45);   arm.write(45);    arm.write(45);
so the arm servo won't do much.
Is there something else wrong with the code?
The issue has been identified and a solution found by @xfpd in #8.
// 2025:
//   The solution was given in the Discord channel of Wokwi.
//   There are only two timers available!
//   The solution is to use another library.
//   * https://github.com/Dlloydev/ESP32-ESP32S2-AnalogWrite
//   * https://github.com/khoih-prog/ESP32_New_ISR_Servo
//   The library by Dlloydev can use up to 16 servo motors.
a7
the servos are powered from a 5V railing where I supply a buck converter with 12V and outputs 5V only pwm pins are plugged to esp32
srry guys i was offline and didnt see the msgs.
[removed the pic since i found the error]
This the the picture, also thanks for welcoming me.:grin:
The wiring is correct, the only issue could be, is that all servos connected to the same rail.
And all servos work correctly if only 1 servo or 2 initialized in the code, but when 3 are initialized the 3rd servo does some BS it's always the 3rd servo, its a problem in the esp32 pwm channels i think.
yeah exactly arm servo isnt supposed to do anything, but the thing is it DOES, and thats the issue.
#include <Servo.h>
Pwm front;
Pwm rear;
Pwm arm;
int frontPin = 3;
int rearPin  = 8;
int armPin   = 16;
  front.attachServo(frontPin);
  rear.attachServo(rearPin);
  arm.attachServo(armPin);
  // Position 1
  front.writeServo(frontPin, 90);
  rear.writeServo(rearPin, 90);
  arm.writeServo(armPin, 45);
  delay(2000);
  // Position 2
  front.writeServo(frontPin, 180);
  rear.writeServo(rearPin, 0);
  delay(2000);
  // Position 3
  front.writeServo(frontPin, 0);
  rear.writeServo(rearPin, 180);
  delay(2000);
void loop() {}
   ESP32 PWM, SERVO and TONE Library, Version 5.0.2
   by dlloydev https://github.com/Dlloydev/ESP32-ESP32S2-AnalogWrite
   License: MIT
#include "pwmWrite.h"
Pwm::Pwm() {}
float Pwm::write(int pin, uint32_t duty) {
  uint8_t ch = attach(pin);
  if (ch < chMax) { // write PWM
    wr_duty(ch, duty);
  return mem[ch].frequency;
float Pwm::write(int pin, uint32_t duty, uint32_t frequency) {
    wr_freq_res(ch, frequency, mem[ch].resolution);
    wr_duty(ch, duty);
float Pwm::write(int pin, uint32_t duty, uint32_t frequency, uint8_t resolution) {
    wr_freq_res(ch, frequency, resolution);
    wr_duty(ch, duty);
float Pwm::write(int pin, uint32_t duty, uint32_t frequency, uint8_t resolution, uint32_t phase) {
    wr_phase(ch, duty, phase);
    wr_duty(ch, duty);
uint8_t Pwm::attach(int pin) {
  uint8_t ch = attached(pin);
  if (ch == 253) { // free channels exist
    for (uint8_t c = 0; c < chMax; c++) {
      if (mem[c].pin == 255 && ch == 253) { //first free ch
        mem[c].pin = pin;
        ch = c;
        ledcAttach(pin, mem[ch].frequency, mem[ch].resolution);
        if (sync) pause(ch);
        return ch;
  return ch;
uint8_t Pwm::attach(int pin, int ch) {
  if (mem[ch].pin == 255) {
    mem[ch].pin = pin;
  return ch;
uint8_t Pwm::attachInvert(int pin) {
  uint8_t ch = firstFreeCh();
  if (ch < chMax) mem[ch].pin = pin;
  ledc_attach_with_invert(pin, ch);
  return ch;
uint8_t Pwm::attachInvert(int pin, int ch) {
    mem[ch].pin = pin;
  return ch;
uint8_t Pwm::attachServo(int pin) {
  if (ch < chMax) config_servo(ch, mem[ch].servoMinUs, mem[ch].servoMaxUs);
  return attach(pin, ch);
uint8_t Pwm::attachServo(int pin, bool invert) {
  return (invert) ? attachInvert(pin, ch) : attach(pin, ch);
uint8_t Pwm::attachServo(int pin, int ch) {
uint8_t Pwm::attachServo(int pin, int ch, bool invert) {
uint8_t Pwm::attachServo(int pin, int minUs, int maxUs) {
  if (ch < chMax) config_servo(ch, minUs, maxUs);
uint8_t Pwm::attachServo(int pin, int ch, int minUs, int maxUs) {
uint8_t Pwm::attachServo(int pin, int ch, int minUs, int maxUs, bool invert) {
uint8_t Pwm::attachServo(int pin, int minUs, int maxUs, double speed, double ke) {
  if (ch < chMax) config_servo(ch, minUs, maxUs, speed, ke);
uint8_t Pwm::attachServo(int pin, int ch, int minUs, int maxUs, double speed, double ke) {
uint8_t Pwm::attachServo(int pin, int ch, int minUs, int maxUs, double speed, double ke, bool invert) {
float Pwm::read(int pin) {
  if (ch < chMax) {
    float deg = (readMicroseconds(pin) - mem[ch].servoMinUs) / (mem[ch].servoMaxUs - mem[ch].servoMinUs) * 180.0;
    return deg < 0 ? 0 : deg;
  else return 0;
float Pwm::readMicroseconds(int pin) {
  if (ch < chMax) return mem[ch].duty * ((1000000.0 / mem[ch].frequency) / ((1 << mem[ch].resolution) - 1.0)); // μs
  else return 0;
float Pwm::writeServo(int pin, float value, double speed, double ke) {
  wr_servo(pin, value, speed, ke);
  return mem[ch].ye; // normalized easing position (0.0 - 1.0)
float Pwm::writeServo(int pin, float value) {
        mem[c].pin = pin;
        ch = c;
        if (mem[ch].frequency < 40 || mem[ch].frequency > 900) mem[ch].frequency = 50;
        if (mem[ch].resolution > widthMax) mem[ch].resolution = widthMax;
        else if (mem[ch].resolution < 14 && widthMax == 20) mem[ch].resolution = 16;
        else if (mem[ch].resolution < 14) mem[ch].resolution = 14;
  wr_servo(pin, value, mem[ch].speed, mem[ch].ke);
void Pwm::tone(int pin, uint32_t frequency, uint16_t duration, uint16_t interval) {
  if (ch < chMax) {
    uint32_t ms = millis();
    static bool durDone = false;
#if defined(CONFIG_IDF_TARGET_ESP32C3)
    if (frequency < 153) frequency = 153;
#else
    if (frequency < 4) frequency = 4;
#endif
    if (!durDone) {
      if (frequency != mem[ch].frequency && (ms - mem[ch].startMs > interval)) {
        mem[ch].startMs = ms;
        mem[ch].frequency = frequency;
        ledcChangeFrequency(pin, frequency, mem[ch].resolution);
        write(pin, 127, frequency, 8);
        resume(ch);
      if ((duration && ((ms - mem[ch].startMs) > duration)) || (duration == 0)) {
        durDone = true;
        if (duration < 0xffff) pause(ch);
    } else if (ms - mem[ch].startMs > interval) durDone = false;
void Pwm::note(int pin, note_t note, uint8_t octave, uint16_t duration, uint16_t interval) {
  const uint16_t noteFrequencyBase[12] = {
    // C       C#        D       Eb        E        F       F#        G       G#        A       Bb        B
    4186,    4435,    4699,    4978,    5274,    5588,    5920,    6272,    6645,    7040,    7459,    7902
  uint32_t noteFreq =  (uint32_t)noteFrequencyBase[note] / (uint32_t)(1 << (8 - octave));
  if (octave <= 8 || note <= NOTE_MAX) tone(pin, noteFreq, duration, interval);
uint8_t Pwm::attached(int pin) {
  if (!((pinMask >> pin) & 1)) return 254; // not a pwm pin
  bool freeCh = false;
  for (uint8_t ch = 0; ch < chMax; ch++) {
    if (mem[ch].pin == pin) return ch;
    if (mem[ch].pin == 255) freeCh = true; // free channel(s) exist
  return (freeCh) ? 253 : 255; // freeCh : not attached
uint8_t Pwm::attachedPin(int ch) {
  return mem[ch].pin;
uint8_t Pwm::firstFreeCh(void) {
    if (mem[ch].pin == 255) return ch;
  return 255;
void Pwm::detach(int pin) {
  if (ch < chMax) {
    if (digitalRead(pin) == HIGH) delayMicroseconds(mem[ch].servoMaxUs);
    ledcWrite(pin, 4);
    ledcDetach(pin);
    reset_fields(ch);   // ← reset LAST
bool Pwm::detached(int pin) {
  return (ch == 254 || ch == 255);
void Pwm::pause(int ch) {
  if (ch == 255) sync = true;
  else ledc_timer_pause((ledc_mode_t)mem[ch].mode, (ledc_timer_t)mem[ch].timer);
void Pwm::resume(int ch) {
  if (sync && ch == 255) {
      if (mem[ch].pin < 48) ledc_timer_resume((ledc_mode_t)mem[ch].mode, (ledc_timer_t)mem[ch].timer);
    sync = false;
float Pwm::setFrequency(int pin, uint32_t frequency) {
  if (ch < chMax) {
    if (mem[ch].frequency != frequency) {
      ledcDetach(mem[ch].pin);
      ledcAttach(mem[ch].pin, frequency, mem[ch].resolution);
      ledcWrite(mem[ch].pin, mem[ch].duty);
      wr_ch_pair(ch, frequency, mem[ch].resolution);
  return ledcReadFreq(mem[ch].pin);
uint8_t Pwm::setResolution(int pin, uint8_t resolution) {
  if (ch < chMax) {
    if (mem[ch].resolution != resolution) {
      ledcAttach(mem[ch].pin, mem[ch].frequency, resolution);
      mem[ch].resolution = resolution;
      wr_ch_pair(ch, mem[ch].frequency, resolution);
  return mem[ch].resolution;
void Pwm::printDebug() {
  Serial.printf("PWM pins:\n");
  for (uint8_t i = 0; i < 48; i++) {
    if ((pinMask >> i) & 1) {
      Serial.printf("%d,", i);
  Serial.printf("\n\nCh  Pin     Hz Res  Duty  Servo     Speed   ke\n");
    Serial.printf ("%2d  %3d  %5.0f  %2d  %4d  %d-%d  %5.1f  %1.1f\n", ch, mem[ch].pin, mem[ch].frequency, mem[ch].resolution,
                   mem[ch].duty, mem[ch].servoMinUs, mem[ch].servoMaxUs, mem[ch].speed, mem[ch].ke);
  Serial.printf("\n");
/***** private functions *****/
void Pwm::ledc_attach_with_invert(int pin, int ch) {
  if (ch >= chMax) return;
  uint32_t ch_config = ch;
  if (ch > 7) ch_config = ch - 8;
  ledc_channel_config_t ledc_channel = {
    .gpio_num       = (mem[ch].pin),
    .speed_mode     = (ledc_mode_t) mem[ch].mode,
    .channel        = (ledc_channel_t) ch_config,
    .intr_type      = (ledc_intr_type_t) LEDC_INTR_DISABLE,
    .timer_sel      = (ledc_timer_t) mem[ch].timer,
    .duty           = 0,
    .hpoint         = 0,
    .flags = {
      .output_invert = 1
  ledc_channel_config(&ledc_channel);
float Pwm::duty2deg(int ch, uint32_t duty, float countPerUs) {
  return ((duty / countPerUs - mem[ch].servoMinUs) / (mem[ch].servoMaxUs - mem[ch].servoMinUs)) * 180.0;
void Pwm::config_servo(int ch, int minUs, int maxUs, double speed, double ke) {
  if (minUs < 500) mem[ch].servoMinUs = 500;
  else if (minUs > 2500) mem[ch].servoMinUs = 2500;
  else mem[ch].servoMinUs = minUs;
  if (maxUs < 500) mem[ch].servoMaxUs = 500;
  else if (maxUs > 2500) mem[ch].servoMaxUs = 2500;
  else mem[ch].servoMaxUs = maxUs;
  speed = (speed > 2000) ? 2000 : (speed < 0) ? 0 : speed;
  mem[ch].speed = speed;
  ke = (ke > 1.0) ? 1.0 : (ke < 0) ? 0 : ke;
  mem[ch].ke = ke;
  wr_ch_pair(ch, mem[ch].frequency, mem[ch].resolution);
void Pwm::wr_servo(int pin, float value, double speed, double ke) {
        mem[c].pin = pin;
        ch = c;
  uint32_t duty;
    float countPerUs = ((1 << mem[ch].resolution) - 1) / (1000000.0 / mem[ch].frequency);
    if (value < mem[ch].servoMinUs) {  // degrees
      if (value < 0) value = 0;
      else if (value > 180 && value < 500) value = 180;
      duty = (((value / 180.0) * (mem[ch].servoMaxUs - mem[ch].servoMinUs)) + mem[ch].servoMinUs) * countPerUs;
    } else {  // microseconds
      if (value < mem[ch].servoMinUs) value = mem[ch].servoMinUs;
      else if (value > mem[ch].servoMaxUs) value = mem[ch].servoMaxUs;
      duty = value * countPerUs;
    if (ke < 1.0) { // easing enabled
      float deltaDeg;
      uint32_t easeDuty;
      if (ke < 1.0 && duty != mem[ch].duty) { // init
        mem[ch].startDuty = mem[ch].stopDuty;
        mem[ch].stopDuty = duty;
        mem[ch].deltaDuty = (mem[ch].startDuty < mem[ch].stopDuty) ? mem[ch].stopDuty - mem[ch].startDuty : mem[ch].startDuty - mem[ch].stopDuty;
        mem[ch].startMs = millis();
        if (speed > 0) {
          deltaDeg = fabsf(duty2deg(ch, mem[ch].stopDuty, countPerUs) - duty2deg(ch, mem[ch].startDuty, countPerUs));
          mem[ch].stopMs = mem[ch].startMs + (deltaDeg / speed) * 1000;
          mem[ch].deltaMs = mem[ch].stopMs - mem[ch].startMs;
      uint32_t now = millis();
      if (duty > mem[ch].startDuty) {
        mem[ch].te = (float)(now - mem[ch].startMs) / mem[ch].deltaMs;
        mem[ch].ye = (-(ke + 1.0f) * (2.0f * mem[ch].te - 1.0f) / (2.0f * (-4.0f * ke * fabsf(mem[ch].te - 0.5f) + ke - 1.0f))) + 0.5f;
        if (isnan(mem[ch].ye) || mem[ch].ye < 0.0) mem[ch].ye = 0.0;
        else if (mem[ch].ye > 1.0) mem[ch].ye = 1.0;
        easeDuty = mem[ch].startDuty + (mem[ch].deltaDuty * mem[ch].ye);
        mem[ch].te = 1 - ((float)(now - mem[ch].startMs) / mem[ch].deltaMs);
        mem[ch].ye = 1 - (((ke + 1.0f) * (2.0f * mem[ch].te - 1.0f) / (2.0f * (-4.0f * ke * fabsf(mem[ch].te - 0.5f) + ke - 1.0f))) + 0.5f);
        easeDuty = duty + (mem[ch].deltaDuty * mem[ch].ye);
      ledcWrite(pin, easeDuty);
    } else ledcWrite(mem[ch].pin, duty);
    mem[ch].duty = duty;
void Pwm::wr_ch_pair(int ch, uint32_t frequency, uint8_t bits) {
  mem[ch].resolution = bits;
  if (ch % 2 == 0) { // even ch
    mem[ch + 1].frequency = frequency;
    mem[ch + 1].resolution = bits;
  } else { // odd ch
    mem[ch - 1].frequency = frequency;
    mem[ch - 1].resolution = bits;
void Pwm::wr_duty(int ch, uint32_t duty) {
  if (mem[ch].duty != duty) {
void Pwm::wr_freq_res(int ch, uint32_t frequency, uint8_t resolution) {
  if ((mem[ch].frequency != frequency) || (mem[ch].resolution != resolution)) {
    ledcAttach(mem[ch].pin, frequency, resolution);
    wr_ch_pair(ch, frequency, resolution);
void Pwm::wr_phase(int ch, uint32_t duty, uint32_t phase) {
  if (mem[ch].phase != phase) {
    ledc_set_duty_with_hpoint((ledc_mode_t)mem[ch].mode, (ledc_channel_t)ch_config, duty, phase);
    mem[ch].phase = phase;
void Pwm::reset_fields(int ch) {
  mem[ch].pin = 255;
  mem[ch].duty = 0;
  mem[ch].frequency = 1000;
  mem[ch].resolution = 8;
  mem[ch].phase = 0;
  mem[ch].servoMinUs = 544;
  mem[ch].servoMaxUs = 2400;
  mem[ch].speed = 0;
  mem[ch].ke = 1.0;
After updating the library it now works, and for some odd reason pwm pins of esp32 48,21, 47 wasnt workin i had to move pin to 8 now it works, thx guys for ur advice especially @xfpd and @alto777 and for @TomGeorge for welcoming me
Not before I saw it!
It's nice to know that sometimes I run a bench that is prettier, and sometimes I run one that is less pretty. Never mind the percentages.
That is to say always good to see any bench.
I'm curious about the non-working pins. I know there is care to be taken when selecting. On the UNO, the servo library can use any pin, and one only needs to remember that it knocks out PWM on pins 9 and 10.
a7
lol, I would also like to dig deep and find why the pins don't work, but i have a competition coming up, so ig after tht when i have free time.
